This is a discussion on Acid #8 1k Etch Primer for chrome grill within the Styling and Car Care forums, part of the General Motoring Discussions category; has anyone got any thoughts of using this to prime the chrome grill on a mkii ocatavia after its had ...
| Briskodian Join Date: Mar 2004 Location: North Wales
Members Car: Octavia II VRS Estate CR2.0tdi in Race Blue Thanks: 122
| Acid #8 1k Etch Primer for chrome grill has anyone got any thoughts of using this to prime the chrome grill on a mkii ocatavia after its had a light sanding with wet n dry? the link to it is below and its what has been recommended by the technical chaps at painst4u.com. Ive had a go of stripping the chrome with some over cleaner which didnt really work plus i havent got a container big enough to leave the grill in bleach which was suggested on another thread. http://www.paints4u.com/ProductDetai...?productID=296
__________________ 2008 OctyII VRS Estate CR 2.0Tdi Race Blue - 18" Zeniths - Sunset Glass - Maxidot - Dual Zone - Cruise - Jumbo Box/Rear Elec - Rear park - Active headrests - Curtain Airbags - MFD2 & OEM Bluetooth my flickr Photos |
Members Car: Audi S3 Thanks: 145
| Re: Acid #8 1k Etch Primer for chrome grill My Fabia one was just painted over after sanding which seemed ok. I happen to know there is a black one being painted this week and I'm sure the owner will make comment if he sees this. ![]()
__________________ Stu Stu's Websites - http://www.fabia-vrs.com & http://www.octavia-vrs.com Stu's Car - 2008 Audi S3 - Ibis White, Black Optics Pack, Privacy Glass, Auto Bi Xenon Headlights, Rain Sensing Wipers, Bose Sound System, Ipod Prep, GSM Phone Prep, Flat Bottom Multi Function Steering Wheel, Electric Folding Mirrors, Acoustic Parking, Cruise Control, Interior Light Pack, Non Smokers Pack. SWMBO's Car - 2008 Seat LEON TDi Stylance, Black Magic, Sports Pack, Rear Parking Sensors. Something for Weekend - A Patio |
| The Following User Says Thank You to VRStu For This Useful Post: | sworrall (31-07-2007) |
| Re: Acid #8 1k Etch Primer for chrome grill thanks stu, did you get many chip/peel free miles out of it before you changed to the octy
| Re: Acid #8 1k Etch Primer for chrome grill Yeah seemed ok Stu.
| | #5 | |
| Ex-Moddy Join Date: Jul 2005 Location: Hampshire
Members Car: Golf PD105 Thanks: 187
| Re: Acid #8 1k Etch Primer for chrome grill Quote:
, but I got a 'man' to do mine and I have know idea what process he uses but I'll ask when I collect it later this week.Edit: Just rememberd him saying something about sanding it down and using a primer but what type I hav'nt got a clue ![]()
__________________ Superchips Bluefin only £390 @ JKM http://www.jkm.org.uk/performance/bluefinxmas2008.htm | |
| The Following User Says Thank You to Makefish For This Useful Post: | sworrall (31-07-2007) |
| Crossdresser Join Date: Apr 2003 Location: fast lane
Members Car: Citroen C-Crosser 2.2HDI Thanks: 25
| Re: Acid #8 1k Etch Primer for chrome grill I sanded mine down and then painted it first with primer, then with black. Worked fine. |
| The Following User Says Thank You to Quinten For This Useful Post: | sworrall (31-07-2007) |
| Re: Acid #8 1k Etch Primer for chrome grill I probably didn't make my first post that clear. I was primed with normal body painting primer, but not acid etched AFAIK.
| Re: Acid #8 1k Etch Primer for chrome grill its not a great deal dearer than the normal stuff so i may just plump for a tin and try it out.
| Hardcore Join Date: Feb 2006 Location: Bahrain
Members Car: Fabia vRS Thanks: 198
| Re: Acid #8 1k Etch Primer for chrome grill my skoda dealer was told to sand it befor epainting it - he BS'd me that he did and now I have nice chromed stonechips... Will take it off again and get him to repaint it....
__________________ Fab vRS - Black Magic - PD160 intake - Forge FMIC - colour coded front grille -SLC Splitter - K&N Airfilter -SEAT Strutbrace - Jabba ARB - IC Waterspray (need to wire it in!) - 312mm TT brakes - Eibach Springs - Skoda Reversing sensors - Devonutopia Tuning (tm) Custom Exhaust (2 1/4" straight pipe) - Short shifter mod- 5 brake light mod - Helix Steel SMF + Organic Clutch + pressure plate - Peloquin LSD - TD stage 2 Hybrid - Washbrook remapped ECU - Uprated injectors - Cupra bushes -Poly-filled dogbone - Allard racepipe - Pirelli Dragons - Forge Rear Strutbrace - DIY SS upper boostpipe delete -Koni FSD's - elephant pipe CCV mod |
| | #10 |
Members Car: Noddy Car Thanks: 211
| Re: Acid #8 1k Etch Primer for chrome grill I have heard that if you leave the chromed plastic in bleach for a couple of days the chrome flakes off and leaves the plastic, not tried it personally though so disclaimer applies ![]()
__________________ ![]() |
| The Following User Says Thank You to Bigw2069 For This Useful Post: | sworrall (31-07-2007) |
| | #11 |
| Re: Acid #8 1k Etch Primer for chrome grill Sandblasting apparently works a treat - if you have a compressor a basic sandblasting nozzle isnt very expensive....
| The Following User Says Thank You to Basil For This Useful Post: | sworrall (31-07-2007) |
| | #12 |
| Re: Acid #8 1k Etch Primer for chrome grill id seen that one too but i dont have a container big enough to put in the grill plus a shed load of bleach!
| | #13 |
| Re: Acid #8 1k Etch Primer for chrome grill ill have a look in the yellow pages tomorrow to see if there are any sandblasters near me. havent got a compressor im afraid
| | #14 |
| Briskodian Join Date: Aug 2005 Location: Aberdeen, Scotland
Members Car: Fabia VRS '04 Thanks: 5
| Re: Acid #8 1k Etch Primer for chrome grill mine was acid etch primed before it was sprayed. my first attempt was to sand thoroughly , prime (normal grey stuff) then spray the colour. this peeled off with the first sight of a pressure washer. so i gave it to my body shop mate and he did it properly, year on an no problems Scott
__________________ Fabia VRS '04, 170bhp, 280lbf-ft, Star Performanced, PD160 Intake, K&N Filter, SEAT Sport Strut Brace, Jabba ARB, 18"Team Dynamics Pro Race 2's with Toyo T1R's 215/35 R18, 312mm Discs and Calipers, KW Varient 1 Coilovers, Forge FMIC, Custom Decals, Helix Organic Clutch with Single Mass Flywheel, JVC HU, RE SUB, ALPINE AMP WANTED:Exhaust, Turbo, Custom Remap Next Step: Sound Deadening and Front Comps |
| The Following User Says Thank You to beedie For This Useful Post: | sworrall (02-08-2007) |
| | #15 |
| Re: Acid #8 1k Etch Primer for chrome grill thanks beedie. ive actually sandblasted it now but its not something id advise after doing it. the back of the grill comes off at the first sign of the grit down to the bare plastic. great i thought, this should be a doddle. a long time later and the front was finally done but i think i may have taken a few mm off the plastic in the attempt to get the chrome off. The back seems to be one coat but the front seems to be several which doesnt come off easy with the blaster. it just seems to blister which you then have to peel off which is a feckin nightmare. ho hum, you live and learn. now its down to bare plastic im going to see if any of the bodyshops in the area can spray it for me or I may be brave and get some paint, laquere and plastic primer from paints4u.com. oh, the other thing is that after the thick chrome is off the part loses some of it stiffness so is a bit more wobbly now. hopefully when the black grill is attached it will be stiff enough and ok. pics hopefully to follow once its sprayed
| | #16 |
| Moving Stables | Re: Acid #8 1k Etch Primer for chrome grill The method i used was, Put in 5l of bleech for 3 days till all chrome goes black. then with the sand blaster on its lowest setting give the grill a once over. The chrome just blisters as the sand hits and by leaving it in bleech its really soft so just peals off. ![]()
__________________ Run out of CASH |
| The Following User Says Thank You to skudmissile For This Useful Post: | sworrall (09-08-2007) |
| | #17 |
| Re: Acid #8 1k Etch Primer for chrome grill finally got all the chrome off (wish id spken to skudmissile before I started!) the grill has gone in to be sprayed yesterday in a bodyshop and should be back end of the week.
| | #18 |
| Briskodian Join Date: Mar 2005 Location: Upper Ramsbottom
Members Car: Yellow Fabia vRS Thanks: 59
| Re: Acid #8 1k Etch Primer for chrome grill Look forward to seeing some pics
__________________ The future's bright The future's mellow Now with a little zest of Washbrook added |
| | #19 |
| Re: Acid #8 1k Etch Primer for chrome grill i thought you might be as a fellow Islander!
| | #20 |
| Re: Acid #8 1k Etch Primer for chrome grill Its a pretty exclusive club on here!
| | #21 |
| | #22 |
| Briskodian | Re: Acid #8 1k Etch Primer for chrome grill That looks loads better. I've been quoted £50 to get it done at a bodyshop place... Tempted to do it myself, but with the magic black paint I think It'd look **** done by a spray novice! |
| | #23 |
| Re: Acid #8 1k Etch Primer for chrome grill thats about the same as mine cost. id get it done at the shop as the paint and primers etc will cost over £30 if you dont have any. add your time onto that and the £50 is worth it. Ive got a slight colour mismatch with mine so make sure you ask them to coour match the paint to your car. not that it may make much difference with magic black
| | #24 |
| Briskodian | Re: Acid #8 1k Etch Primer for chrome grill Yea, I suppose in a way it'll be fairly easy to match. Even if it's slightly off it should still ok. Would I have to inform my insurance company about it? Surely not?! |
| | #25 |
| Briskodian | Re: Acid #8 1k Etch Primer for chrome grill Oh, visited a bodyshop on Friday... Guess how much he quoted just to spray the grill? ......£100!!!!!! Couldn't believe it, he even asked if I wanted to get the chrome off as it could be extra. Plus he wouldn't be liable if it chips/peels. |
