This is a discussion on gearbox oil level within the RWD Skodas and others forums, part of the Skoda Model Discussion Area category; Hello ! As ,maybe you allready know, I have a 1992 Favorit and I want to check the level for ...
| Briskodian | Hello ! As ,maybe you allready know, I have a 1992 Favorit and I want to check the level for the gearbox oil and how can I add some extra if needed.Thx very much. ![]() |
| Hardcore Join Date: Feb 2006 Location: Bahrain
Members Car: Fabia vRS Thanks: 200
| Re: gearbox oil level IIRC gearboxes have a screw on the side that is opened and oil is filled until it starts to come out of this hole, indicating it's full. Not something you usually check or change unless IN a major service. Better ask a real mechanic IMHO Cheers! bAS
__________________ Fab vRS - Black Magic - PD160 intake - Forge FMIC - colour coded front grille -SLC Splitter - K&N Airfilter -SEAT Strutbrace - Jabba ARB - IC Waterspray (need to wire it in!) - 312mm TT brakes - Eibach Springs - Skoda Reversing sensors - Devonutopia Tuning (tm) Custom Exhaust (2 1/4" straight pipe) - Short shifter mod- 5 brake light mod - Helix Steel SMF + Organic Clutch + pressure plate - Peloquin LSD - TD stage 2 Hybrid - Washbrook remapped ECU - Uprated injectors - Cupra bushes -Poly-filled dogbone - Allard racepipe - Pirelli Dragons - Forge Rear Strutbrace - DIY SS upper boostpipe delete -Koni FSD's - elephant pipe CCV mod |
| Briskodian Join Date: Feb 2006 Location: manchester
| Re: gearbox oil level Look at the back of the gearbox from the top where the speedo drive is bolted.Remove 9mm bolt and remove speedo drive (you can leave the cable connected).Looking down the hole,you can see a ledge,the level of oil need to just cover that.Make sure the car is level of course ! |
