Estelle driveshafts/diff
This is a discussion on Estelle driveshafts/diff within the RWD Skodas and others forums, part of the Skoda Model Discussion Area category; I have fitted a weber carb and KandN filter to my estelle which gave me loads more power, took it ...
Old 29-05-2007, 12:22   #1
Unhappy Estelle driveshafts/diff
I have fitted a weber carb and KandN filter to my estelle which gave me loads more power, took it for a spin round the block and didnt even make it home before I lost all drive. I pulled off a junction and lost drive with it in gear. When I got towed home there was a very loud rattling coming from the rear. The clutch is engaging fine and the speedo goes up but the car aint going anywhere!
What have I done??!?
Barclay120 is offline
Old 29-05-2007, 13:02   #2
Hairy Yeti
Lummox's Avatar
Default Re: Estelle driveshafts/diff
Sounds like a bust CV joint.
Unit 18 now open Servicing, repairs, modifications you name it we do it. Cupra console bushes at special price, PM for a very competitive quote.
Lummox is offline
Old 29-05-2007, 13:10   #3
KenONeill's Avatar
...or the diff's gone (but the CV joint's more likely).
KenONeill is offline
Old 30-05-2007, 14:12   #4
Unhappy Re: Estelle driveshafts/diff
The diff seems fine, iv take of the axel and the little connecting noddule has snapped into a number of pieces, which would be fine as I have i new one to hand but the middle of the old one is firmly wedged in place. I have tried bashing it but it aint going nowhere!
Old 30-05-2007, 15:14   #5
TeflonTom's Avatar
the speedo drive comes off the diff crownwheel. this suggests to me that power is coming through the gears/syncromeshes etc because the corwnwheel must be turning for you to register the speed on the speedo.
surely if a cv joint was broke, it would still move a little
does the speedo work when the car is being towed??
i would suggest that you've sheered off the rivets that hold the diff casing to the crownwheel
TeflonTom is offline
Old 30-05-2007, 15:52   #6
KenONeill's Avatar
Well, if Tom's right and the speedo drive's off the crownwheel, then that's still turning. If the car's not moving then it's either a smashed CV or Hookes joint (pretty obvious), or something badly wrong with the differential gears themselves or their connection to the crownwheel.
Tom, unless the Estelle came with an LSD of some form as standard, I'd expect no movement with a totally failed joint, because all the power will be directed to the side of the diff with the failed joint on it (empirical proof - I've "locked" one side of a diff (in a tech museum), and watched as the other free side spun at double speed).
Old 31-05-2007, 11:03   #7
Its definatley the joint. I have the whole shaft, suspension, trailing arm, etc and the joint has snapped off both sides. There is a pin with block guides on either side, the guides have sheared off and left half the pin stuck in the middle. I have tried hitting it, heating it, putting it in a vice and trying to squeeze it out and various combinations of the above!
Old 31-05-2007, 11:17   #8
KenONeill's Avatar
Cheers mate. No idea about how to shift it I'm afraid. Good to know that my understanding of the open diff is confirmed again.
Old 31-05-2007, 11:21   #9
lol. well im hardly the expert so all help is appreciated! I think I will most probably have to drill it out.
Old 31-05-2007, 12:42   #10
KenONeill's Avatar
I've a notion that the yolk (basic Hooke's joint) or pins (CV joint) are heat-hardened, so drilling may be hard to impossible.
Quite often (from exploded diagrams) the yolk in a Hooke's is held in place by end cups, which are held in place by circlips. Does that seem any sort of familiar?
