This is a discussion on Boost Gage install within the Styling and Car Care forums, part of the General Motoring Discussions category; hey all just finished playing and tweaking my boost gage install and i think its looking pretty sweet. have a ...
| Briskodian Join Date: May 2007 Location: weston-Super-Mare
Members Car: A 03 Plate magic Black Skoda Octavia VRS Thanks: 1
| Boost Gage install hey all just finished playing and tweaking my boost gage install and i think its looking pretty sweet. have a look and let me know what you think. i have also included a step by step guide on how i did it as well. ( sorry if this has been done before ) sorry i have no pic of the original dash but i think we all know what an Octavia Vrs dash looks like so first off i removed the cubby hole and head unit to see what was there. ![]() ![]() then i made a mock of how i would like my gage to be laid out in the car on a piece of card board. ( as you can see i did it in work thats why is so basic......but still had time to add style with the logos ![]() i then tried the card layout in the dash to see what it would look like. ( didn't get very Far with this bit as i made the cardboard lay out to big ![]() so new cardboard layout later and a second hole for another gage added its in and looking how i think it should go. ![]() ![]() after a few trips to the shop I'm set on making this happen...but not sure if i like the gage above the head unit. so i then made the card template out of some perspex plastic i had laying around. its not to critical if the perspex is cut a Little under size as it will all be hidden later. next was to remove the carbon look cover from the dash and to lay my perspex in and mask off all areas i didn't want bonded. ![]() next was to add all the bonding gunk. this would hold the perspex in place. ![]() now the perspex was bonded in place i could flip it over and sand out any gunk that had seeped through onto the front of the unit. ![]() its taking shape now not much work left i then had to fill all the gaps and even out the front ![]() once the front had been filled and sanded flat the unit was ready for painting but as I'm not sure what I'm doing to my interior at the moment i decided to cover the hole install in a carbon look vinyl. here is a few pics of the finished article ![]() ![]() ![]() ![]()
__________________ Cheers Moo ( catch you one the flip side ![]() Green intake system, center exhaust box removed, DE-lock kit, shark fin aerial, custom boost gauge install, color coded grill surround, custom amp and sub install, |
Members Car: Black Magic Fabia vRS Thanks: 344
| Re: Boost Gage install That's dedication for you - nicely done! ![]()
__________________ |
| Briskodian Join Date: Aug 2007 Location: Kent
Members Car: vauxhall vectra and omega and 1.9tdi new fabia Thanks: 37
| Re: Boost Gage install MINTED!!! thats some custom install.. i want to do one for my own car, but using the drivers side vent as theres no room above the radio like what you have there. liking the carbon too, well done! |
| Re: Boost Gage install cheers .....it took its time but i just can wait for the new gages to arive then it should look super sweet ![]()
| | #5 | |
| Re: Boost Gage install Quote:
__________________ Cheers Moo ( catch you one the flip side ![]() Green intake system, center exhaust box removed, DE-lock kit, shark fin aerial, custom boost gauge install, color coded grill surround, custom amp and sub install, | |
| Briskodian Join Date: Feb 2007 Location: lancashire
Members Car: 2001 octavia vrs Thanks: 4
| Re: Boost Gage install Well done mate that looks fooking spot-on , not sure if I have the time and motivation to this I would probably just buy a din size 2/3 guage pod and remove the cubby hole . But a sweet job all the same!!!!! ![]()
__________________ APR STAGE 2 REMAP , CARBONIO CAI , 100 CELL CAT , BLUEFLAME EXHAUST , HYPERBOOST DV , BRISKODA STICKERS AND A GREEN MAGIC TREE!!! |
| | #7 | |
) and its a smoked face and until its powered up you cant see what it is. lights up white and red. | |
| | #8 | |
have a look on here iv gone for the multi color ones that are a boost and oil pressure. I'm going to have to pull that stupid sun visor off them tho they look stupid with them on. Automotive Dials Gauges pods t-piece should finish off the dash a treat ![]()
| Briskodian Join Date: Aug 2006 Location: Watford
Members Car: Mondeo 2.2TDCI Thanks: 21
