This is a discussion on Favorit Tuning within the RWD Skodas and others forums, part of the Skoda Model Discussion Area category; im tuning my favorit and would like some help. Rite now im sourcing two weber dcoe 36mm carbs for intake. ...
| Briskodian Join Date: Jan 2006 Location: St. Andrew, Jamaica
Members Car: 1995 Skoda Favorit comfortline Thanks: 0
| Favorit Tuning im tuning my favorit and would like some help. Rite now im sourcing two weber dcoe 36mm carbs for intake. On the exhaust side i would like to know what size exhaust piping i should use.. i have thought of using a 2.5' downpipe and a high performance muffler. What size exhaust piping do u think i should use? |
Members Car: Fabia 2.0/Felicia Thanks: 48
| Re: Favorit Tuning imho for a 1300cc engine it should be about 2" outside diameter tubing. anything bigger that this could lead to a loss in performance |
Members Car: Octavia TDi110 Thanks: 65
| Re: Favorit Tuning Also, have you thought about a new manifold? If so, do you want a 4 into 1 for best peak power, or a 4-2-1 for better mid-range? |
| Re: Favorit Tuning also i'm glad too see you are trying to find smaller carbs... the smaller carbs will give you better bottom end power, perfect for driving about town |
| Re: Favorit Tuning Thanx. i think i'd prefer a 4-1 setup but i dont kno where to find exhhaust headers for my favorit here in jamaica. i also saw a cold air intake setup for the favorit. would this make any sense? |
| Re: Favorit Tuning I'm completely stuck on where you'd source a new exhaust manifold from (well other than probably Europe someplace). If you're fitting twin Webers you'd not get an off the shelf CAI that would do any good; you'd need to make up a plenum chamber with a CAI inlet. |
| Re: Favorit Tuning i saw one on ebay an it looked real nice. dont know if its any goodd tho. Thanx for the help. do u think i need bigger diametre carbs? |
| Re: Favorit Tuning 36 to 40mm side-drafts sound about right for a 1300 to 1600 engine. You don't want to go too big because that slows the airflow and stops the fuel atomising into and staying properly suspended in the air, which causes problems with slow running and pick-up. If you can borrow a copy, try looking at any of David Vizard's books on tuning a 4-cylinder engine for far more information than I'll ever remember (or indeed try and type on a web forum). |
| Re: Favorit Tuning thanks alot guys. |
| | #10 |
| Re: Favorit Tuning sorry but i've not been on the sight alot because of certain circumstances but i saw the fav orit h model and was wondering if they make body kits like the one seen on the h model. if so where could i get one? |
