This is a discussion on Faulty Favorit electrics within the RWD Skodas and others forums, part of the Skoda Model Discussion Area category; Hi,this is my first thread on this site so i hope it makes some sense! The Skoda in question is ...
| Briskodian Join Date: Jan 2007
| Hi,this is my first thread on this site so i hope it makes some sense! The Skoda in question is a 1995 Favorit GLXie 1.3 and the electrics are playing up. The fun begins when you switch on the lights at dusk and they begin to flicker at idle. I have tested the battery and the alternator for drops in current and they seem healthy enough. My next thought is to try an auto electrician though it could be pricey. I suspect if the Police saw it, i could expect points or a fine at the least. Anyone got any good ideas out there? |
| Geordie Lass Join Date: Oct 2005 Location: in the ceiling watching you.....
| Can’t help you on that one I’m afraid, but hello and welcome to Briskoda ![]() |
| volatge regulator problem, it's part of the alternator |
| Just throw another alternator on. Its a 5 min job and £10 from the scrappies.Hope that helps |
| Thanks for the tip! I have picked up another Favorit for fifty quid of the same model and have swapped the alternator over; problem solved! Now my reversing lights have stopped working and will check out the fuse box like the other guy is doing! |
