This is a discussion on Rapide Distributor Change within the RWD Skodas and others forums, part of the Skoda Model Discussion Area category; After doing some poking round, it appears that a Favourit distributor will fit my 1990 136 Rapide engine, getting rid ...
| Briskodian Join Date: Mar 2008 Location: Worksop
| After doing some poking round, it appears that a Favourit distributor will fit my 1990 136 Rapide engine, getting rid of the horrible points. Is there a Howto or guide anywhere that I've missed? Also on Fleecebay there are 2 different ones pre '93 & post '93 am I right to assume I need pre '93. Last question this time honest, do I need anything else as well? Cheers in advance Alan... |
| Briskodian Join Date: Dec 2007 Location: SE London
| It'll certainly fit physically, but you'll also need the little box of electronics that interprets the magnetic pickup signal from the dissie and turns it into sparks. You'd better get the coil off the Fav as well, since the Rapid one is almost certainly substantially different in characteristics. The gubbins is all mounted on the right wing and it's pretty obvious what's what - just follow a few wires! The post-1993 Fav had fuel injection instead of a carb but I would imagine the dissie and associated electronics are not much different - there may be some difference in advance curve. Use an early version setup for preference. |
| The Following User Says Thank You to Richard Black For This Useful Post: | Phaeton (22-03-2008)
| My other alternative I thought of was replacing it with a Megajolt (as I have all the Edis stuff already). But then will need a 36-1 toothed rotor on the crankshaft, is there a ready made option off another engine or am I going to have to get one fabricated which will probably be even more expensive. Alan... |
| | #4 | |
| Quote:
| | #5 | |
| Briskodian Join Date: Dec 2005 Location: Sawston, Cambridgeshire
| Quote:
The distributor body is similar but the associated electronics are totally different. There is an engine management system that controls both the fuel system [SPi] and ignition system, totally different set up to the pre 1993 carb'd Favorit.
__________________ David McKinney TREASURER OF SKODA OWNERS CLUB GREAT BRITAIN www.skoda-owners-club.org.uk | |
| | #6 | |
| Quote:
