This is a discussion on HDMI cables for HD & Blu-Ray? within the The Tech Shed forums, part of the Members Area category; As there seem to be a hundred and one different HDMI cables out there all made by manufacturers claiming to ...
| SMOGUS MAXIMUS | HDMI cables for HD & Blu-Ray? As there seem to be a hundred and one different HDMI cables out there all made by manufacturers claiming to be the best, what have other forum members used, and with what results, good or bad? I have always been a fan of QED and IXOS products, has anyone used either of these brands for HDMI? These are required for HD television and Blu-Ray plus upscale, and not PS3. |
| Briskodian | Re: HDMI cables for HD & Blu-Ray? Dont bother spending a fortune on a cable. HD is a digital signal and as such, it'll get there or it wont' there is no "in-between" This has been confirmed in recent tests (including The Gadget Show) where side-by-side comparrisons show no difference between the most expensive and the not-quite-the-cheapest. |
| Legend!! Join Date: Oct 2006 Location: Portsmouth
Members Car: 53 reg Octavia Vrs & 57 reg Octavia Vrs 170pd TDi Thanks: 42
| Re: HDMI cables for HD & Blu-Ray? i bought mine from Play.com for about £10. Its about 2.5 metres long feels really good quality and the picture is great. I have tried a £65 one in the same tv with no visible or audible difference. I think if your tv is about 100" + you might see a difference or if you have a MEGA sound set up! But for most a £10 lead will be absolutely perfect. |
| Briskodian Join Date: Mar 2008 Location: Baildon, West Yorkshire
Members Car: Race Blue MkII Octavia vRS, Cruise, Xenon, Maxi, Light Assist, Jumbo Pack, Heated Seats. Thanks: 28
| Re: HDMI cables for HD & Blu-Ray? I agree. I work in the AV industry. You should not have to spend loads on ur cables. The most important bit to look at though is the connector at either end. Sometimes they can be a bit loose fitting and fall out when lightly pulled at. I'm not talking fancy gold plated blah, blah blah - simply - how tight the fitment is and ensures a good ground point. The only other thing to beware of, is if you are using a cable longer than say 5m; this is when impedance matching and transmission line effects will be more prominent and odd effects can happen and affect the eye patterns in the HDMI signalling. Thus far though - i use the $1.50 leads we ship in our products and never had an issue < 2 metres. Hope this helps.
__________________ ![]() 2008 Race Blue vRS 2.0 TFSI, Xenons+Philips Vision bulbs, Park Assist Front+Rear, MaxiDot, Cruise Control, Jumbo Box, Auto Rain Wipers & Light Assist, Heated seats, 18" Alloys, OEM Integrated Bluetooth, Pipercross Air Filter, Chrome climate+light dial surrounds+climate OFF mod, Briskoda stickers, Midnight Rear Tints, VRS-reg. Engineers know that million to one shots happen 9 times out of 10!!!! |
| SMOGUS MAXIMUS | Re: HDMI cables for HD & Blu-Ray? Thanks to all for the replies, and if only "ER" indoors would sanction a 100" screen....LOL In the past when using scarts, I have always used IXOS products and there is a marked difference, but will give the cheaper HDMI's a go as the maximum size I need is only the one metre ones, and then if not satisied will try the dearer ones. Thanks again. |
| Briskodian Join Date: Apr 2005 Location: North East
Members Car: Seat Leon FR TDi Thanks: 52
| Re: HDMI cables for HD & Blu-Ray? i've got two of these: Play.com (UK) : Linx 1.2m Luxury 24k Gold Plated HDMI Cable : Electronics - Free Delivery Spot on picture, good quality cable and the connectors are a good, tight fit.
