This is a discussion on Help with Favorit project within the RWD Skodas and others forums, part of the Skoda Model Discussion Area category; hi. ive not been postin on the site in quite a while because i was really busy with school and ...
| Briskodian Join Date: Jan 2006 Location: St. Andrew, Jamaica
Members Car: 1995 Skoda Favorit comfortline Thanks: 0
| Help with Favorit project hi. ive not been postin on the site in quite a while because i was really busy with school and all o that. i remembered askin about the tuning aspects of the favorit engine. i realized that here in jamaica we dont have many resources for skoda tuning so i wantedd to know ur opinions. i want to make my skoda fast because rite now i cant compete with any car on the road here in jamaica. i want it to be peppy and more fun to drive. i was thinking of doin an engine swap. i was thinkin of goin either 4efte, 1600 vw engine, 4age, or even a honda engine. i need some hp. im in desperate need of help. do u have any suggestions in terms of the engine i could use or the tuning that could be done to the skoda engine. |
Members Car: Fabia 2.0/Felicia Thanks: 48
| Re: Help With Favrit Project personally i wouldn't bother with trying to fit a honda engine, or either of the toyota engines you mention... fitting the 1600 vw engine is dead easy... all you'd need is the engine moutings from a 1.6 felicia plus a few other bits and it would go straight in |
| Re: Help with Favorit project thanks, Teflon tom. I thought that doing the 1600 vw swap would be the most practical thing to do seeing that the 1600vw engine was in the skoda favorit 1600H. The skoda favorit H produced about 175hp. Thats the kinda power i want from my favorit but i dont think i want to go N/A tuning cuz its expensive. i want to go turbo. i've been searching for the engine an i wanted to know if the 1600 engine from a 1994 vw bug will work. and if it would be wise to use mt current favorit gearbox, if it could work with the engine. And by the way, would this swap require a lot of modifications to the engine bay of my car? |
| Briskodian | Re: Help with Favorit project is it just straight line traffic light grand prix stuff you are talking about? The little favorits and felicias are more than capable cars with the original 1300 engine tuned as long as they are given the right suspension and tyres and corners though which to compete. Theres a reason the skoda favorit on a 1300 breathing through carbs was able to win the world 2litre cup outright, The cars secret weapon is its handling and its bulletproofness. However off from the lights the favorit wont be so good, but through corners even in stock form they can surprise people in the right hands .People have turbo'd the 1300 favorit lump using a renault 5 carb and turbo I believe. If you have a 135 instead of 136 engine they already have quite a low compression ratio which you can play around with. |
| | #5 | |
| Re: Help with Favorit project Quote:
whatever engine you fit, if it wasn't originally fitted to a fav/fel then it would require modifications tothe engine bay | |
| | #6 | |||
| Briskodian | Re: Help with Favorit project Wouldnt be able to offer mcuh help on drag racing the favorits, off the lights really isnt their natural strengths. Any engine swap will require major amounts of cutting and welding EVEN going to the VW 1600 The favorit and late felicia had different front subframes which are not interchangeable, the engine and gearbox mounts within the engine bay were altered a few times over the years, the inner wing design is very different between favorits and late felicias. The VW1600 will be one of the easier transplants to make being as it will physically fit, and willcome with an adapter plate to make the engine fit the skoda gearbox, this same adapter plate can be used tomake most of the VW range of engines fit the favorit gearbox. This adapter plate can be used to make the 1.8Turbo engine fit, the VR6 engine etc etc, but those would require far more working out to get under the hood. Fortunately the favorit has a large engine bay for its size. Its also worth noting that the favorit shell is very flexible, and if you want the car to stay around for a decent amount of time, you will need to reinforce the shell some seam welding and a roll cage would probably help keep the shell straight for enthusiastic use with large amounts of horse power. One of my friends who was rallying skodas before I got into them had the plans worked out to fit theold vauxhall 2ltr 16v engine to the favorit and reckoned it would fit. (but again an engine swap takes more effort than you might think). Ive been involded in many engine swaps and few of them are as simple as drop it in and it all bolts up . Even swapping engines from the same manufaturer, I remember replaceing a CVH with a pinto engine, in a car, it started out as being just a set of engine mounts need fabricating, and a cut and shut on the exhaust... 