39,396 Members 1,487,240 Posts
LED bike lights?
This is a discussion on LED bike lights? within the The Roadside Hotel forums, part of the Members Area category; Anyone got any experience of LED bike lights and how the output compares to filament lamps? I'm just after a ...
Go Back   BRISKODA - The Skoda Forums > Members Area > The Roadside Hotel
Old 31-01-2007, 10:51   #1
slacker
steve0275's Avatar
Location: Maybe I'm in hell, maybe I'm alone But I can deal with this, at least I feel at home.
Members Car: Pug 306 xsi, Fabia VRS
Question LED bike lights?
Anyone got any experience of LED bike lights and how the output compares to filament lamps? I'm just after a set for road riding, mainly so that i can be seen rather than illuminating the whole road, just so that i can get in some pratice on these dark evenings.
i'm considering these 2 as they seem to be rated well.
Clicky
and clicky
Ta!
06 black magic furby vRS, slower than a mustang.
steve0275 is offline
Old 31-01-2007, 11:11   #2
Members Car:
Re: LED bike lights?
I actually have the second one fitted on my bike.
The output is great but one thing I do find is that it gives a bright spot of light with no peripherial lighting. This means you do tend to get a bright spot with defined edges at which it becomes very dark.
I tend to have mine aimed a fair distance in front to aid fast riding but this means I get a black spot between the pool of light and my wheel.
If I used my bike on anything other than paved cycle routes and a canal towpath I'd look at getting another, set slightly differently, to fill this black spot.
The rear one is great!
Goochie is offline
Old 31-01-2007, 11:11   #3
ASZ Eternal
ap0gee's Avatar
Members Car: Black Magic Fabia vRS
LEDs are much better in terms of visibility to stop you getting run over, but their beam pattern is pretty narrow so they aren't ideal as actual headlights. Then again, you mention you'll be road riding (on lit roads, presumably) in which case this won't be an issue...
I saw a cyclist the other day with a hi-vis bib, that as well as having reflective bands and braces also had red LEDs on front and back. Might be worth considering if you're planning to ride on busy roads? (Sure, you'll look a bit of a t1t, but at least it'll help prevent you being run over! )
ap0gee is offline
Old 31-01-2007, 11:57   #4
slacker
steve0275's Avatar
I thought as much, my experience of LED torches seemed to suggest that it would be a more focused beam of light. As i said its only for road riding on lit roads so should be fine, and i would seriously consider a high vis bib aswell, dont care if i look a t!t so long as i dont get myself mashed by a car!
anyone remember this? YouTube - Pedal Safety Song 1978
Old 31-01-2007, 12:09   #5
Members Car:
One other this that I do is to mount the rear light on the frame rather than the seatpost.
I started doing this after following a cyclist who's coat was hanging down below the seat and obscuring the rear light.
Some front and rear lights can be make to flash/strobe quickly to help point you out to drivers.
Goochie is offline
Old 31-01-2007, 12:13   #6
heresmo's Avatar
Members Car:
If it's not a stupid question, is there any reason why it's "either" "or" rather than both? Can't you have lots of lights? Meaning those that will light the road for you and those that allow you to be seen by car drivers? Plus vest straps, spoke fluorescent flashers, those led lights on the back of pedals etc. Get the whole lot as far as I'm concerned.
That's not a rant, just that cyclists (and pedestrians dressed in black) are the stuff that nightmares are made from when you only just miss them because you ain't got a cat in hell's chance of seeing them till you have to swerve dramatically and possibly cause an accident by doing that.
*Has little lie down*
Mo
heresmo is offline
Old 31-01-2007, 12:20   #7
Members Car:
Mo, as I said above, if I needed to cycle anywhere darker I woul dget another light for the front. However, at £50 a pop its a lot of money to be spending.
I do have a second set of older filament type lights in the rucksack I have with me that I can fit if I find my LED lamps are stolen/dead when I come to ride.
In the winter I wear a rather tasty pair of bright yellow high-vis trousers too. Mainly to stop my wrok trousers getting wet/muddy but they are very bright and have reflective bands around them too.
As a motorist and a cyclist I've had my eyes opened to poor cyclists. When I was in my teens I used to go everywher eon my bike and I now look back and realise just how stupid some of the things I did were - I think its important to use motoring experience when on a bicylce - it could save your life.
Being seen by others is far more important than essing where you're going.