| Re: Boost Gage install Very very nice I wish I had the time to do something like that Top job ![]()
__________________ Octavia VRs ***SOLD*** The futures somkey! The futures diesel ![]() |
| | #10 |
| Briskodian | Re: Boost Gage install That looks sweet! I would but a oil temp gauge in the other hole ![]() Shaun |
| | #11 | |
looks like what ive got. when the missus gets her turbo into her vectra i will have to look into those dials again for her boost gauge. not keen on a pillar mounts | |
| | #12 |
| Briskodian | Re: Boost Gage install It looks sweet dude. just 1 daft question can you fit a boost gauge to a fabia VRS????? ![]() |
| | #13 | |
yep should be no problem all you will have to do is find your dump valve cut the pipe that is on the top of it and T piece the boost pipe from there. shouldn't be to difficult ![]()
| | #14 | |
| Hardcore Join Date: Feb 2006 Location: Bahrain
Members Car: Fabia vRS Thanks: 198
| Quote:
I'm removing the intake manifold over the next couple of days when I have the time.... HTH Bas
__________________ Fab vRS - Black Magic - PD160 intake - Forge FMIC - colour coded front grille -SLC Splitter - K&N Airfilter -SEAT Strutbrace - Jabba ARB - IC Waterspray (need to wire it in!) - 312mm TT brakes - Eibach Springs - Skoda Reversing sensors - Devonutopia Tuning (tm) Custom Exhaust (2 1/4" straight pipe) - Short shifter mod- 5 brake light mod - Helix Steel SMF + Organic Clutch + pressure plate - Peloquin LSD - TD stage 2 Hybrid - Washbrook remapped ECU - Uprated injectors - Cupra bushes -Poly-filled dogbone - Allard racepipe - Pirelli Dragons - Forge Rear Strutbrace - DIY SS upper boostpipe delete -Koni FSD's - elephant pipe CCV mod Last edited by Basil; 19-09-2007 at 19:23. | |
| | #15 |
| Briskodian Join Date: Jul 2006 Location: South Birmingham
Members Car: Red Octavia vRS 1.8T (20v) Thanks: 46
| Re: Boost Gage install I want a cow hole. Nice work
__________________ Support Briskoda----------------------> ![]() Red Skoda Octavia V//RS Mods to date: Carbonio CAI Forge 007 DV Aero Wipers Briskoda Stickers KVW100 GB Wheel Inserts RS Tuning Remap Delocked Piper Cat Back Kenwood KDC-W6541U Fli Twin 12" Active Sub Parrot CK3100 ------------------------------------------------ ![]() |
| | #16 |
| Re: Boost Gage install cow holes come as standard with this install lol thats mini magic moo!!!!!!!
| | #17 |
| Briskodian Join Date: Apr 2006 Location: Sheffield
Members Car: Red Octy vRS Thanks: 36
| Re: Boost Gage install Looks the dogs but i have to say that the original design is better ![]() |
| | #18 |
| Briskodian Join Date: Jun 2007 Location: Norwich
Members Car: Octy vRS Thanks: 5
| Re: Boost Gage install Very tidy. I might have been tempted to spray it black but that might have been a little plain I guess. Is the standard layout radio on top cubby hole bellow (like mine) or with the radio bellow like yours? Or is it whatever they felt like doing that day on the production line? ![]()
__________________ ![]() |
| | #19 | |
i think the standard layout is radio on top and cubby hole bellow..........i did try it with the radio at the bottom but it looks to clustered near the other controls.
| | #20 |
| Powahhhhhh.. Join Date: Apr 2004 Location: Buckinghamshire
Members Car: 2002 Octy 4X4 Thanks: 10
| Re: Boost Gage install Very nice, looks almost OE. I'll be first on the list for a group buy.. 1.UncleRic
__________________ ------------------------------------------------- 4x4 Octavia, now with leaner gerbils ------------------------------------------------- |
| | #21 |
| @(o_0)@ Join Date: Mar 2006 Location: Grimsby
Members Car: Mk1 Octavia vRS Images: 8 Thanks: 60
| Re: Boost Gage install Yep ill take one ![]() 1.UncleRic 2. apinner |
| | #22 |
| Re: Boost Gage install looks like i got loads of work to do then lol ![]()
| | #23 |
| Briskodian | Re: Boost Gage install Thanks have not got a clue how to do all of that might give it a miss for now but thanks |
| | #24 |
| Briskodian | Re: Boost Gage install sounds like a pain in the *** think i might give it a miss for now But thanks |
| | #25 |
| Ta moko! Join Date: Jun 2004 Location: Aotearoa - land of the long white cloud
Members Car: 2004 Octavia vRS Estate Images: 1 Thanks: 154
| Re: Boost Gage install Very neat job, that. Good one!
__________________ Corrida Red 2004 Octavia vRS Estate - It's the bestest Skoda in New Zealand! Whaia te mātauranga, whaia te māramatanga - Pursue knowledge, pursue the wisdom of knowledge www.pimpmyskoda.co.uk www.clubley.org Facebook |
