This is a discussion on 105 and engine transplants.. within the RWD Skodas and others forums, part of the Skoda Model Discussion Area category; Jumping ahead here but whats needed to fit the Favourit or felicia engine into an estelle 105 1986/7 vintage? ....Also ...
| Briskodian Join Date: Mar 2008
| Jumping ahead here but whats needed to fit the Favourit or felicia engine into an estelle 105 1986/7 vintage? ....Also have read that all models from 1984 on have the later type rear suspension? ...Be grateful if anyone can explain why at my age the thought of collecting the 105 is keeping me awake at night!! ![]() |
| Briskodian Join Date: Jan 2004 Location: DONCASTER
| You will need the 136 rapid manifolds, flywheel and clutch, iirc distributor, sump,oil pick up and strainer. these are the major bits. One or two nuts and bolts will swop from the other engine As for the rear suspension , the semi trailing set up was fitted to the rapid and 130 estelles. to fit this you will need the gearbox to go with it and the gear selector rod as it is a different length
__________________ I DONT WANT TO DIE A GROWN UP!!! |
| The Following User Says Thank You to rigsby For This Useful Post: | Downton (26-03-2008)