*Goes for a drink* the shock of saying something sensible is just too much to cope with
Goochie is offline
Old 31-01-2007, 12:21   #8
Members Car: VW Corrado Storm
Take a look at these little things:-
Glo-Toob
They are extremely bright, easy to use, and could easily be attached to a bike for the rear/front marker light, and they will be visible from all angles too, so will increase side on visibility. I use one for scuba diving at night, and SWIMBO has a red and a white for her horse. There are 7 flash/glow modes, and it'll last for about 50-80 hours on a single battery. Replacement batteries are available from Tescos for about £1.20 each.
Phil
My Car - 2.0 TDI Octavia L&K
My Toy - 95 Corrado VR6 STORM
SWMBO's - 55 Navara
storm monkey is offline
Old 31-01-2007, 14:18   #9
heresmo's Avatar
Members Car:
Goochie, I was actually replying to the OP post - it just happened to follow yours in sequence.
There is much info being put forward in this thread both from yourself and all the other posts arriving about keeping cyclists safe I sometimes get out of my car and tell cyclists that they can't be seen. Usually, when I pull up in front of them they think I'm going to mug them or something so I've stopped doing that now LOL.
Any info and emphasis on common sense is 110% by me
Regards
Mo
heresmo is offline
Old 31-01-2007, 14:42   #10
kit
kit's Avatar
Members Car: octavia RS
i have one attached on my staffies collar when she goes out at night....can see her miles away
K
kit is offline
Old 31-01-2007, 20:23   #11
Kentish's Avatar
Members Car: 4 wheels, 4 doors.
I used to run 2x 10w halogen Cateyes, one flood one spot. Also 1 or 2 light "cannons" which were multy LED lights, all of this at the front. On the rear,3 LED lights. All the LED lights (both front and back) were set to flashing. This prolongs the battery life, and makes it much easier to see you.
If it's cost you're concerened about, what price brain damage or broken limb after being moan down by a motor or some sort?.
Andy
Owner of a sense of humour.
Kentish is offline
Old 31-01-2007, 20:28   #12
Sonic1980's Avatar
Members Car: Fabia vRS - Black
I got the LED set from Halfords ( a winter special @ £20) and its brilliant for my 4mile cycle commute.
I think you need 2 rear lights, one static and one strobe and one or two for the front. The combination of static and flashing is nigh on impossible to miss.
hth
Fabia v/RS
http://www.whf.org.uk
Wildlife Heritage Foundation - The Big Cat Sanctuary in Kent.
Part of the European Endangered Species Programme (EEP)
Big Cat Encounter - Want an idea for a great present??
Sonic1980 is offline
Old 31-01-2007, 22:13   #13
monkeychild's Avatar
Members Car: Octavia vRS
I have these and they are ace!!! Merlin Cycles Ltd Blackburn Lights (bottom of the page)
They are good as you get seen from the side too!!!!
My Brum Brums: 2002 Silver MKI Octy vRS standard apart from an APR R1 DV 2002 1.4 Tdi Polo
My Pedal Pedals: 2008 Gary Fisher Hookooekoo, 2008 Genesis io Singlespeed 2003 Kona Lavadome Single speed goodness
monkeychild is offline
Old 31-01-2007, 23:28   #14
jason's Avatar
Members Car: skoda octavia VRS
http://campusbikeshop.com/images/lib...l300s_04_m.jpg
thats my front,pretty good for a "cheap" light.
is it not true that flashing lights are illegal ?even though its not exactly enforced?
a mate at work who i bike with has just bought some HID lights for hundreds of pounds.
he says he's been flashed by cars.
this is my rear:
http://www.sigmasport.co.uk/store/li...s/t_ld1000.jpg
has 6 rear and 4 sidewards facing led.award winning iirc
louder than war
jason is offline
Old 01-02-2007, 09:26   #15
slacker
steve0275's Avatar
ok, been having a look round and am now considering a set of these Electron Light System EHP315 Twin 5w-10W NiWH Lights - Front 49.99 GBP Free P & P to UK & Ireland, Cheap International Rates. Next day delivery from Europes Largest Online Bikeshop. with some better bulbs.
and a couple of decent led rears.
Old 01-02-2007, 11:20   #16
heresmo's Avatar
Members Car:
this is my rear:
[my bold] This was discussed here, starting from around post # 20-ish:
http://www.briskoda.net/forums/off-t...cycle+flashing
Mo
heresmo is offline
Old 01-02-2007, 18:15   #17
vindaloo's Avatar
IMO you need a combination effect. Something to splash a lot of ambience around and something to pin-point your position.
