This is a discussion on Help required on discontinued part! within the RWD Skodas and others forums, part of the Skoda Model Discussion Area category; Can anyone help me try and find a brake fluid cap and sender unit for a 1992 favorit ..... this ...
| Briskodian Join Date: Jan 2008
| Can anyone help me try and find a brake fluid cap and sender unit for a 1992 favorit ..... this is a discontinued part and they scrap yards in Liverpool arent interested in helping you as soon as you say skoda!!!! ![]() Can anyone help please ?? Chelle |
| is hating life! Join Date: Aug 2007 Location: Dont Know, Dont Care
| Fuel sender?
__________________ Id rather be a nobody than an overated someone... |
| Briskodian Join Date: Jan 2007 Location: Leeds
| Do you mean sender unit as in the brake fluid low level warning switch? Or the brake fluid reservoir itself? I suppose you could risk it without a level warning light if you keep an eye on the level regularly and ensure the brake pipes are in perfect condition. You then only need to worry about the cylinders. Hopefully this is the sort of thing someone will have somewhere anyway. You may also like to try the site www.SKODA FORUM.com™ - The International Skoda Community Forum too in the wanted section ![]() Suprised scrappies ain't interested, these Skoda's are easy cars to take bits off. |
| Just to add, having looked at the parts lists, the brake fluid container, the level switch and cap seem to have the same part numbers as the later favorits. I *think* part number 115 595 481 is what you would need from the dealers. Should be under £10 and still available but would probably be special order. I would check first that they will let you return for a refund if it isn't the required part if you go that route. Another route to try is Jorily Skoda on ebay eBay UK Shop - Jorily Skoda: Estelle Rapid, Favorit, Felicia contact him and he should be able to help out with what you need as he seems to be able to get everything . |
| Site Sponsor Join Date: Mar 2006
| You could always try Butts Of Bawtry They do old parts too I hope you get sorted Sarah |
| Briskodian Join Date: Nov 2005 Location: N.I.
| butts are good for body parts but they only do one shipment a month so small, older parts are a disaster, and thats where Graham/Jorily comes in. give him an email lass and I'm sure he'll get you sorted asap ![]() |
| Briskodian Join Date: Dec 2007 Location: SE London
| Isn't that pretty much the same part that's on practically _any_ European car? I'd be surprised if you couldn't find one in a scrappy that would fit. The level warning almost never works and if you know what's good for you you'll be checking the level weekly along with oil, coolant and fan belt condition, so all you need is something that screws on and stops brake fluid sloshing all over the world when you corner hard. |
| The fact that none of the supplied caps with the Gunson Eezibleed fit the Favorit reservoir suggests to me that they are unique to Skoda unfortunately. |
| Butts have now stopped supporting old Skoda's. I would ask Jorily on E-Bay as he is an excellent source of spares. Hope that helps. |
| | #10 |
| Briskodian Join Date: Jan 2007 Location: Peterborough
| Another Skoda specialist with over 20 years experience is Chris Pepper Motor Services, (CPMS).His ebay name is boroskoda and he has a massive stock of spares for Skodas from the 60's to the present.He bought all of S4 imports stock.01733 324251 is the number to get him on.He's an ex-dealer mechanic too who also services/repairs any skoda. |
| | #11 |
| Briskodian Join Date: Sep 2006
| Yes, Jorily Skoda can get almost anything you need |
