39,458 Members 1,489,954 Posts
Humming sound - between 60-80mph
This is a discussion on Humming sound - between 60-80mph within the RWD Skodas and others forums, part of the Skoda Model Discussion Area category; I have just noticed my car has acquired a humming sound that starts to be noticeable at about 60mph, is ...
Old 16-01-2008, 21:28   #1
anewman's Avatar
Images: 1
I have just noticed my car has acquired a humming sound that starts to be noticeable at about 60mph, is at it's most noticeable at about 70/75, and seems to tail off at 80mph. I can't feel any associated vibrations.
The sound is definitely not the engine or road surface. I have checked tyre pressures but that doesn't seem to have helped.
There is a possibility a weight has fallen off my front offside wheel. All tyres were fitted at same place and the other 3 have those weights that clip onto the edge of the rim, whereas this one only seems to have a stick on weight. I can't say I noticed whether it had such a weight before though.
Any suggestions on possibilities? I was going to swap 2 of the wheels and have the alternate ones on the front anyway as 2 seem to lose pressure every-so-often.
94 Favorit GLXIe Estate
Briskoda "Banger" social group
anewman is offline
Old 16-01-2008, 22:43   #2
rigsby's Avatar
Re: Humming sound - between 60-80mph
Sounds like a wheel bearing on its way out. Jack up each wheel and check for play,on the rears spin them as fast as you can and listen for any noise
I DONT WANT TO DIE A GROWN UP!
rigsby is offline
The Following User Says Thank You to rigsby For This Useful Post:
anewman (16-01-2008)
Old 16-01-2008, 23:03   #3
Briskodaholic
Tom_vRS's Avatar
Members Car: '97R BMW 328i Saloon
Could be a slightly distorted tyre too...
97/R BMW 328i in Boston Green.
Tom_vRS is offline
The Following User Says Thank You to Tom_vRS For This Useful Post:
Old 16-01-2008, 23:05   #4
anewman's Avatar
Images: 1
On the front nearside wheel, when it's in first gear, it moves back and forth in the direction of rotation quite a bit very easily. Could it be this one?
Apparently the rear nearside one was replaced due to "excessive roughness" nearly 2 years ago.
I've just swapped the two front wheels anyway (with what I think are the best 2 from my collection of 8 spares) so when I next go out I can see if that's changed anything.
Update: no difference with 2 new wheels at front.
anewman is offline
Old 17-01-2008, 05:44   #5
anewman's Avatar
Images: 1
If excessive play is found, is it worth attempting to adjust them using the Haynes manual method before taking to a garage to replace them? Or does noise = bearing death?
anewman is offline
Old 17-01-2008, 16:43   #6
anewman's Avatar
Images: 1
Just checked. Rear-offside, no play, but scraping sound when spinning. So it seems it is a wheel bearing. Thanks guys.
anewman is offline
Old 18-01-2008, 13:34   #7
KenONeill's Avatar
Members Car: Octavia TDi110
Other prospect is a "funny" tyre, where one wear bar is showing. I've had that happen to me once.
KenONeill is offline
Similar Threads
humming noise from vrs matt@theforce Fabia I 13 14-09-2007 10:40
Vibration at 80mph in 6th? AngryNortherner Fabia I 13 19-08-2005 12:53
RPM at 80mph Trotts Fabia I 4 19-06-2005 09:03
80mph blowout! car 3 weeks old! is this strange???? JdH Fabia I 6 10-01-2005 16:43
