39,476 Members 1,490,585 Posts
I suspect my hard disk is shagged
This is a discussion on I suspect my hard disk is shagged within the The Tech Shed forums, part of the Members Area category; Can anyone reccommend any software to test? Cheers...
Go Back   BRISKODA - The Skoda Forums > Members Area > The Tech Shed
Old 09-09-2008, 18:46   #1
jamesmckelvie's Avatar
Members Car:
Cheers
1.9 TDI Elegance - Cappuccino Beige
Plenty enough power and torque for the economy offered
jamesmckelvie is offline
Old 09-09-2008, 19:13   #2
Why So Serious
fatty5000's Avatar
Members Car: a car
Re: I suspect my hard disk is shagged
The ultimate boot disk found here. Ultimate Boot CD - Overview has disk tools, but you need to burn the image, is the computer still working???
fatty5000 is online now
Old 09-09-2008, 20:02   #3
Members Car:
thanks - yes still working, but slowly
Old 09-09-2008, 20:07   #4
splash!!!!
bengie's Avatar
Members Car: 4x4 turbo estate
so what are you symptons?
owner of a skoda octavia 4xvrs3
bengie is offline
Old 09-09-2008, 20:12   #5
Members Car:
XP is very slow to load, before it gets to the GUI, and when you shut it down after using it, it runs a checkdisk. No unusual noises though, the drive sounds sweet.
Old 09-09-2008, 20:17   #6
splash!!!!
bengie's Avatar
sounds like it could be the drive
bengie is offline
Old 09-09-2008, 20:18   #7
Members Car:
I am wondering if it is conflicting hardware. I might try disabling the onboard lan - audio etc and see how I get on from there.
Old 09-09-2008, 21:06   #8
cheezemonkhai's Avatar
Members Car:
No it just sounds like you have a load of dead sectors and your drive is remapping them on the fly, but not getting them quickly enough or running out of allocated spares to replace them with.
For the sake of a pittance for a new drive I wouldn't take the chance with your data. Back it up, and get a new drive in asap
cheezemonkhai is offline
Old 10-09-2008, 01:15   #9
anewman's Avatar
Images: 1
In my experience failing hard disks usually make nasty noises, clicking, grinding etc.
I managed to recover data from a failing hard disk once by sealing it in a bag and sticking it in a freezer for a while. Gave me just enough time to copy the data over before it started going iffy again. Suppose it's amazing they last so long when you think these things spin at 72,000 RPM (1,200 rotations per second?)
94 Favorit GLXIe Estate
Briskoda "Banger" social group
anewman is offline
Old 10-09-2008, 01:18   #10
Why So Serious
fatty5000's Avatar
Members Car: a car
Do they...... more like 7,200 rpm
The Following User Says Thank You to fatty5000 For This Useful Post:
anewman (10-09-2008)
Old 10-09-2008, 01:58   #11
anewman's Avatar
Images: 1
Ooops, I fail still quite fast though
anewman is offline
Old 10-09-2008, 10:39   #12
Aspman's Avatar
Members Car: Octavia VRS TFSI
Have a look at the disk itself to see who made it and then visit their website. They all make free diagnostic software.
BUT first things first do as the Monkhai says and back everything up. AND check the backup is ok.
The TazZone Forums
Aspman is offline
Old 10-09-2008, 10:54   #13
Members Car:
You're quite wrong about failing disks making noise. That is only from a catastrophic failure of the mechanism. Many things such as age or temperature can cuase bad sectors and once the limit of these is reached things go down hill quickly.
Old 10-09-2008, 12:41   #14
cjb
Seconded. Failing disks quite often go silently these days. Use the PC as little as possible until you have a good backup of your data.
-- Chris
The Devil may care, but I don't mind.
cjb is offline
Old 10-09-2008, 12:50   #15
cjb
And the higher density of data these days means that once things start to fail they can go badly wrong quickly.
-- Chris
cjb is offline
Old 10-09-2008, 13:01   #16
matchmaker's Avatar
Members Car: Black Octavia vRS
Might be an idea when you get the new disc to get hold of drive imaging/cloning software and do a straight copy from old to new.
But do a backup asap - just in case!
Alan
"Darth" - Black Magic Octavia VRS with Forge DV, BMC CDA induction kit, Milltek cat, Supersprint exhaust, Xenons, ESP, cruise, parking sensors and Kumho 225/45/17 tyres Been to Star sufficient bhp & ample lb/ft All time low - 7.8 mpg
matchmaker is offline
Old 10-09-2008, 18:29   #17
Members Car:
thanks all - managed to get the data off using xcopy. I imaged the computer when I first built it, now time to get a new hdd, and test the restore.
Similar Threads
How to deliberately corrupt hard disk? maffwilson The Tech Shed 12 12-09-2007 23:40
External Hard Disk - Thoughts GAFF The Tech Shed 7 20-02-2006 12:23
Laptop Hard Disk MrBump The Tech Shed 7 06-12-2005 18:05
Networked Hard Disk davidcollins01 Off Topic and Chit Chat 10 07-02-2005 18:29
Hard Disk Fail devonutopia Off Topic and Chit Chat 16 26-11-2004 10:04
