39,396 Members 1,487,238 Posts
Important home security warning.
This is a discussion on Important home security warning. within the The Roadside Hotel forums, part of the Members Area category; Found this on Scoobynet and thought it should be known by as many as possible. http://bbs.scoobynet.com/fao-those-upvc-t537518.html...
Go Back   BRISKODA - The Skoda Forums > Members Area > The Roadside Hotel
Old 21-08-2006, 12:29   #1
Members Car:
Goochie is offline
Old 22-08-2006, 12:05   #2
heresmo's Avatar
Members Car:
Re: Important home security warning.
It was a common problem with double glazing, especially for UPVC, as some of the construction was on the outside, so it was simply de-constructed. Whilst known, it's a reason for ensuring windows are fitted by a reputable company, both to have confidence and also to ensure that an odd construction item is not accidentally left out, since much fitting, even by big companies, is subcontracted.
I think multi-point locking systems give a false sense of security, personally. I reckon they are probably more to prevent warping, when you think that they all run off a central lock - so if that is compromised...
Patio doors can be a weakness (as a friend discovered, though the insurance did pay out). He had an "anti-slide mod" fitted albeit after the horse had bolted.
As said on Scoobynet, windows make for easier access, given that any space wide enough for a human head to go through is sufficient to get a whole person through! (Often a small kiddie accomplice in the progs I've seen.)
FWIW I've locked myself out of different properties so many times to know how easy it is to get in. Luckily, I've never had owt worth marketing on the nicked market (sobs).
Regards
Mo
PS For Goochie: For some reason I had to register on Scoobynet to gain access to that thread If I didn't know better, I'd think it was just a ruse to get me join Regards, Mo
heresmo is offline
Old 22-08-2006, 12:18   #3
Old Git
Octygone's Avatar
Oh sod it
Only thing I can do is fit bolts on the inside for now...and hope the lock people come up with a way to stop it
Octygone is offline
Old 22-08-2006, 12:20   #4
Members Car:
Apparently the technique has been known to "the lock people" for years. The problem is that the internet is bringing this knowledge to everyone
Goochie is offline
Old 22-08-2006, 12:25   #5
Old Git
Octygone's Avatar
Just figured it out .....bolts on the inside of the front door and go out through the back door which has a normal 5 lever chubb lock ...my double glazing is fitted from inside so they can't take the glass out to get in......just can't fit an alarm as the cat would set it off
Octygone is offline
Old 22-08-2006, 12:28   #6
Members Car:
You can get an alarm if you have a cat. You just need pet sensitive PIR sensors.
We have changed our PIR's to pet sensitive and they're fine with our medium sized dog - so a cat should be fine.
Goochie is offline
Old 22-08-2006, 12:32   #7
heresmo's Avatar
Members Car:
Not sure about that Goochie (edit, referring to your post no.4). I did a few searches after the last time I locked myself out thinking (as you did re batchrooms) that it was easy money. There's so much available on the Net, that anyone with a purpose wouldn't need to look far.
It never hurts to know how vulnerable one is, so it's no bad thing IMO. Plus it reminds people to review their insurance, as some policies are conditional on keeping the main house keys in the main sleeping room!, and all windows have to be closed and locked throughout the house at night etc. There was a case of insurance not being paid because an upstairs window was left open (invalidating the insurance) even though it was clear that the burglars had entered via the back door.
Regards
Mo
heresmo is offline
Old 22-08-2006, 12:33   #8
150HP&counting's Avatar
I think most of the pet sensitive pirs allow for pets upto around the 20-25Kg weight - unfortunately my liitle germ shep dont fit those limits and generally she is enough of an alarm for most burglers
What is: Octavia vRS... Black Magic yet again... with plenty planned
What was (May she RIP): Blk Magic Octy (Not quite a VRS) L&K,Climate,Heated leather,Cruise,Xenons,
MODS(so far): Custom Code Phase II JBS-Forge-007P DV, Forge/Samco TIP, 18" Ace 205's, ABD/JBS CAI (*Wooosh), Audi TT 312mm Brakes
150HP&counting is offline
Old 22-08-2006, 13:49   #9
mello in yello
postmanpat's Avatar
Members Car: fabia vRS/ octavia vRS
Glad we swapped the upvc for an old fashioned wood door with a mortice lock. That is truly scary.
Originally Posted by Emily-Elizabeth
Sperm donership: It is not like giving blood, it is tossing away...............
Postmanpats car Fabia vRS Zennons, ESP, autochanger, 3rd headrest, heated seats, cruise control
SWMBO Octy Mk2 vS maxidot, duel zone wotsit, cruise, parking sensors, 18" alloys
postmanpat is offline
Old 22-08-2006, 15:00   #10
johnjohnhealy's Avatar
Members Car: Superb 130pd
Pet sensitive PIR's are available for almost any size dog, basically all they are is a normal PIR with a different lense in them that cuts the beam of at a certain hight depending on the size of animal, therefore theoreticaly if a burglar suspected you had pet sensitive PIR's he could crawl underneath the beam, mission impossible style!
Only problem with pet sensitive PIR's and cats is that cats climb around and are likely to cimb into the detected zone. whereas dogs dont generaly climb.
johnjohnhealy is offline
Old 22-08-2006, 15:15   #11
Members Car:
We were told differently. The PIR is triggered by IR given off by objects. The pet filter filters more IR making it less sensitive.
Trouble is that if you have a big dog there is littl edifference between the dog and a teenage oik. Hence the 25kg limit on dog size.
Goochie is offline