As a driver, LED's are great once you're aware of them but they're a small point source and normally don't work wide angles very well. Combined with the current fad for smaller, lighter, brighter lights means the only other clue is if the bike's rear reflector is visible.
J.
Slowly turning the planet sooty.
vindaloo is offline
Old 01-02-2007, 18:38   #18
3 little red LED's on tha back of a bike are a real pain to spot, particularly in traffic, where there are larger brighter red lights around. The silver reflective tape you get on hi vis jackets is by far the most noticable, when you shed a little light on it.
Did see a front bike light once where there was the main light on the road, and a small bulb or LED directed at the rider, so there whole torso was lit up. Very easy to spot!
Phil
SWMBO's - 55 Navara
Old 01-02-2007, 18:43   #19
Old Git
Octygone's Avatar
I have a feeling the flashing LEDs are illegal for road use
Octygone is offline
Old 01-02-2007, 18:57   #20
Worthless loser
drm_jones's Avatar
Members Car: Unimportant
I have one of the Blackburn quadrant lights on my bike - they are very good. It has 3 mode settings:
1) All LEDs on
2) 2 main LEDs on, 2 side LEDs flashing
3) All LEDs flashing
A few mates have them as well and they give them a big thumbs up
Excellent value for money and good battery life as well
David
2002 Black Magic Octavia V/RS
drm_jones is offline
Old 01-02-2007, 23:19   #21
vindaloo's Avatar
Not so long ago, all LEDs were technically illegal if the legislation was interpreted in a certain way.
ISTR that the flasher stuff may not be illegal now... or by summer at any rate... There's an amendment up...
Can't possibly be any more vague than that so I'll be off then....
J.
vindaloo is offline
Old 01-02-2007, 23:57   #22
ASZ Eternal
ap0gee's Avatar
The last newsletter I got from the Cyclists' Touring Club (no longer a member - spare tyre may or may not be related to this!) had a bit about how they'd successfully lobbied for the law to be changed, so that they're now (or soon will be legal). I certainly very much doubt you'd be pulled over for having them...
ap0gee is offline
Old 02-02-2007, 08:14   #23
Old Git
Octygone's Avatar
Don't get me wrong I would much sooner see any kind of light on bikes around here as most of them seem to think it's fun to ride ride along or cross roads in front of you with no lights at all.........but unless those led lights point in the right direction they are very difficult to see due to the narrow angle of them.
Octygone is offline
Old 02-02-2007, 10:19   #24
Have you looked at Silva head torches, particularly the L1? I've started night riding this year around Wharncliffe Woods so have been messing around with bike lights recently.
Being tight with my money and happy to modify, I've ended up with twin electron lights but with 2 x Cateye 15w spot bulbs running off two 7.2V model car batteries. They're more than a match for the Lumicycle 10/12W setup (piccys available of them in action on the Lumicycle website).
However, I've also bought a Silva L1 head torch for ~£50. Personally i can't see quite as well with the LED blue/white light compared to the yellow/white light of Halogen but its very similar in 'reach' and output to a 10/15w halogen bulb. Though you wouldn't want to go too quickly, you could safely cycle at normal speed with it in complete darkeness without a problem. It'll run of 4xAA mounted on your head or 4xC which you put in your bag.
The combination of 1 of my 'over-volted' cateye 15W halogens with the Silva in flashing mode actually brings most drivers coming in the opposite direction to crawling place. Maybe its a wee bit dangerous (funny though!) but i only do short sections of back roads to join up the off road bits. Being a head torch you can also use it for other things too.
Mondeo Tdci 115, sweet!
DaveH is offline
Old 02-02-2007, 10:44   #25
slacker
steve0275's Avatar
Thanks for the reply dave,
I was looking at the electron 5w/10w combo but after seeing bad reviews for the build quality i am now looking at the BLT metrino 15, same thing but build seems to be regarded better.
BLT Metrino 15 - Halogen Lights - Front 49.99 GBP Free P & P to UK & Ireland, Cheap International Rates. Next day delivery from Europes Largest Online Bikeshop.
The GF has kindly offered to buy me these as a birthday pressie! I will no doubt upgrade the bulbs and batteries at some point.
On top of this i am going to invest in some decent rear lights and high vis reflectives for road riding.
If i get to off roading in the dark then i will seriously consider a head torch as i have heard nothing but praise for them! Need to build up the fitness a bit first methinks!
Cheers
Steve.
