This is a discussion on Skoda Favorit GLXi Estate 1.3 1994 light switches within the RWD Skodas and others forums, part of the Skoda Model Discussion Area category; Hi I've been having some problems with in particular the sidelight switch in my Skoda Favorit GLXi Estate 1.3(1994) in ...
| Briskodian | Skoda Favorit GLXi Estate 1.3 1994 light switches Hi I've been having some problems with in particular the sidelight switch in my Skoda Favorit GLXi Estate 1.3(1994) in that it doesn't seem to click into position easily any more.I wonder whether anyone has any idea where I can obtain a replacement switch or the mechanism inside it? Cheers Steve Hughes Monmouth |
| Briskodian Join Date: Feb 2006 Location: manchester
| Re: Skoda Favorit GLXi Estate 1.3 1994 light switches Steve,it seem's the later Mk-2 Fav's switch was made of cheaper plastics when those pesky VW types took over ! The MK-1 had better switches that never failed but had pants interior's ! You local Skoda dealer should be able to sort you out if they can still be bothered with the old stuff OR try Butts of Bawtry,they still supply loads of older skud stuff. |
| Briskodian Join Date: Dec 2005 Location: Sawston, Cambridgeshire
Members Car: SKODA RAPID 136 Thanks: 20
| Re: Skoda Favorit GLXi Estate 1.3 1994 light switches You can take those switches apart and reshape the wire springy bit inside to make it work again......sometimes! Failing that get a new one from Jorrily's ebay shop or Butts.
__________________ David McKinney TREASURER OF SKODA OWNERS CLUB GREAT BRITAIN www.skoda-owners-club.org.uk |
| The Following User Says Thank You to daverapid For This Useful Post: | anewman (07-11-2007) |
| Briskodian | Re: Skoda Favorit GLXi Estate 1.3 1994 light switches Do what i did got a mk1 switch and solder the mk2 wires to it. Sorted! |
| Briskodian Join Date: Jan 2007 Location: Leeds
Members Car: 1994 Skoda Favorit GLXIe Estate Images: 1 Thanks: 1,121
| Re: Skoda Favorit GLXi Estate 1.3 1994 light switches As a quick fix you could just replace the whole panel of switches for a good one. Unscrew, remove, unplug - plug in, replace making sure it's firmly in at the left, screw back in. I wonder if also a MK1 panel would drop in as a direct replacement, although AFAIK would be brown. |
| Briskodian | Re: Skoda Favorit GLXi Estate 1.3 1994 light switches if its a 94 on model! |
| Briskodian | Re: Skoda Favorit GLXi Estate 1.3 1994 light switches when you get the new switch ,don't worry if the multiplug connector is different , just cut the plug off and join the new switch to the wires ,i tried to buy the correct one for my favorit ,even gave the skoda dealer the chassis number ,they still sent me the wrong one ,so i got fed up of waiting and fitted the one they had sent. |
| Briskodian | Re: Skoda Favorit GLXi Estate 1.3 1994 light switches thanks everyone - I bought a whole assembly but in the end just replaced the inner white plastic part in the headlight switch-fantastic! cheers steve |
| Briskodian Join Date: Nov 2007 Location: Behind the wheel of a small automobile somewhere in the East Midlands
Members Car: 1.3 spi 95 Felicia glxi 136B SPi Thanks: 67
| Re: Skoda Favorit GLXi Estate 1.3 1994 light switches The spring locking mechanism on my h/l sw broke, so I pulled the front off and replaced it with a screw. Sadly it failed the MOT on this so I got a replacement from the scrappers. Job done! ![]()
__________________ Yam FS1E, Yam RD 200, ancient Mk 1 Mini 850, Ford Zephyr, Mint Mk1 Cortina 1500 Super, 1500 FD Victor o/d, Triumph Toledo, 1800 Marina deluxe, 2.0 Montego estate, Datsun Sunny 120, Mazda 626, two 1300 Astra estates, Mk 2 1050 Polo - all gone to meet their maker. Piaggio Sfera, 95 Felicia 1.3 GLXi SPi. 136B (I think that's lt ) |
| Parts to pull off a Favorit GLXi estate before it goes to the scrap yard? | anewman | RWD Skodas and others | 16 | 25-08-2007 11:42 |
| felicia 1.3 glxi plus estate | caddy | Favorit, Felicia, Fun and Forman | 0 | 24-05-2006 15:15 |
