39,457 Members 1,489,949 Posts
Ignition Timing & Points Gap
This is a discussion on Ignition Timing & Points Gap within the RWD Skodas and others forums, part of the Skoda Model Discussion Area category; Not been lucky enough to get a HBOL yet so could do with a little information please. Actually got to ...
Old 22-03-2008, 20:38   #1
Members Car: BugRat #1
Not been lucky enough to get a HBOL yet so could do with a little information please. Actually got to drive today & I know I wasn't expecting lightening performace from the 136 engine but it was rather more sedate than I had presumed. I think it's running rich as the exhaust is quite sooty, but I wanted to start by checking the timing. Can somebody provide me with points gap, static timing, strobe timing, dwell angle & what the marks on the casing represent please.
Cheers
Alan...
Phaeton is offline
Old 22-03-2008, 21:04   #2
daverapid's Avatar
Members Car: SKODA RAPID 136
Re: Ignition Timing & Points Gap
Set the points gap to 0.4mm and the ignition timing to between 3 and 7 degrees before TDC at idle with the vacuum advance pipe disconnected. The 0 on the timing case represents TDC and each mark on the scale is 5 degreees. Best way to set the timing to give optimum performance is to set it at 7 degrees, road test it and if it pinks back it off a little at a time until it doesn't pink. The spark plugs should have a gap of 0.60mm. Shell Optimax, BP Ultimate or equivalent is best, it costs a little more but you get it back in economy and performance. It's very important to set the valve clearances too, if they go tight you'll get sluggish performance, poor starting and ultimately burnt valves.
Is a standard Jikov carb fitted?
No standard rear engined Skoda is fast, but the 136 if set up right is fairly nippy.
David McKinney
TREASURER OF SKODA OWNERS CLUB GREAT BRITAIN
www.skoda-owners-club.org.uk
daverapid is offline
The Following User Says Thank You to daverapid For This Useful Post:
Phaeton (22-03-2008)
Old 22-03-2008, 21:18   #3
Do you have the settings, if the weather isn't shine/rain/sleet/shine/sleet/rain/shine tomorrow I might have a go.
It is at the moment, I would like a Webber, but found nowhere to buy a manifold as yet, also seen posts for an 'Ashley' (is that right) exhaust which looks like a 4 branch which I'd like as well.
Wasn't expecting fast, but I certainly didn't feel nippy, as I said it was more like sedate. However I think I broke a handbrake cable, which means that maybe the rear brakes are binding & it could be the mixture is up the spout.
Alan...
Phaeton is offline
Old 23-03-2008, 00:20   #4
Members Car: 1993 Favorit
Valve clearance 0.2 to 0.25mm.
You broke a handbrake cable? It's a pretty tough cable - it was probably on the verge anyway. More likely that the cable itself was binding than the brakes, though. Give them a quick check (at the very least you'll want to check the condition of the liningon the shoes), it's all easy enough to do.
The 0 degrees timing mark on the case is made explicit - you can see it if you use a torch, clean some muck off, and squint a bit!
Richard Black is offline
Old 23-03-2008, 01:01   #5
I'm saying it's a broken cable, the lever comes all the way up to the stop & the car still rolls. We don't think it did before but we only got it Friday so not sure.
Alan...
Phaeton is offline
Old 29-03-2008, 15:17   #6
Well 1st dry day or at least a couple of hours as it's raining again now, looks like my 'sedate' problem is the carb is only opening one of the chokes, the other appears to be stuck closed. So it looks like ti needs to come off for a good clean.
Alan...
Phaeton is offline
Similar Threads
48 in a 30 = 3 points & £60. Seem fair? devonutopia General Car Chat 74 28-06-2007 17:43
1998 Felicia 1.9D wont start after new glow plugs fitted & timing belt. kerzo102 Favorit, Felicia, Fun and Forman 12 06-03-2007 11:02
Fabia Ignition Timing (or Equivalent) SteVRs Fabia I 13 04-10-2006 22:23
FREE TO GOOD HOME - 1.4 & 1.9pd engine timing kit TeflonTom General Car Chat 5 18-06-2006 23:21
Cam/timing belt & 80k service Jimbo79 Octavia I 11 13-04-2006 19:09
