Skoda Favorit thermostat
This is a discussion on Skoda Favorit thermostat within the RWD Skodas and others forums, part of the Skoda Model Discussion Area category; Hello ! Do you know at what temp does the termostat opens??I think my termostat opens too soon.Another question : ...
Old 04-12-2006, 07:56   #1
Smile Skoda Favorit thermostat
Hello ! Do you know at what temp does the termostat opens??I think my termostat opens too soon.Another question : on the temp indicator : what temp is showing each icon??
andreiu is offline
Old 04-12-2006, 09:49   #2
Location: Often found behind the wheel of a Pre-VW Skoda.
Default Re: Skoda Favorit termostat
Thermostat should start to open at 86 to 90 c and be fully open at 103c.
Some people fit the estelle thermostats which run a bit cooler, and I believe there are two different thermostat temperatures available for the favorit as well.
As for the temperature scale on the dash Your dash design might be slightly different to uk models, but roughly speaking once warmed up the needle should be sitting near enough halway up the scale, a bit under isnt normally a problem, a bit over during normal running I'd be a bit concerned about. My Injection favorit sits dead on halfway, my carb favorit sits just under.
ugluk is offline
Old 04-12-2006, 12:37   #3
Thx for the answer.How do I know that my engine have 80 grades C ??
andreiu is offline
Old 04-12-2006, 12:55   #4
My termocontact for the radiator fan closes at 92 C and opens at 88 C.
andreiu is offline
Old 04-12-2006, 13:22   #5
I tend to go by feel of heaters and the temperature guage for when a thermostat needs replacing. If things are boiling over too easily the thermostat is probably stuck closed.
If heaters run cold and temperature guage wont warm up then the thermostat is probably sticking open. Ive never used a thermometer to check thermostats. Just have a fair idea of how things should "feel"
Your fan temperatures sound just fine to me, you could take you car for a drive to warm up and then park up with the engine running and see if after a while the cooling fan comes on and check where the temperature guage is sat at the time. on my cars thats normally 3/4 of the way up the guage.
ugluk is offline
Old 04-12-2006, 13:28   #6
I can say that the guage is at the half of the white area when fan comes on .
andreiu is offline
Old 06-12-2006, 09:37   #7
OK checked my spares car that still has a mk1 dash and if your dash looks like that one, Id say your fans are coming on dead right.
(my daily driver has a hybrid mk1 mk 2 dash that I cobbled together)
ugluk is offline
Old 11-12-2006, 11:41   #8
Smile Re: Skoda Favorit termostat
Hello.I have changed my thermostat.I bought one from QH.It opens at 88 C .At last my engine it is warm.I am very happy.
andreiu is offline
Old 11-12-2006, 12:13   #9
Excellent good news.
ugluk is offline
Old 11-12-2006, 16:52   #10
Is there a way of mounting the thermostat ?? Maybe a position??
andreiu is offline
Old 11-12-2006, 21:51   #11
they only work one way round.
ugluk is offline
Old 04-01-2007, 13:31   #12
sainz's Avatar
In Turkey, I use a termostat which opens at 88 degree and I use fan termostat which opens at 92 degree and works untill heat comes 87 degree. If you drive on an open road (I mean road without a traffik jam) your fan will never start because radiator will get enough wind to get cold.
sainz is offline
