39,476 Members 1,490,473 Posts
Block paving help needed
This is a discussion on Block paving help needed within the The Roadside Hotel forums, part of the Members Area category; Wonder if anyone on here can help.... If part of the verticle soldier course (set in concrete) for a horizontally ...
Go Back   BRISKODA - The Skoda Forums > Members Area > The Roadside Hotel
Old 31-07-2008, 15:31   #1
GnatG's Avatar
Members Car: fabia 1.9TDi (100bhp)
If part of the verticle soldier course (set in concrete) for a horizontally laid block driveway is removed, could this cause the blocks behind it to slip forwards causing loss of intergrity to the driveway?
A txt diagram:
======================= <--- horizontal blocks
¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦*********¦¦¦ <--- soldier course (*** indicates blocks and concrete removed)
Cheers.
Edit: Forgot to mention that the level of the course removed is at the bottom of the slope, approx 1.5 ft slope top to bottom.
GnatG is offline
Old 31-07-2008, 15:35   #2
ASZ Eternal
ap0gee's Avatar
Members Car: Black Magic Fabia vRS
Re: Block paving help needed
It would depend on how long you want the blocks to stay put, what the blocks are laid on, what's on the blocks, and whether what's on the blocks will move...
ap0gee is offline
The Following User Says Thank You to ap0gee For This Useful Post:
GnatG (31-07-2008)
Old 31-07-2008, 15:38   #3
cheezemonkhai's Avatar
Members Car:
The biggest question is how big is the person you killed and want to bury?
cheezemonkhai is online now
The Following User Says Thank You to cheezemonkhai For This Useful Post:
GnatG (31-07-2008)
Old 31-07-2008, 15:41   #4
ASZ Eternal
ap0gee's Avatar
As long as they don't have any prostethics or gallstones, it's the John Haigh technique every time for me...
ap0gee is offline
Old 31-07-2008, 15:42   #5
GnatG's Avatar
They were laid on top of a crushed concrete sub base and bedding sand, according to Marshall's specifications. B*****d water company dug up part of the drive without informing me first, and I'm doubting a repair will be sufficient. Obviously want it sorted asap as I need to park 2 cars on the drive, but I'm not paying for somebody else's c**k up.
GnatG is offline
Old 31-07-2008, 15:43   #6
GnatG's Avatar
No comment!
GnatG is offline
Old 31-07-2008, 15:44   #7
ASZ Eternal
ap0gee's Avatar
If you're going to be driving cars on and off it constantly, I give it a couple of days max before the blocks on the leading edge of the repair shift. It needs to be put right ASAP...
ap0gee is offline
GnatG (31-07-2008)
Old 31-07-2008, 15:46   #8
Members Car:
Agree you need those blocks there really.
If they are on your property then they have to replace them anyway.
Old 31-07-2008, 15:53   #9
GnatG's Avatar
Thought as much. Now I have to convince the legal experts....! The water co. were going to use sub-standard contractors to do the work, and they seem unwilling to admit any liability! I just want to get it sorted ASAP using the same company that laid the drive for me in the first place (with the water company paying for the priviledge).
GnatG is offline
Old 31-07-2008, 15:55   #10
ASZ Eternal
ap0gee's Avatar
As it goes, this:
Paving Expert - Block Paving - Edge Courses
might put things into perspective...
ap0gee is offline
GnatG (31-07-2008)
Old 31-07-2008, 15:56   #11
GnatG's Avatar
That's what the company that laid the drive for me said. Said he may have to come back regularly if he tries repairing, as the blocks could shift every few months. Ideal scenario is a new drive from scratch, but could use some of the old blocks if they're not damaged. What a pain.
GnatG is offline
Old 31-07-2008, 15:56   #12
heresmo's Avatar
Members Car:
I'd say have a word with a Marshall's engineer. Clearly the blocks are (were) set in there for a reason. Hopefully they might be able to give you a tech spec to present to whomever you are hoping to claim against.
Regards
Mo
heresmo is online now
The Following User Says Thank You to heresmo For This Useful Post:
GnatG (31-07-2008)
Old 31-07-2008, 15:57   #13
GnatG's Avatar
As it goes, this:
Spoke to the guy that wrote the Paving Expert site a few minutes ago! What a nice man he was. Agreed with the advice you gave in your previous post. You could get a job as a block layer!
