This is a discussion on Favorit 92 within the RWD Skodas and others forums, part of the Skoda Model Discussion Area category; HELP SOMEONE PLEASE INDICATOR PROBLEMS!!! CAN SOMEONE TELL ME WHAT WIRES NEED TO BE IN WHAT ORDER ON THE LEFT ...
| Briskodian Join Date: Jan 2008
| HELP SOMEONE PLEASE ![]() INDICATOR PROBLEMS!!! CAN SOMEONE TELL ME WHAT WIRES NEED TO BE IN WHAT ORDER ON THE LEFT HAND INDICATOR ......... THERE IS A CONNECTOR ON TOP AND UNDERNEATH WITH THE FOLLOWING CODES. 1 56A / 58 / H / BAT / L 2 56B / 30 / 56 / P / 49A ON MY UNDERSTANDING COLOUR OF WIRES FROM LEFT TO RIGHT ARE ON PLUG 2 IS YELLOW/ BLACK/BLUE-YELLOW/GREEN/YELLOW PLUG 1 IS 2 YELLOW/ - / BLACK/ - /YELLOW IF SOMEONE CAN HELP I WOULD APPRECIATE IT! THANKS CHELLE |
| Briskodian Join Date: Jan 2007 Location: Leeds
| Caps ![]() According to my diagrams in Haynes manual 56b - 2/5 - black 56a - 1/1 - Yellow 30 - 2/4 - black 56 2/3 - a blue wire and a yellow wire (yellow is for rear foglight switch). Those connectors are for the high/low beam and flash. The other connector should have... 1/3 - black wire for horn 1/5 - Yellow wire for left hand signal one wire leading to dashboard, one to the lights themselves 2/2 - Green wire for right hand signal, again wire for dash and lights themselves 49a - 2/1 Yellow - this is the wire the switch connects the left or right wires to for the signal. It leads to the "Z" connector on the flasher relay attatched behind the coin tray. If after checking the wiring you're still having problems, it is pretty easy to open up the switch to see if the connectors mate properly when in the "indicating" position. It's just the two screws at the front. It is possible this switch is broken. It is also possible something is wrong with the flasher relay, but this would affect the hazards too. |