6 months later it was running with a completely fabricated exhaust manifold, downpipe and system re routed steering rack, repositioned battery, new fuel line setup new fuel pump, etc etc and more delays and small engineering challenges than I care to remember.Even the old 2litre pinto to replace the 1.6x/flow in a old escort was never as easy as just "dropping it in" and thats one of the most common engine swaps ever done. There is NO such thing as CHEAP speed, its all going to be hard work and space and you need to be sure you can put the work in to fuel your hobby, you can do it all yourself if you are prepared to take the time and effort and advice from people near to you who have done a few engine swaps. There is even more hassle than you would think swapping over the 135 favorit engine for the 1.4 fabia version of the same engine!! When you are planning an engine swap on a car work itall out get your diagrams and measurements together start costing up the parts you are going to need including postage etc, price up any labour on parts you wont be able to do yourself, price up the engine and any new ancillaries you think you are going to need, make sure you consider issues like flywheels and clutches, once youve got a figure you probably wont be tooput off but now 4x it if you havent done the job many times before if youve done a few engine swaps double it .I still work things out in advance and still know its going to cost over double what I first think. |
| | #8 | |
and the vr6 has a totally unique bellhouse which wont interchange.... you would need to use the vr6/v5 gearbox | |
| Re: Help with Favorit project well i dont think im goin to be goin 1.8t anytime soon. i think i'll jus have to stick with the favorit engine. since i cant go for a drag car, it might jus be practical to make te car more fun to drive. im thinkin of turbocharging it. i think the renault 5 gtt uses a solex carb. saw it for sale on an english site for 200 pounds. need to find a cheaper price. an if i run a turbo setup with stock internals, how much psi should i run it on and about how much horse power will the engine make? would i have to get upgraded clutch, pressure plate ..etc..? |
| | #10 |
| Re: Help with Favorit project i thought the r5 turbo had renix fuel injection?? the early gordini r5 turbo has a webber 32/34 carb |
| | #11 |
| Briskodian | Re: Help with Favorit project I think it was a Solex 32 DIS used on the renault 5 GT turbos, wouldnt swear to it though, it wasnt me who did the conversion but a friend who did it to a rapid, with some interesting results .As for the adapter plates Ive seen photos of the 1.8t in a rapid and vr6 in a favorit, and was told they used the1600 adapter plate. Ive never done the conversion or even owned a vw engined skoda though. I wasnt aware VW used so many bell housing stud layouts, more used to skoda and ford where they use pretty much one bolt layout for years and years. |
| | #12 |
| Re: Help with Favorit project i'm still undecided to whether i should go turbo or not. what are all the things i would need if i were to go turbo? |
| | #13 |
| Re: Help with Favorit project i have fully decided o go turbo. its easier to get power out of it and i love the sound off a blow off valve. i was wondering if anyone could help me with a few things. so wat i need: garret t25 turbo solex 32 carb custom headers oil cooler blow off valve wastegate intercooler and piping 2 inch exaust boost controller boost gauge turbo timer did i leave out anything? |
| | #14 |
Members Car: Octavia TDi110 Thanks: 65
| Re: Help with Favorit project Just answering a couple of points:_ 1) Yes the old flat 4 reversed would give you multiple reverses, but it's one of the few transaxles where you can reverse the diff by moving the crownwheel, so that's not a major issue. 2) The R5 Alpine/Gordini (depending on market) Turbo used a carb, but the "SuperCinq" Turbo had fuel injection. 3) If you can afford it, I'd go with fuel injection rather than a carb with a turbo project. There's not much point in buying a boost controller unless you have a fuellie, because you'll have no control of the fueling with a carbie engine. 4) Save money on the turbo timer; just idle the engine for a couple of minutes before switching off, which is basically all a good timer like a GReddy one does. The bad ones are basically just stopwatches! |
| | #15 | ||
i had a gordini for a while... loved it, miss it, wish i hadn't got rid of it.. but it is difficult getting spare parts for them.. Quote:
)...the most important thing would be getting the ignition timing right. you would need to retard the ignition timing because of the extra heat inside the combustion chambers also running at pressure you need to lower the compression ratio of the engine. fabricating an exhaust manifold/header is fairly easy. but you need to fabricate a custom downpipe as well to match it all up to the exhaust system | ||
