39,362 Members 1,486,357 Posts
can i clay bar my 1yr old fabia ?
This is a discussion on can i clay bar my 1yr old fabia ? within the Styling and Car Care forums, part of the General Motoring Discussions category; it's nearly my '56' fabia's birthday so i was thinking of using a clay bar on it. will it be ...
Go Back   BRISKODA - The Skoda Forums > General Motoring Discussions > Styling and Car Care
Old 04-08-2007, 14:02   #1
jamestay1's Avatar
Members Car: '56' fabia 1.2 12v
will it be ok to use ?
thanks
jamestay1 is offline
Old 04-08-2007, 14:04   #2
Members Car:
Re: can i clay bar my 1yr old fabia ?
yes.
Use the guides on the polished bliss website as an aid, you can clay a car from brand new, they often benefit from this as most have been lying around somewhere.
Glider is offline
Old 04-08-2007, 14:05   #3
Irf
Irf's Avatar
Members Car: Furby vRS
You can clay a car whenver you want, whether it's brand new or 10 years old. Just make sure you use plenty of lubricant/spray if you get any with or or just use car shampoo diluted in water.
Some tips: Before using the clay, cut it into two pieces. That way if you drop it you can throw it away and use the other remaining piece. Once you've cut it, warm it up using hot water and keep on folding it in your hands. Then when you go and use it on the bodywork, do not press hard. Just rest it on the surface and move it across the paint lightly. Keep on checking the clay regularly and remove any bits it pics up/fold it often.
Hope that helps
Edit: Once you've clayed the car, make sure you protect the paint by waxing it afterwards.
FURBY VRS: cruise, xenons, ESP, heated seats, Revo, Eibachs, Koni FSDs, PD160 pipe, Jabba rear arb, Allard EGR pipe, EGR totally removed, Powertec induction kit, Milltek full system, Garrett GT17, Forge FMIC, 17" Octy wheels, debadged, side strips removed, Seat Cupra splitter, 312mm brakes...
ICE: Alpine 9835, Alpine changer, Alpine X-Type sub, Alpine MRDM1000 & MRFV340 amps, Alpine Remote Amp Controller, Boston Acoustics Pro60....
NEXT: re-remap & clutch
Irf is offline
Old 04-08-2007, 14:32   #4
mattbeef's Avatar
Members Car: Red Octy vRS
As long as you go in this order you will be fine
Wash
Clay
Wash
Dry
Wax
You will be fine mate
I few bits here and there but im happy to Performance Torque
Go on click me you know you want to
mattbeef is offline
Old 04-08-2007, 21:52   #5
Neily03's Avatar
Members Car:
Wash
Clay
Wash
Dry
Wax
I'd dry after the first wash.
Black Magic MY07 Fabia v/RS with Cruise, Xennons, Heated Seats, Dension Ice-Link+, Aero wipers & Jabba RARB.
Neily03 is offline
Old 04-08-2007, 22:31   #6
mattbeef's Avatar
why dry it when you need the car was wet as possible to clay the car
You only keep adding to the whats already on there so its only making more work drying it
mattbeef is offline
Old 04-08-2007, 22:33   #7
Irf
Irf's Avatar
I'd wash the car, then keep it wet. This helps lubricate the clay also. Then, provided you've used enough lubricant while claying you'd only need to rinse it off afterwards and then dry it. Maybe using a quick detailer while drying will help too. Then I'd apply the polish (if required) then apply the wax by applying it on one panel, then spraying quick detailer over it, then applying a second coat directly on top. Then buff off and repeat on the next panel etc.
Irf is offline
