This is a discussion on Favorit exhaust leak woes within the RWD Skodas and others forums, part of the Skoda Model Discussion Area category; Hi Earlier in the week by Favorit started leaking on the join between the exhaust manifold and the downpipe. I ...
| Briskodian | Favorit exhaust leak woes Hi Earlier in the week by Favorit started leaking on the join between the exhaust manifold and the downpipe. I relpaced the gasket today, an tightened all the nuts as much as they would do up, but it is still leaking on the right side. Should I have used assembly paste? As I just used the bare gasket, believing that it should compress to create a gas tight seal. The car is fuel injection, so obviously I don't want to get any sealant on the lambda, but at the same point as the leak is pre lambda I guess that excess oxygen will be drawn in and give the lambda a false reading. I have not checked to see if the manifold is cracked, because the heat shield bolts look very fragile, so I didn't want to remove them unneccessarily. Do these crack often? Has anyone else experienced similar to this, and if so, how do you cure the problem? Thanks Drew |
| Briskodian Join Date: Dec 2005 Location: Sawston, Cambridgeshire
Members Car: SKODA RAPID 136 Thanks: 20
| Re: Favorit exhaust leak woes Check that ALL traces of the old gasket is removed.
__________________ David McKinney TREASURER OF SKODA OWNERS CLUB GREAT BRITAIN www.skoda-owners-club.org.uk |
| The Following User Says Thank You to daverapid For This Useful Post: | drew_d (04-11-2007) |
| Briskodian | Re: Favorit exhaust leak woes Thanks Dave, will do. The downpipe was fine, but its hard to see the manifold side with the manifold bolted to the engine. |
| Re: Favorit exhaust leak woes No probs, please let us know how it goes.
| Briskodian | Re: Favorit exhaust leak woes Time for an update. I finally got this sorted out. I coulld feel exhaust gasses escaping from the join between the manifold and the downpipe, so I assumed it was the gasket. I changed that, but there was still a leak, which was getting worse, and causing the car to run really bad, as the leak was before the lambda probe. Anyway, it turns put the downpipe was leaking on the weld where the flange joins the pipe. I fixed this over the weekend, and now the car is running fine. Thanks for the help again Dave. |
| Re: Favorit exhaust leak woes Great news, any time.
| Briskodian | Re: Favorit exhaust leak woes glad you got it sorted. I think i had similar a while back and ended up replacing the bolts with non sleeved ones to allow the joint to be tightened up more. |
| | #8 | |
| Briskodian Join Date: Dec 2007 Location: Bristol
Members Car: Skoda Favorit Foreman GLXI Thanks: 1
| Re: Favorit exhaust leak woes Quote:
regards Marcus
__________________ Skoda Favorit Forman GLXi 56bhp Vauxhall Carlton 2.6 Diplomat 150bp Citroen Xantia 2.0i Turbo Activa 170bhp at 1bar approx Nissan 300zx TT 380bhp at 1.2bar approx | |
| | #9 | |
| Briskodian Join Date: Nov 2007 Location: Behind the wheel of a small automobile somewhere in the East Midlands
Members Car: 1.3 spi 95 Felicia glxi 136B SPi Thanks: 67
The two bolts that maintain the clamp from downpipe to catalytic converter with the springs look like 50mm M8 course threaded bolts and the shoulders are there probably to prevent overtightening which would transfer too much stress & vibration to the cat. If that joint is leaking, replace the gasket and springs before attempting to tighten it physically ![]()
__________________ Yam FS1E, Yam RD 200, ancient Mk 1 Mini 850, Ford Zephyr, Mint Mk1 Cortina 1500 Super, 1500 FD Victor o/d, Triumph Toledo, 1800 Marina deluxe, 2.0 Montego estate, Datsun Sunny 120, Mazda 626, two 1300 Astra estates, Mk 2 1050 Polo - all gone to meet their maker. Piaggio Sfera, 95 Felicia 1.3 GLXi SPi. 136B (I think that's lt ) | |
| | #10 | |
| | #11 | ||
__________________ Yam FS1E, Yam RD 200, ancient Mk 1 Mini 850, Ford Zephyr, Mint Mk1 Cortina 1500 Super, 1500 FD Victor o/d, Triumph Toledo, 1800 Marina deluxe, 2.0 Montego estate, Datsun Sunny 120, Mazda 626, two 1300 Astra estates, Mk 2 1050 Polo - all gone to meet their maker. Piaggio Sfera, 95 Felicia 1.3 GLXi SPi. 136B (I think that's lt ) | ||
| Wireless Woes | DaveI | The Tech Shed | 9 | 09-01-2007 22:53 |
| HU Woes | TaXiMaN1972 | ICE, Security and Insurance | 0 | 23-12-2005 06:34 |
| Help! PC woes! | LXI | The Roadside Hotel | 16 | 11-10-2004 14:37 |
| Favorit (and Felicia, Fabia?) heater valve leak fix. | JimFord | Maintenance & Performance | 1 | 07-12-2002 21:46 |