__________________ 2007 Seat Leon FR TDi 170 Bluetooth / Convenience Pack / 18s / Rear Parking Sensors / Front Centre Arm Rest / Passenger Airbag Disconnect / Free Dealer Mats / Brodit Mount + Brodit Tom Tom One Active Holder Used to have an A5 Skoda Octavia 1.9 TDi Elegance Combi and Missing somewhere comfy to rest my right arm! |
| Re: HDMI cables for HD & Blu-Ray? Because HDMI is digital there is no signal degridation(IE you either get a picture or you don't). All HDMI cables have to conform to the same standard, my cheapo cable that came with the SkyHD box gives the same picture than the mistakenly purchased more expensive Belkin cable I used to use with the HTPC. If you are going for a longer length (5M plus) then a more expensive cable may help guard against data loss though.
| Briskodian Join Date: Jul 2005 Location: Fareham
Members Car: Octy vRS Thanks: 5
| Re: HDMI cables for HD & Blu-Ray? True 'digital is digital' but you can get difference in spec on HDMI cables... Cheap ones probably won't perform to V1.3 (which is the output performance capability of a PS3 for example). V1.3 will have a greater colour range (several trillion colours as opposed to 256,000 on the cheap ones) and also from a future compatibility viewpoint the V1.3 will also cope with HD upto 1440P (which will come sooner or later) If it were me, I would buy a decent ish brand with V1.3, but not spend silly money.
__________________ You be chillin' |
| Re: HDMI cables for HD & Blu-Ray? HDMI is digital, the number of colours is irrelevent and all cables are already HDMI 1.3 compliant, even the cheap ones. Over on avsforums (us version of avforums) they did a comparison on a 50" plasma TV being fed with bluray and nobody could tell the difference. Same thing using a HD projector, nobody could tell.
| | #10 |
Members Car: 4x4 turbo estate Thanks: 17
| Re: HDMI cables for HD & Blu-Ray? hdmi v1.3 is the item not the cable ![]() the same as you get a usb cable rather than a usb 1.0/1.1/1.2/2.0 etc etc digital is digital so buy em cheap ![]()
| | #11 |
| Geordie Lass Join Date: Oct 2005 Location: in the ceiling watching you.....
Members Car: BMW 1 series Thanks: 221
| Re: HDMI cables for HD & Blu-Ray? Another vote for reasonably priced cables here. I wouldn’t necessarily buy the cheapest though, as the mechanical integrity of these items may not be brilliant. Dry joints and bad pressings etc. but the idea of spending huge sums on short lengths of HDMI is a false one imho. I work in broadcasting and I have seen many things that show that solid dilithium crystal latticed kryptonite coated pixi dust sprinkled cables are not necessary at all. I agree for longer lengths a decent cable will probably be better. |
| | #12 |
| Hiya Vic!!! Join Date: Feb 2006 Location: Sheffield, South Yorkshire
Members Car: 2006 Fabia vRS & 2005 Fabia vRS. Images: 9 Thanks: 116
| Re: HDMI cables for HD & Blu-Ray? I got the following from www.hdmi.org Q. What is the difference between a “Standard” HDMI cable and a “High-Speed” HDMI cable? Recently, HDMI Licensing, LLC announced that cables would be tested as Standard or High-Speed cables.
Cheers Dave. |
| | #13 | |
| Go Gadget Octy! | Re: HDMI cables for HD & Blu-Ray? Quote:
| | #14 | |
| Why So Serious Join Date: Jan 2006 Location: "What" ...What ain't no god damn country
Members Car: a car Thanks: 272
| | #15 |
| Briskodian | Re: HDMI cables for HD & Blu-Ray? I just get mine free from work and never had any issues with them but if i did would just get another one ![]()
__________________ Never put off until tomorrow,what you can do today...unless you simply can't be arsed!! |
| Hd Movie - DVD9 Vs Blu-ray | fluffy01016 | The Tech Shed | 8 | 21-06-2008 01:47 |
| Blu-Ray | apinner | The Tech Shed | 17 | 15-03-2008 00:16 |
| Recommend a Blu-Ray. | pittVRS | The Tech Shed | 6 | 13-12-2007 00:56 |
| did sony just kill blu-ray? | andypandypoos | The Tech Shed | 17 | 15-01-2007 08:43 |
| HD/Blu Ray | Terry G | Off Topic and Chit Chat | 30 | 04-01-2007 17:09 |
