handbrake warning switch on estelles?
This is a discussion on handbrake warning switch on estelles? within the RWD Skodas and others forums, part of the Skoda Model Discussion Area category; My handbrake warning light refuses to go out and I cant find the switch. Its not covered in the manual, ...
Old 31-05-2007, 11:26   #1
Question handbrake warning switch on estelles?
My handbrake warning light refuses to go out and I cant find the switch. Its not covered in the manual, does anyone know..............??
Barclay120 is offline
Old 31-05-2007, 12:54   #2
KenONeill's Avatar
Default Re: handbrake warning switch on estelles?
Dunno about the Estelle, but on anything else I've worked on that had one, it was beside the lever someplace, and should be obvious when you take the cover off.
KenONeill is offline
Old 31-05-2007, 20:37   #3
anewman's Avatar
On the favorit it is directly under the handbrake. Removing the cover (easy to do on the favorit) made the button easily obvious. Check the handbrake mechanism and see if it hits the button correctly. If it doesn't I assume you have to adjust the handbrake, or may get away with tightening the side it needs to go to a little and loosening the other side a little.
If the handbrake does hit the switch try depressing the button firmly a few times and see what happens.
anewman is offline
Old 01-06-2007, 08:59   #4
KenONeill's Avatar
It was pretty much where I expected!
If adjusting the switch position wrt the lever doesn't work, try spraying an electrical contact cleaner into the switch.
Old 18-06-2007, 13:40   #5
on the estelle it is a general brake warning light not specifically a handbrake light the switch is above the pedal, if you tace a look whilst operating the pedal by hand you will see part of the pedal lifting a vertical bar which operates the switch simply push this up you should hear a click as it relocates
it is there to tell you your brake fluid is low and allowing too much pedal travel so if you havent worked on the brakes recently its probaly telling you that you need to
hope this helps
Dave
coupeman is offline
The Following User Says Thank You to coupeman For This Useful Post:
KenONeill (18-06-2007)
Old 18-06-2007, 14:52   #6
KenONeill's Avatar
I'd presumed the owner would know the difference between a h/b warning and a low fluid level one!
Old 26-06-2007, 13:42   #7
many owners assume its a handbrake warning because of the symbol by the light, i guess most cars do have both but unless someone has fitted one themselves this car should only have the fluid light, and it is common to forget to reset the switch after working on the brakes
coupeman is offline
