Centre dash and vents.
This is a discussion on Centre dash and vents. within the Styling and Car Care forums, part of the General Motoring Discussions category; Should I or shouldn't I try to add some colour there? I've picked up some Plasticote Pewter metallic spray paint. ...
Go Back   BRISKODA - The Skoda Forums > General Motoring Discussions > Styling and Car Care
Old 15-05-2006, 20:40   #1
vindaloo's Avatar
Default Centre dash and vents.
Should I or shouldn't I try to add some colour there? I've picked up some Plasticote Pewter metallic spray paint. Looks quite good on a sacrificial 3.5" floppy disc. Thinking of doing the surround for the heater controls, stereo etc.
Not entirely sure if I want to go so far as to do the heater vents as that may lead to too much extra work or colouring in gone mad.
In case it looks too shiny, anyone know if it's possible to buy smoked or tinted lacquers and if so where?
EDIT: Bung a link in.
http://www.anticsonline.co.uk/430_1.html
Some of the Custom Colour stuff looks nice too
J.
Slowly turning the planet sooty.
vindaloo is offline
Old 16-05-2006, 16:09   #2
Default Re: Centre dash and vents.
Do it man, do it!!!!!!!!!
mellowyellow55 is offline
Old 16-05-2006, 19:47   #3
texasjohn's Avatar
J.
Tamiya (model) spray paint you can get in 'smoke' it is a lacquer-type paint (i.e. meant to be sprayed on top of a basecolour.
from your local toy or model shop.
Xbox 360 gamertag: TexasJohn74.
texasjohn is offline
Old 16-05-2006, 23:52   #4
vindaloo's Avatar
<thud> Excellent!
Now if it's only compatible with the pewter <rubs chin thoughtfully.>
UPDATE: There are two "Smokes" in the Tamiya range. One is a Polycarbonate spray, the others a Lacquer. The lacquer looks the less opaque of the two.
J.
vindaloo is offline
Old 17-05-2006, 00:07   #5
vindaloo's Avatar
Oh dear, idea spirals out of control....
Discovered Tamiya Translucent paints. Any number of colour finishes. Now I'm doomed.
Anyway, the ashtray lid is likely to be the sacrificial part to see if it's worth doing. It looks easy enough to remove providing I don't lose the bl**dy spring in doing so.
J.
vindaloo is offline
Old 17-05-2006, 00:28   #6
texasjohn's Avatar
Translucent
Thats the word I was looking for earlier
Old 18-05-2006, 15:07   #7
Mil
Mil's Avatar
You mean like this?
Got it on the plastic gear surround panel too.
Milton Kyvernitis
Private Government
Mil is offline
Old 18-05-2006, 15:59   #8
vindaloo's Avatar
Originally Posted by Mil
You mean like this?
<images snipped>
Yep, quite like that. I like the way you've done the door pulls as well.
I'm going to start slowly with the ashtray lid and see how that turns out.
I'm hoping for a gently uplift and minor theming without going OTT.
God that last sentence sounded old, wonder if it'll look good in Tamiya "old folks home tartan blanket"
J.
vindaloo is offline
Old 18-05-2006, 16:59   #9
Stimps's Avatar
Tried it many years ago - really f**ked it up
Basically - too much paint on surrounds, which stopped the vents moving. And to top things off, snapped a vent being heavy handed.
Replacements (2xside, 1xcentre) come to about £100 or so, IIRC
Steve
« Nature Green 1.4 16v Fabia Comfort »
Stimps is offline
Old 19-05-2006, 00:26   #10
vindaloo's Avatar
Arrrggghhh!!! I did not want to hear that - I'm not listening, I'm not listening.
Basically, I've just spent "an evening with the Subaru" explaining to it that I need its ICE to work properly. Short version is "My home made RCA leads turned out to be faulty. They've been binned. The car is now back in one piece thanks to an RCA lead from Comet"
Anyway, back on topic. As therapy from the above, I've lovingly cradled the gear surround and ashtray lid out of the Furby and into the house. I surprised myself by not losing either of the small springs (OK, yet....) or breaking any plastic when prising the lid off.
My spray booth (what I enjoyed making) <hic>
In progress shots...
J.
vindaloo is offline
Old 21-05-2006, 13:33   #11
vindaloo's Avatar
Visited Antics in Guildford and came away with Cutom Colours "Smoke" and something called Crystal clear. They reckoned that the polycarbonate paint would maybe melt other plastics and maybe attack other paint too. Cripes! So I believed them.
Guinea pigs were again floppy disks. I'm having real trouble getting an even coverage with the smoke lacquer though and too many coats of it are required to get near enough to even coverage. . Also, the pewter colour seems to work very well all by itself. So I'm probably going to ditch using the smoke effect lacquer.
The crystal clear is something else altogether. Used on a black floppy, it made it VERY black and VERY shiny.
J.
vindaloo is offline
Old 23-05-2006, 11:10   #12
vindaloo's Avatar
Done the ashtray lid. Now working on the gear surround.
As Stimps mentioned, paint thickness may be an issue with the lid but I have a cunning plan involving T-CUT or minor sanding if it stops things working or if it scrapes.
For the best effect, I think several coats of crystal clear may be required to give depth to the metallic pewter.
J.
vindaloo is offline
Old 31-05-2006, 00:32   #13
vindaloo's Avatar
BTTT for some more piccies above.
Finished the first couple of bits. Paint looks a bit scabby on the edges of the gear surround 'cos it is. I had a bit of a drippy moment with the clear topcoat. After a bit of sanding, some of the metallic came off too. Not in areas that can be noticed though, so I left it as it was.
I quite like the effect. Strange how it looks kind of buff/champagne finish inside the car but steel grey/pewter outside of it. Must be something to do with tints etc.
I'm convinced enough to do the rest of the centre console if I can figure how to remove it.
J.
vindaloo is offline
Old 31-05-2006, 01:39   #14
texasjohn's Avatar
I think what you've done so far is pretty good, looks nice!
I'm thinking about it myself now!
Mil, did you car come like that, in 'GT' spec* or did you put the silver paint on the plastics yourself?
If it came like that, maybe we can order the parts in silver ourselves and change out the plastics for those that want to do so?
* I read somewhere on here that his car is a 2.0 GT Fabia which we don't get in the UK AFAIK.
