This is a discussion on Headlight alignment within the RWD Skodas and others forums, part of the Skoda Model Discussion Area category; this seems rather strange, but in the haynes manual it shows there's a vertical adjustment screw at the bottom of ...
| Briskodian Join Date: Apr 2008 Location: Manchester
Members Car: Rapid 136... in bright yellow Thanks: 2
| Headlight alignment this seems rather strange, but in the haynes manual it shows there's a vertical adjustment screw at the bottom of the lighs... my car doesn't have this, just two alignment screws on either side of the lamp... drivers sized one is seized to buggery as well ... |
Members Car: Octavia TDi110 Thanks: 65
| Re: Headlight alignment Haynes' diagram is inaccurate; adjusters are normally top and inside (middle of car) of each lamp. The screw at the bottom is the 3rd mounting. |
| Briskodian Join Date: Sep 2005 Location: Hemel Hempstead
Members Car: Fabia vRS and Estelle 105 Thanks: 29
| Re: Headlight alignment Adjustment screws are steel screw into nylon. They do seize up, and with some penetrating spray they will work loose (make sure you don't damage the screw head). Now, you can make small adjustments yourself, BUT there is no direct height adjuster screw - the light goes up and diagonal with one and up and across with the other. It is a matter of working all the screws to get the beam where you want it - not easy. MOT test stations have beam checkers and they may well do it free if you ask nicely I struggled with mine for 20 minutes and got the heights perfect - except they were then too much to the left. Doh! Ian |
| Re: Headlight alignment oh well, the drivers side is seized and the screw head is well and truly knackered, gonna have to get the light out and do some writhing with a big set of pliers I think... ![]() |
| Headlight re-alignment after fitting new bulbs? | ultra_joel88 | Fabia I | 14 | 07-08-2007 23:26 |
| Headlight Alignment (Halogen) | QuattroGmBh | Fabia I | 2 | 03-06-2005 13:43 |
| Lowering & headlight alignment | Jon TDI | Fabia I | 5 | 16-03-2005 10:54 |
| Sticky headlight levelling on one headlight | mannyo | Maintenance & Performance | 1 | 20-01-2005 22:14 |
