39,476 Members 1,490,590 Posts
Had to happen I suppose
This is a discussion on Had to happen I suppose within the The Tech Shed forums, part of the Members Area category; Xbox has finally given up, it will only work for a minute or so before it just locks up. Screen ...
Go Back   BRISKODA - The Skoda Forums > Members Area > The Tech Shed
Old 17-09-2008, 18:55   #1
DaveI's Avatar
Members Car: Seat Leon FR TDi
Xbox has finally given up, it will only work for a minute or so before it just locks up. Screen either goes black or whatever is currently displayed freezes with loads of artifacts all over the screen.
So where is currently cheapest on the high street for an XBox 360 Arcade package?
2007 Seat Leon FR TDi 170 Bluetooth / Convenience Pack / 18s / Rear Parking Sensors / Front Centre Arm Rest / Passenger Airbag Disconnect / Free Dealer Mats / Brodit Mount + Brodit Tom Tom One Active Holder
Used to have an A5 Skoda Octavia 1.9 TDi Elegance Combi and Missing somewhere comfy to rest my right arm!
DaveI is offline
Old 17-09-2008, 19:10   #2
Om nom nom nom
Neo_VR's Avatar
Members Car: A White Car
Re: Had to happen I suppose
Xbox's are DIRT cheap now try your usual game/gamestation/HMV shop etc.
they are £149 on Play.com (199 for the 60gb premium)
ColGod the UberMod
,___,
[O.o]
/)__)
-"--"- ORLY??
Neo_VR is offline
Old 17-09-2008, 19:10   #3
.:Robbo:.
Robshaw's Avatar
Members Car: A Clio 1.2 16v
Is there any "Red lights" on the box at all - or does it just crash as stated above?
If no lights show - It should technically just be a hardware problem. If it's under warranty send it back to Microsoft!
Current:
Renault Clio 1.2 16v Dynamic
Sold:
Honda Civic Type R
Skoda Fabia vRS
Robshaw is offline
Old 17-09-2008, 19:54   #4
DaveI's Avatar
No red lights, just the freezing.
It was purchased second hand and went out of warranty an age ago.
Just got it in front of me gradually taking it to bits. Found a guide which basically means re-doing the thermal compund and re-jigging the heat sinks so they don't stress the MB as much.
DaveI is offline
Old 17-09-2008, 20:23   #5
FORE!!!!
Hedge's Avatar
Members Car: Shanks Pony
Good luck. It may be worth a call to Microsoft as they fixed mine for around £60 even though it was out of warranty. They basically stuck my serial number on a new box and sent it back.
Hedge is offline
Old 17-09-2008, 20:52   #6
DaveI's Avatar
Too late!
DaveI is offline
Old 17-09-2008, 21:19   #7
Getting a flat!
djswivel's Avatar
Members Car: Fabia vrs
You can get an 360 arcade for £129.99 now. Get one of those, and stick your hard drive in. They're all shipped with HDMI now, just the arcade has a different disk drive so will not play xbox original discs.
djswivel is offline
Old 17-09-2008, 21:53   #8
DaveI's Avatar
I didn't fix it:
There goes my dream of an internet based Xbox 360 repair service!
DaveI is offline
Old 18-09-2008, 00:03   #9
cheezemonkhai's Avatar
Members Car:
Check the capacitors on the board for bulging and replace any of them. Also check the solder joints on the VGA connector and make sure any heatsinks are help firmly in place.
cheezemonkhai is offline
Old 20-09-2008, 16:18   #10
Blade404's Avatar
Members Car: Black Focus
I thought all 360's had a 3yr warranty?
EDIT: At least according to this Clicky...
One brush to tar them all!
Ford Focus Titanium in Panther Black
For information about joining the briskoda.net folding team click here..
Blade404 is offline
Old 20-09-2008, 16:47   #11
FORE!!!!
Hedge's Avatar
Only for the 3 red lights or red ring of death.
Any other problems then it is only a year.
Hedge is offline
Old 24-09-2008, 00:47   #12
DaveI's Avatar
Everything appears to be right with the world again, the sun will shine tomorrow, the birds will sing as I have appeared to have fixed my XBox!
