39,396 Members 1,487,239 Posts
Household electrical query.
This is a discussion on Household electrical query. within the The Roadside Hotel forums, part of the Members Area category; Recently we bought a washing machine. It has worked faultlessly for 2 weeks. Yesterday SWMBO plugged it in, turned it ...
Go Back   BRISKODA - The Skoda Forums > Members Area > The Roadside Hotel
Old 16-08-2006, 09:33   #1
Members Car:
Yesterday SWMBO plugged it in, turned it on at the socket and it tripped the 30mA breaker thingmy in the fuse box.
We have since tried other things in the same socket and they work fine. Due to the W/M being where it is, the only way to test it in other sockets is to use an extension lead - when we do this it is fine, even in the socket it was in to start with.
After all the messing around, we then tried it once mor ein the original socket and it worked
This morning I tried it again and it tripped.
Faulty washing machine? Worth changing the sealed plug?
Goochie is offline
Old 16-08-2006, 10:21   #2
I'm back...
Mr Grumpy's Avatar
Members Car: Office chair.....
Re: Household electrical query.
Faulty washing machine Goochie!
I have an electrician in the house as I type, he says don't use it, it could be dangerous, take it back. HTH
S50 VRS Number Plate for sale..ffs someone must want it....
Mr Grumpy is offline
Old 16-08-2006, 10:21   #3
Members Car:
Thanks.
Goochie is offline
Old 16-08-2006, 11:00   #4
Kentish's Avatar
Members Car: 4 wheels, 4 doors.
Do you want me to tell you it sounds like the heater, mains suppressor, motor or leak onto electrics causing it to trip?
Do not remove the moulded plug, unless you can see it's burnt..they very rarely cause problems.
The make would help with further ideas.
Andy
Owner of a sense of humour.
Kentish is offline
Old 16-08-2006, 11:02   #5
heresmo's Avatar
Members Car:
Agree. Best keep it unplugged from the socket also in the meanwhile of course. Plus if you mess about with it, you might invalidate the guarantee.
Best
Mo
heresmo is offline
Old 16-08-2006, 11:06   #6
Members Car:
When I say "recently bought" - its only been used 4-6 times. I was just wanting to check that others suspected the machine and not the household wiring.
I shall call Zanussi later.
Goochie is offline
Old 16-08-2006, 11:20   #7
Monkey Butler
thegavsters's Avatar
I reckon its the washing machine. We had an iron that used to trip out the supply. bought a new iron and no trip outs since.
Get your own Gamercard Sig.
thegavsters is offline
Old 16-08-2006, 11:26   #8
EddyH's Avatar
Members Car: Audi S8
Anything else plugged in at the same time on the occasions when the RCD has tripped? However I wouldn't expect a washing machine to have a high earth leakage current, it's usually IT equipment such as cheap PC power supplies that cause problems. As suggested it is most likely a fault with the washer, however it's best to eliminate other possibilities first as if it turns out the washer is fine you will most likely be charged for the call out.
EddyH
Audi A6 Avant 2.7 TDI
Audi A3 2.0 TDI Sport
EddyH is offline
Old 16-08-2006, 11:54   #9
Members Car:
The strangest thing is that the W/M works when connected to the same socket via a 20A extension lead.
However, I think the resistance of the extension when coiled may be enough to prevent the trip.
Goochie is offline
Old 16-08-2006, 11:56   #10
I'm back...
Mr Grumpy's Avatar
I still wouldn't use it, just to be on the safe side.
If it packs in when full I imagine an awful mess could ensue!
Old 16-08-2006, 12:03   #11
Members Car:
I'll send SWMBO down to the canal with a wash board then.
Goochie is offline
Old 16-08-2006, 12:12   #12
I'm back...
Mr Grumpy's Avatar
That's the way...
Treat 'em mean, keep 'em keen..
Old 16-08-2006, 14:44   #13
cheezemonkhai's Avatar
Members Car:
Defo the machine, Our old one did this and then we junked the thing and replaced it and never had a problem again.
cheezemonkhai is offline
Old 16-08-2006, 17:23   #14
heresmo's Avatar
Members Car:
One of mine decided to keep filling up (overflowing). I had heard about someone being electrocuted due to a bad connection, so switched the mains board off to be on the safe side. Several months later, it transpired that the water had caused rot in the joists where the water had seeped down around the edges of the room. Needed new joists and floor (not so good).
FWIW My Zanussi "appliance of science" dishwasher leaked in two places from the bottom (despite repairs) and my tumble dryer went bang because something had apparently been placed too closely to something else. I don't buy Zanussi these days.
Regards
Mo
heresmo is offline
Old 16-08-2006, 18:02   #15
splash!!!!
bengie's Avatar
Members Car: 4x4 turbo estate
don't worry it won't hurt you phil, seeing as you have an RCD you will also have MCB's so the chance of you getting a shock is very remote.
it might be the machine but it might also be a weak RCD. get an electrician local to you to test the RCD, we have this in council houses every now and then.
it could also be down to something very simple like a bad incoming earth connection, its a shame you live miles away now as i would have popped over and taken a look for you
owner of a skoda octavia 4xvrs3
bengie is offline
Old 16-08-2006, 18:48   #16
Kentish's Avatar
Sorry, I didn't twig it was brand new..
Call the manufacturer is the answer for sure.
Andy
Kentish is offline
