39,457 Members 1,489,949 Posts
How common are flywheel oil seal leaks?!
This is a discussion on How common are flywheel oil seal leaks?! within the RWD Skodas and others forums, part of the Skoda Model Discussion Area category; I have a leak which appears to be coming from between the engine and the clutch housing, at least it ...
Old 03-10-2007, 20:39   #1
anewman's Avatar
Images: 1
I have a leak which appears to be coming from between the engine and the clutch housing, at least it is dripping from there. The oil switch, filter, sump plug, camshaft cover. fuel pump blanking plate are all dry.
I have smelled the oil and it doesn't appear to be transmission oil (no foul smell).
If the flywheel oil seal is my best bet, how much would a rough ball park figure be for a garage to replace the seal? (I don't fancy the job myself.)
Thanks in advance.
94 Favorit GLXIe Estate
Briskoda "Banger" social group
anewman is offline
Old 03-10-2007, 21:09   #2
ECUless
fordfan's Avatar
Members Car:
Re: How common are flywheel oil seal leaks?!
Labour wil be the main cost, in the region of 3 hours. I can't see the seal been more than £15, gearbox oil around £10, but you may want to consider renewing the clutch (kit around £70) as it all has to come out to replace the seal.
fordfan is online now
The Following User Says Thank You to fordfan For This Useful Post:
anewman (03-10-2007)
Old 03-10-2007, 21:35   #3
anewman's Avatar
Images: 1
Ouch on the 3 hours. Will have to give the underside a good scrub up to see exactly where the oil does come from. From experience it's often difficult to tell without a good clean up as the oil tends to move around.
anewman is offline
Old 03-10-2007, 21:43   #4
rigsby's Avatar
cheap tray from poundstretcher £1.99 to put on the drive plus a top up now and then. a lot cheaper than repair and blow back of oil stops floorpan rusting
I DONT WANT TO DIE A GROWN UP!
rigsby is offline
The Following User Says Thank You to rigsby For This Useful Post:
Old 03-10-2007, 21:49   #5
anewman's Avatar
Images: 1
Well I don't have a drive so it leaks onto the road. Lol. Will double check source of leak and ring around for cheapest price. I really couldn't afford anything above £100 which with 3 hours it sounds like it would be.
I have put wynn's engine stop leak in there twice. Once before oil change and once after changing the oil. I wonder if that could have caused the damage or if another can could help stop the leak.
anewman is offline
Old 03-10-2007, 21:49   #6
daverapid's Avatar
Members Car: SKODA RAPID 136
You'd have to go some to replace a rear crank seal in 3 hours even in a workshop with the car on a ramp. I reckon 4 or 5 hours is more realistic.
David McKinney
TREASURER OF SKODA OWNERS CLUB GREAT BRITAIN
www.skoda-owners-club.org.uk
daverapid is offline
The Following User Says Thank You to daverapid For This Useful Post:
Old 03-10-2007, 22:00   #7
rigsby's Avatar
sod the tray if its on the road , just top it up!!!
rigsby is offline
Old 03-10-2007, 22:05   #8
daverapid's Avatar
Put the tray under the car at night, and in the morning pour the oil back in the engine!
David McKinney
Old 03-10-2007, 22:11   #9
anewman's Avatar
Images: 1
Not sure I like the idea of that lol. Looks like Asda smart price 20/50w 5 litre cans it is. Lol. Hopefully it will remain a smallish trickle and won't foul the clutch mechanism.
anewman is offline
Old 04-10-2007, 21:38   #10
rigsby's Avatar
my rapid (same engine) leaked for the 3 years i had it, and i never got round to fixing it
rigsby is offline
anewman (04-10-2007)
Old 04-10-2007, 22:00   #11
anewman's Avatar
Images: 1
The annoying thing is I only just fixed a leak from the fuel pump blanking plate, and this leak looks like it won't be cheaply/easily fixable. Was possibly that leak stopping the other happening or something. Oh well.
You've given me some hope for the likely longevity of the car was starting to consider the possibility of having to get another car possibly within the year. When the time comes I would probably be looking at getting another Favorit or a Felicia anyway, leaving this one on bricks ready to be collected by a scrappie.
anewman is offline
Old 31-03-2008, 16:29   #12
stevejwest's Avatar
I havnt found an engine with a few miles on it in ANYTHING that doent leak a bit!
As long as you keep a bit of oil in it!
I have found that keeping the oil about halfway between the marks reduces the leaks - if its low you risk engine damage - if its high it just leaks out!
The Wynns Stopleak shouldnt damage the engine but dont go outside their recomendations. Wynns have a really good technical team you can ask this sort of question on though.
Rapid 136 (blue ish) with no interior, LPG system, Rover 200 Part leather seats, 4points, N2hohoho and a turbo
Octy2 2.0 vRS tdi Combi in Blue
RIP octy 130PD combi in Silver sadly missed but never forgotten - why oh why did I sell you?
stevejwest is offline
Old 31-03-2008, 22:38   #13
A word of warning re. any of the stop leak products!!
These stop the leak by reacting with and swelling up your rubber seals, this works initially, but will drastically reduce the life of all your rubber engine seals, as they will wear prematurely after treatment, so you fix your main oil seal for maybe 10K or so, but then all your seals will start weeping!!
Personally, I'd live with the leak or fix it, but woulldn't use stop leak products if you plan to keep the car and do any significant mileage
favguy is offline
The Following User Says Thank You to favguy For This Useful Post:
anewman (31-03-2008)
Similar Threads
1.3 shift linkage oil seal Rob B Favorit, Felicia, Fun and Forman 3 01-05-2007 18:34
re, leaks Len Superb 9 22-05-2006 14:03
water leaks Len Superb 2 14-04-2006 13:10
Any one had this Oil leak at Gear linkage seal johnmb Octavia I 3 16-02-2006 23:19
Crankshaft oil seal. Common Problem on VRS? Monkey Boy Octavia I 1 20-04-2005 20:31
