39,457 Members 1,489,949 Posts
Estelle distributors - two become one
This is a discussion on Estelle distributors - two become one within the RWD Skodas and others forums, part of the Skoda Model Discussion Area category; I thought I had better start a new thread on this - it is not related to my other question ...
Old 06-04-2008, 22:43   #1
Tailhappy's Avatar
I thought I had better start a new thread on this - it is not related to my other question about the 105 you see.
Looking through the 1991 isue Estelle/Rapid parts book and workshop manual, there are two different distributors listed - one for the 105 range and one for the 123/130/136 range. The only difference between them is the advance curves - as stated by the workshop manual.
Nowadays, only one distriburor is available for all cars. My queston is how were two distributors amalgamated to one type? Is the curve in the new type partway between the original two?
Can anyone elaborate on the two curves and let me know how they affect the running properties of the car. Will having the wrong curve give a problem?
Thank you,
Ian
Tailhappy is offline
Old 07-04-2008, 13:34   #2
KenONeill's Avatar
Members Car: Octavia TDi110
Re: Estelle distributors - two become one
I'd think that the advance curve on the "new" dissie must be different. I don't know how though, because different rate springs will change the mechanical advance rate, and a different vacumn unit will change the vacumn advance.
As for how the change will affect the running of the car, I don't know. You'd need someone with experience (ideally including engine dyno time) of both to answer that properly.
<sits back and waits for DaveRapid>
KenONeill is offline
Old 07-04-2008, 15:00   #3
rigsby's Avatar
See skudman on the skoda-forum, he will know
I DONT WANT TO DIE A GROWN UP!
rigsby is offline
Old 07-04-2008, 16:10   #4
Tailhappy's Avatar
Thank you. Do you have any contact details for Skudman? I am only on this one Skoda forum you see, and although I could join another, I would like to stay loyal to just one as I will not be able to contribute very well to two forums (if I was a member of both).
Cheers, Ian
Old 07-04-2008, 18:34   #5
daverapid's Avatar
Members Car: SKODA RAPID 136
The advance curve is different for the 105 distributor. It used to be quite common for 105 distributors to be fitted to 120/130 models as apparantly it makes them go better. To be honest I doubt very much if it would make much difference in the real world, and it appears the distributor manufacturers agree. You can vary the amount of vacuum advance by undoing the 19mm bolt on the end of the vacuum unit and adding/removing washers as required. The official Skoda method of curing early Favorit 136's pinking problem was to add an extra washer to reduce the amount of vacuum advance.
Worth remembering that the ignition timing will never be spot on if there is excessive slack in the timing chain.
Also worth remembering that on old cars such as these setting the timing "by the book" doesn't necessarily mean the engine is set for optimum efficiency. It's often better to use good old fashioned "earsight" and a few roadtests!
David McKinney
TREASURER OF SKODA OWNERS CLUB GREAT BRITAIN
www.skoda-owners-club.org.uk
daverapid is offline
The Following User Says Thank You to daverapid For This Useful Post:
Tailhappy (07-04-2008)
Old 07-04-2008, 23:37   #6
Tailhappy's Avatar
Thanks Dave - that is much appreciated info.
Well, I went a test run today to get some fresh LRP, and with the timing at 3 degrees before TDC with the Luminition fitted I am getting pinking on acceleration and also a roughish tickover - not able to smooth it out by tinkering with the mixture screws. Also when starting from cold it sounds like the engine is 'working against itself' and almost stalling the starter motor out for a few turns (then it fires).
I will try some road tests and vary the position of the distributor a little at a time (retard) and see where that leads me.
Thank you once again,
Ian
Old 08-04-2008, 08:24   #7
KenONeill's Avatar
Pinking suggests too much advance. What I used to do back in the day was set up plugs, points gap etc, get the engine hot, then set the timing by ear to the fastest idle speed I could get, then slow the idle back down with the throttle stop screw.
Old 21-04-2008, 21:24   #8
daverapid's Avatar
Ian
I removed the cylinder head from this car today. Looking at the state of the head gasket I'm not surprised it pinked!
David McKinney
Old 22-04-2008, 08:59   #9
KenONeill's Avatar
Well and truly cream-crackered?
Similar Threads
estelle or newer??? mantamad RWD Skodas and others 4 11-01-2008 00:11
My estelle is dead! Barclay120 RWD Skodas and others 3 07-03-2007 18:55
Old Estelle Sam Tan RWD Skodas and others 4 22-02-2007 20:00
Estelle...30 this year! daverapid General Car Chat 8 15-04-2006 00:15