Bought the screws and washers etc from ebay and followed these instructions:
Untitled Document
It's been running ok for the past 3 hours or so where as before it wouldn't manage more than ten minutes. Better get back in my Astra and see if I can beat Bengies ring time!
DaveI is offline
Old 25-09-2008, 20:08   #13
Members Car:
What on earth are they doing with those bolts?
Just put in a better heatsink or replace the (I imagine stretched) nuts in the heatsink of the whole heatsink and clean out the fans.
Old 26-09-2008, 17:34   #14
DaveI's Avatar
The mounting of the heatsinks are a bit strange with just an X shaped bracket on the back of the mainboard stretched over the 'legs' of the heatinks.
I don't know the exact science behind it but it all seems to be working now! Cleaned out the heatsink dust, replaced the thermal paste and have a (supposedly) better fan to fit this weekend.
DaveI is offline
Old 26-09-2008, 22:19   #15
Members Car:
That's fairly common for Xeon and other older server chips that I'd seen.
My guess, and it is just a guess, would be that the bolts somehow stretch and can't get enough of a pull to keep the heatsink pushed down on the CPU or GPU and it has a funny.
I wonder if just cleaning it up, applying the new heatsink compound and doing it all up would work fine.
Old 26-09-2008, 22:53   #16
DaveI's Avatar
It didn't, see post #8. That was my first effort at just re-seating the heatsinks and replacing the thermal paste.
DaveI is offline
Old 27-09-2008, 00:08   #17
Members Car:
Guess the bits you remove from the heatsink just stretch or lose their thread.
Not a piece of genius design.
Old 27-09-2008, 06:25   #18
Blade404's Avatar
From what I've been told, by someone who has fixed a few RRD 360's it's some of the connections on the cpu it's self that break with all the expansion and contraction of the cpu as it's heats up then cools with use.
In order to fix the problem you have to increase the pressure on the cpu so that these connections are pushed back together.
Blade404 is offline
Old 27-09-2008, 12:55   #19
DaveI's Avatar
According to the repair procedure I followed it's the GPU that has dodgy connections:
This step requires you to overheat your GPU & keep the CPU cool at the same time.
The reason for this is to keep the CPU cool while we overheat the GPU under the DVD Drive. The heat generated helps to secure the GPU chip and embed the "reflow" of the BGA solder connection that has failed.
I dunno, I did it and it worked!
DaveI is offline
Old 29-09-2008, 13:30   #20
philje123's Avatar
I did Something similar on my old iBook quite some time ago that had a similar issue with the BGA solder connections on the GPU.
So... took the back cover off, turned it over, powered it up and placed a lit tealight candle on top of the GPU.. it worked!
It finally gave up a couple of months later unfortunately!
Glad you got it sorted!
96 Felicia Laurin & Klement 1.3 spi Hatchback called Nelly
philje123 is offline
Old 29-09-2008, 15:52   #21
Members Car:
Sounds like the BGA soldering wasn't up to it and the extra pressure fixes the joints well enough to work.
I'd have thought this might have something to do with the Lead Free Solder as when the 360 came out this would have been very new. Does anyone know if the XBox 360 is RoHS compliant and if so what level it is (5 or 6/6 etc?).
If it was down to the lead free solder not being up to the job, then I'd be fairly certain some people could put in a nice claim for replacement of the goods FOC as they were not fit for purpose due to the original design.
The leaded and lead free solder have pretty different characteristics in this aspect and IIRC most leaded connectors the solder was enough to hold it strong but the lead free ones needed extra pins to take the insertion forces.
Similar Threads
dont suppose fonzi's felicia Photography and Photoshop 2 14-03-2008 13:12
Well I suppose it's their exercise roo Off Topic and Chit Chat 0 29-10-2007 07:20
Why does it always happen to me! Octavia Vrs! Octavia I 0 30-07-2007 14:30
I don't suppose any of you happen to be... ColinD Off Topic and Chit Chat 8 31-12-2005 04:22
Is this suppose to happen ADMotorsport General Car Chat 12 15-05-2005 12:36
1 2 3 4 5 6 7 8 9 10
