135 Rapid - overrunning
This is a discussion on 135 Rapid - overrunning within the RWD Skodas and others forums, part of the Skoda Model Discussion Area category; I have a Skoda Rapid (135 RIC converted to carburettor), i'm finding that the engine keeps overrunning after a decent ...
Old 25-01-2008, 11:08   #1
Default 135 Rapid - overrunning
I have a Skoda Rapid (135 RIC converted to carburettor), i'm finding that the engine keeps overrunning after a decent run, though it does not appear to be overheating. Certainly the temperature gauge does not suggest this, and appears to be working fine. I rather need to get this sorted as, following someone destroying my Seat while parker, I need the Skoda for work... Any ideas?
Tysonian is offline
Old 25-01-2008, 13:15   #2
KenONeill's Avatar
Default Re: 135 Rapid - overrunning
Over-running? Do you mean it's running on after you switch the ignition off?
KenONeill is offline
Old 25-01-2008, 21:33   #3
rigsby's Avatar
Eesy solution.
1 put handbrake on
2 put in 5th gear
3 lift clutch and stall engine
Mine allways did it until i put webber on it
I DONT WANT TO DIE A GROWN UP!!!
rigsby is offline
Old 28-01-2008, 09:18   #4
Tailhappy's Avatar
The 136 range has (or should have) an anti-run on valve fitted on the carb which cuts the fuel when the ignition is switched off. There should be a metal contact tab on the 136 carb which needs wiring onto the switched ignition. That will solve it.
Ian
Tailhappy is offline
Old 28-01-2008, 10:21   #5
KenONeill's Avatar
Yeah Ian, that's exactly the sort of thing I was thinking of, was issues with an existing anti run-on valve, or the need to fit one if there wasn't one.
