Favorit GLXIe Handbrake light stopped working.
This is a discussion on Favorit GLXIe Handbrake light stopped working. within the RWD Skodas and others forums, part of the Skoda Model Discussion Area category; I recently acquired a Favorit GLXIe estate and it is my first car. The handbrake pads (or whatever they are) ...
Old 15-02-2007, 19:33   #1
anewman's Avatar
Default Favorit GLXIe Handbrake light stopped working.
The handbrake pads (or whatever they are) were recently been replaced. Unfortunately today I reversed with the handbrake on (ooops) and ever since the handbrake dashboard light has worked intermitently, but more often not working. Is there any quick easy fix to sort the problem out?
Note - I have a Haynes manual to hand.
Thanks in advance.
Alan.
anewman is offline
Old 15-02-2007, 19:36   #2
TeflonTom's Avatar
Default Re: Favorit GLXIe Handbrake light stopped working.
there a switch at the base of the handbrake lever, make sure it is working as it should.... the lever kind of presses onto the switch!
TeflonTom is offline
Old 15-02-2007, 19:42   #3
stopan1j's Avatar
The early Favorits had a rather basic switch / contact assembly on the handbrake lever IIRC, any play in the pivot of the handbrake assembly used to cause this kind of problem - thats what I found anyway on the ones I had. I would not think it was caused by the driving with it on, they would have been rear shoes that were changed. The mechanic would have adjusted the cables on the lever so could have distrurbed the switch operation. The switch is easily made visible IIRC so should be obvious to a someone mechanically / electrically minded
stopan1j is offline
Old 18-02-2007, 00:52   #4
anewman's Avatar
Thanks very much guys, found the switch easily. Handbrake gaiter very easily pulls back making the button easily visible. A few depresses and a wiggle and all is back to perfect working condition
anewman is offline
