This is a discussion on hello all within the RWD Skodas and others forums, part of the Skoda Model Discussion Area category; hello i have just joined the site after a years worth of estelle ownership and can honestly say it is ...
| Briskodian Join Date: Jul 2008 Location: durham
| hello i have just joined the site after a years worth of estelle ownership and can honestly say it is the best car i have had (responsive steering ,sideways handling even in the dry ,rally heritage)what more could i want ..........maybe better gearchange and another gear, higher diff ratio, new sills, rear seats but even so those issues arent a problem really (i met rob norman just when i was thinking off buying a rover p6b and his enthusiasm rubbed off on me so i decide to keep the est) its not standard because it came with a 105 engine then i went for a 2001 felicia unit after it wore out but now its rather quick but undergeared ,still hit 100 mph @ 6100rpm/110 on the clock (on the race track) tried to add pics (not that great on pcs) the sill pics were from yesterday now it is welded ,is that a common issue as nowhere else on the car has rusted so bad ..........well the inner wings did but i sorted that last year |
| Briskodian Join Date: Apr 2008 Location: Manchester
| looks good, whats the exhaust you got on there? |
| Briskodian Join Date: Dec 2005 Location: Sawston, Cambridgeshire
| Yeah, rust problems there are common.What have you done regarding fitting a spigot bearing to your Felicia engine?
__________________ David McKinney TREASURER OF SKODA OWNERS CLUB GREAT BRITAIN www.skoda-owners-club.org.uk |
| hi the exhuast is a volvo 340 backbox welded to 1.75"pipe and a felicia downpipe (it is restrictive at high revs though due to the huge dent it needed to clear the engine mount.......but cost £5 it is only slightly quicker than rob normans 136 even with a 32/36 carb so a bit of tuning is needed (not to much though as 85 bhp possibly more would give plenty off thrust) would a 1400 fabia 8v fit in the same way (i just swopped the flywheel hub with the 105 motors spigot bearing .......amazing the interchangability between models) i have a complete but stripped 105 motor that i dont need anymore (70s vintage) maybe someone could make use of a free motor |
| Stock exhaust manifold? |
| doesn't look like a rapid one... |
| It doesn't look like the "system" I've seen for a 130 either, which was a straight pipe down from the manifold to the top of the silencer box, and tailpipe out the back end. |
| Briskodian Join Date: Jul 2006 Location: South Birmingham
| Welcome to the forum
__________________ Support Briskoda----------------------> ![]() Red Skoda Octavia V//RS Mods to date: Carbonio CAI Forge 007 DV Aero Wipers Briskoda Stickers KVW100 GB Wheel Inserts RS Tuning Remap Delocked Piper Cat Back Kenwood KDC-W6541U Fli Twin 12" Active Sub Parrot CK3100 ------------------------------------------------ ![]() |
| thanks for the welcome i am looking to buy a 136 rapid manifold just so i can fit something a bit better ;whats the ashley system like in normal useage |
| | #10 |
| Loud ... |
| | #11 |
| oooooh i want one (if it makes race tuned noises rather than loud drumming from the back panel like i get now) |
| | #12 |
| sounds really good... MOT place I went to wouldn't beleive it was still only the 1300 in there until they actually saw it due to the noise... |
| | #13 |
| it would go well with my solex twin carb setup i made a while back (ran ok too considering it had 4 huge venturis feeding it and no rejetting whatsoever from stock) your rapid looks pretty awesome |
| | #14 |
| Briskodian Join Date: Sep 2004
| welcome to brisky
__________________ Daily drive; Octy II 2.0 (?Turbo?)DI ![]() Plus some stuff in the RWD section. Next trip from Scunthorpe & Doncaster clicky http://briskoda.net/midlands-skoda-m...26-oct/125071/ |
