39,476 Members 1,490,472 Posts
Boiler Problems
This is a discussion on Boiler Problems within the The Roadside Hotel forums, part of the Members Area category; This is something I plead a total lack of knowledge too, but I can imagine whatever is wrong is going ...
Go Back   BRISKODA - The Skoda Forums > Members Area > The Roadside Hotel
Old 25-09-2007, 23:39   #1
skodayouth's Avatar
Boiler Problems
This is something I plead a total lack of knowledge too, but I can imagine whatever is wrong is going to be expensive!
We have a combi boiler and I think it is made by IER or something like that. What keeps happening is when a hot tap is turned on the boiler fails to ignite. I have to switch the boiler off or use the reset switch and turn the tap on again for the flame to kick in,
Is there some kind of sensor that detects a hot tap being turned on that is broken?
Skoda Octava II Estate 1.9DSG Elegance
Anthracite Grey
Skoda Fabia 3 1.6 Tiptronic
Storm Blue
skodayouth is offline
Old 26-09-2007, 00:28   #2
Nuts
anonymouse's Avatar
Members Car: Fabia vRS
Re: Boiler Problems
We had a Worcester that was similar - got steadily worse.
Ours was a diaphragm vale in which the rubber was perishing so water was flowing through it.
May be similar. All I can suggest other than have a word with friends for someone to look at it (need to be qualified - forget the name, though - HAH Corgi qualified).
We got ours done by a relative of a relative who installed / repaired for the Council
£100 two years ago (and that was cheap).
"Stupidity, if left untreated, is self-correcting." - Heinlein
anonymouse is offline
Old 26-09-2007, 01:55   #3
cheezemonkhai's Avatar
Members Car:
Re: Boiler Problems
Had similar hard water had caused a flow sensor to jam up
cheezemonkhai is online now
Old 26-09-2007, 07:05   #4
Go 4X4 it
FOZ1's Avatar
Members Car: Octavia 1.8T 4X4 5DR
Re: Boiler Problems
We had similar too, flow sensor changed, all ok now. do have Centrica cover though, so no cost at time.
I would try & find a friend of a friend if you don't have cover, as it could be expensive.
Hope you get it sorted anyway, good luck.
Out of the asylum.- Into Freedom(Again )
Previous:-Red Citroen ZX Volcane, Chipped, Black Diamond drilled & grooved front discs, Greenstuff pads, Green Induction Kit, 16" Alloys.Powerflow exhaust.
FOZ1 is offline
Old 26-09-2007, 08:02   #5
Crossdresser
Quinten's Avatar
Re: Boiler Problems
I had similar (on a Potterton), and it turned out to be some air pressure sensor. There are lots of points of failures which all give you the same symptons, and if you are really unsure as to go about, get someone qualified in... you don't want to mess with gas.
What you can do (if you can bare it another 2 months or so), is get gas cover on the boiler, then report it as a fault in 2 months time after the initial period has expired...
Awooga!!!
Quinten is offline
Old 26-09-2007, 10:08   #6
skomaz's Avatar
Re: Boiler Problems
Might also be worth checking that the internal system pressure is up as well. I'm no expert but when my wife was in her flat and had a similar problem it turned out that the internal pressure had dropped below a preset value and as such the boiler would not fire up for safety reasons. It was an easy fix that was explained in the manual and was obvious from a pressure dial on the boiler?
If everything was as reliable as a VW... My Skoda would be at the bottom of the JD Power tables!
Octavia II 2.0 TDi 4x4 Estate and Fabia I 1.9 TDi Estate and Modified Mk1 Mazda MX-5 1.8iS
skomaz is online now
Old 26-09-2007, 15:04   #7
Members Car:
Re: Boiler Problems
We recently moved house.British Gas just been in(annual service) and condemned the boiler.Its too old for us to claim on our policy
With all the new regs(thanks John Prescott) its going to cost us about £3k for a new one(fitting etc ) so I hope yours is fixable
Apparantly the new ones are a pain /generally not reliable but we've got to have one .
Bit off topic.Sorry.Just get a corgi registered man in
lozgti is online now
Old 26-09-2007, 15:28   #8
Fluffy Bunny's Avatar
Re: Boiler Problems
Not much hel this but I had a problem with the boiler in my old house that wouldn't ignite and when it was looked at the reason the pilot light wouldn't ignite was because a moth was stuck in it and the spark couldn't ground.
Heather
Fluffy Bunny is offline
Old 26-09-2007, 17:36   #9
skomaz's Avatar
Re: Boiler Problems
Beware of what British Gas tell you and get an independant check. We had one guy from BG tell us similar but when I called them to ask specifics (I wasn't there at the time) another BG man came out and said that whilst it didn't meet current guidance (it did date from the 60's!) it was fine and just needed a bit of fettling.
We did subsequently replace the boiler a couple of years later but didn't go with BG who quoted about £3200 for the boiler, controls and associated plumbing work. A small local Corgi registered plumber did it for £1800 and gave us exactly what we wanted rather than what BG happened to want to sell us!
Old 26-09-2007, 18:05   #10
vrswhite's Avatar
Re: Boiler Problems
is your pressure and flow on your cold water taps comming into the prop ok? (you should check the kitchen tap for this)?
vrswhite is offline
Old 28-09-2007, 13:40   #11
Members Car: Octavia Turbo
Re: Boiler Problems
You could always do star jumps to keep warm
TheRSKid is offline
Old 28-09-2007, 14:45   #12
Oops! :(
apd007's Avatar
Location: The 2nd biggest city in the whole of England.
Members Car: Octy II vRS
Re: Boiler Problems
Have you tried searching on the internet? The reason why I ask is my sister had a similar issue in her house, a bit of searching and it turned out to be a minor thing (something silly like a setting or tap) that she sorted herself in minutes.
Support Briskoda join Freedom ======>
Was :- Skoda 120LSE Yellow 1.2 ~ 60 BHP?
Then :- Mk I Skoda Octavia Blueline 1.9 TDi 90 BHP.
Now :- Mk II Skoda Octavia vRS Black 2.0 TFSI. 200 BHP.
apd007 is offline
Old 29-09-2007, 00:07   #13
I parked up 1st
ric04vrs's Avatar
Members Car: silver Fabia VRS
Re: Boiler Problems
thats not really of any help , but it made me laugh
not so bored now
ric04vrs is offline
Old 29-09-2007, 01:05   #14
Kaiserb_uk's Avatar
Re: Boiler Problems
What is the consensus of opinion on these £7-£10 per month heating cover deals?
Personally I think it's like all insurance - we legally have to take out car insurance but if given the choice why bother? If it needs fixing then you pay what's required, and if not you don't. Or you can pay ten quid a month on the off-chance that you might have a problem?
Offended? spEak You're bRanes
MCSA:M
CompTIA:Security+
Mods:Nearly enough
Kaiserb_uk is offline
Similar Threads
Any Gas Boiler Experts Glider The Roadside Hotel 2 03-02-2007 20:16
GAS Boiler fix it myself or not johnmb The Roadside Hotel 23 20-10-2005 00:02
New Gas Boiler .................Mended!!!!! ag.morley The Roadside Hotel 7 16-10-2005 13:03
Help!! Any domestic boiler experts here!! Charlo Off Topic and Chit Chat 2 08-03-2005 19:22
Have I bought an old boiler? C.J. Maintenance & Performance 8 12-04-2004 14:13
