39,457 Members 1,489,948 Posts
Favorit Immobiliser
This is a discussion on Favorit Immobiliser within the RWD Skodas and others forums, part of the Skoda Model Discussion Area category; Help. Have a Favorit Estate 1995 Glxie and am having trouble with the immobiliser and need to bypass it. I ...
Old 26-11-2007, 10:30   #1
Members Car: 1995 favorit
Favorit Immobiliser
Help. Have a Favorit Estate 1995 Glxie and am having trouble with the immobiliser and need to bypass it. I have found the immobiliser box and it has a lot of black wires coming out of it. Does anyone know what I need to do to bypass it.Also when I put the red key in it puts out the light but will still not start.
The Doctor is offline
Old 26-11-2007, 15:49   #2
anewman's Avatar
Images: 1
Re: Favorit Immobiliser
If the key puts the light out, the problem may not be the immobiliser.
94 Favorit GLXIe Estate
Briskoda "Banger" social group
anewman is offline
Old 26-11-2007, 20:46   #3
Members Car:
just to warn you,
I have heard so many bad stories regarding by-passing immobilisers,
good luck i say
daz51 is offline
Old 26-11-2007, 22:27   #4
When the red light is out and I turn the ignition key nothing happens but I still have electic power i.e. the lights,indicators,etc still work. Any thoughts ?
Old 26-11-2007, 23:45   #5
anewman's Avatar
Images: 1
My understanding is that the immobiliser cuts out the starter motor, fuel pump, and ignition (spark).
I think I read somewhere that cutting all the wires successfully disconnects the immobiliser, but I would not want to do it without being 100% certain. Hopefully someone else here knows more than I do will reply.
I have also read somewhere of someone getting RAC to bypass it, so if you had at home cover you could call them out.
It's probably worth checking the fuses behind the ECU under a plastic cover haven't blown, and the starter motor. Also if you can hear the relay behind the ECU click when an attempt is made to start the car, I would imagine this points to the problem not being the immobiliser.
The light going off means the code on the key has been recognised and the car, erm, mobilised.
anewman is offline
The Following User Says Thank You to anewman For This Useful Post:
The Doctor (26-11-2007)
Old 27-11-2007, 14:12   #6
KenONeill's Avatar
Members Car: Octavia TDi110
I'm pretty sure that the immobiliser cuts out the starter and ignition; not sure about the LP fuel pump (if electric).
Also slightly worried by the mention of a "red key", since on some cars this is a master key, and on others it's a "doors only" key, and using it to start the car scrambles the immobiliser!
KenONeill is offline
Old 27-11-2007, 16:47   #7
The red key in question is the one you put into the immobiliser
Old 27-11-2007, 16:55   #8
The red key in question is the one you put in the immobiliser .
Old 28-11-2007, 01:35   #9
anewman's Avatar
Images: 1
I'm not sure it being red is necessarily problematic. Apparently when the previous owner of mine tried to get some new immobiliser keys made (as I understand it after a garage broke the key whilst trying to *turn* it ), the new ones were red. Not sure what happened but I think the garage sent the wrong key so the keys were useless. They were done in a place in Kent but I have no idea if that place still does them, or of their address, or if you can still get them copied anywhere now.
anewman is offline
Old 28-11-2007, 01:36   #10
anewman's Avatar
Images: 1
Just noticed a thread here on the same topic but no solution there yet either.
http://www.briskoda.net/forums/other...bilizer/93812/
anewman is offline
Old 14-12-2007, 10:29   #11
Re: Favorit Ignition System
Have now had a go at the immobiliser and disconected it. Have joined the breaks in the wires together but have a yellow wire left over which went straight into the immobiliser and I have no idea what to do with it . I have traced it and it goes into the engine somewhere. Has anybody any ideas on how to wire the ignition system together.
Similar Threads
Favorit immobiliser nathan1984 RWD Skodas and others 15 13-06-2007 14:41
What immobiliser do i have? Sonic1980 General Car Chat 2 09-02-2006 08:57
immobiliser Daddy2Coull Octavia I 2 14-11-2005 23:33
Immobiliser Geoff Octavia I 7 01-07-2005 12:10
Favorit immobiliser Mattblack Maintenance & Performance 12 28-02-2005 11:37