GnatG is offline
Old 31-07-2008, 16:22   #14
Members Car:
If those stones were on your property and they have not replaced them, then IIRC that's criminal damage.
GnatG (01-08-2008)
Old 01-08-2008, 11:15   #15
heresmo's Avatar
Members Car:
Well, sort of, or not, as it wasn't damage caused with intent. If I'm not mistaken, pipes that carry public services carry a right of access (could be wrong here). In practical terms, it's more likely to be a case of finding the easiest route to get through to the right person to talk to to get it sorted and if that fails, then consider a potentially costly legal route.
I know nothing though, so feel free to ignore this.
Mo
GnatG (01-08-2008)
Old 01-08-2008, 13:43   #16
GnatG's Avatar
Mo
I won't ignore you because what you say is correct. It's exactly what a friendly policeman told me. The pipes do carry a right of access, but only if the correct notice is served to the property owner first (IIRC 24 hours for a major burst/leak, 1 month for a minor leak, 2 months - as in my case - for other non urgent work). I was not served any notice before the digging commenced (nor after it had finished!). The water peeps are not playing ball. So, sadly, it's the legal route I'm progressing down, and if it becomes public so be it. Having investigated the way they carry out the works, there are ways of doing this (using a mole) which would dig to a substantial depth below the drive so as to not cause any damage. But that's obviously too simple for those "luddites"...... All to resolve a bad water pressure problem which still exists.
GnatG is offline
Old 01-08-2008, 13:44   #17
GnatG's Avatar
The criminal damage occured when somebody used one of the blocks to smash the rear windscreen on my car.
GnatG is offline
Old 01-08-2008, 14:04   #18
simonsheil's Avatar
As you say for non urgent works you should have been notified in writing that they are going on to your land. I'm guesing the pipe runs close up the edge of your property and the contractor got carried away and took out part of your drive, could probably go down as unexpected which shoudl cover them.
Obvisouly it is up to the water company to replace them, however, they have a right to rectify the works.
In terms of a mole in a residential area its preety mcuh a no no as far too much risk of hitting other services.
simonsheil is offline
Old 01-08-2008, 14:35   #19
vindaloo's Avatar
IMO....
Whenever the ground is excavated, it needs time to re-settle after being filled in, even if compacted with a thumper to start with. If the area is subject to traverse by people, it should be "finished" and flat. Usually, that means they'll cap it with tarmac. If they leave it sticking up and someone falls over, they're liable as they disturbed it.
You want the ground settled before beginning any remediation work for your driveway or it'll settle oddly.
J.
Slowly turning the planet sooty.
vindaloo is offline
The Following User Says Thank You to vindaloo For This Useful Post:
GnatG (01-08-2008)
Old 01-08-2008, 15:06   #20
tippo1983's Avatar
Members Car: Auris SR180
A txt diagram:
Cheers.
if the blocks are replaced within a week you will have no issues.
Im not addicted to coke, i just like the smell of it. - Richard Pryor
tippo1983 is offline
The Following User Says Thank You to tippo1983 For This Useful Post:
GnatG (01-08-2008)
Old 01-08-2008, 15:14   #21
Members Car:
Wonder if you could claim that off them since they left a brick unsecured and knew that if it wasn't down a scroat could potentially come and do it.
No idea, but worth asking.
GnatG (01-08-2008)
Old 01-08-2008, 15:28   #22
GnatG's Avatar
Been more than a week unfortunately....
GnatG is offline
Similar Threads
Hi all, new on the block. soldatov INTRODUCE YOURSELF! First time visitors, say hello here. 11 24-11-2007 23:15
New Skoda on the block nathan_marriott INTRODUCE YOURSELF! First time visitors, say hello here. 4 24-01-2007 09:45
New kid on the block 02 vRS Octavia INTRODUCE YOURSELF! First time visitors, say hello here. 5 27-09-2005 09:19
paving stones?? mattstimpson Off Topic and Chit Chat 6 23-09-2005 21:20
Hello, New bloke on block addsvrs INTRODUCE YOURSELF! First time visitors, say hello here. 9 07-04-2004 13:59
