This is a discussion on MS Active Directory Software deployment help... within the The Tech Shed forums, part of the Members Area category; For some reason I cant seem to get something to work correctly with regard to using AD to deploy some ...
| MS Active Directory Software deployment help... For some reason I cant seem to get something to work correctly with regard to using AD to deploy some software. Application x = Office 2003 pro edition, Application y = office 2003 std edition What I am trying to achieve is to have X uninstalled and replaced with application Y. There is a reason why I need to change the office version but thats something else. I have an admin install of each, an MSI file for each and a MST file for each as well. I have 2 GPO's in AD one that deals with X and the other for Y. I changed the rules for Y so it would in theory uninstall X and replace it with Y. Whats actually happening is that X is being left and Y is installing as well. Looking in add/remove programs both X and Y are shown. I need to find a simple way, using AD if possible to uninstall X from about 1/2 the pc population and replace it with Y without visiting all the clients. Any help appreciated (assuming that all makes sense).
| | #2 | |
| rodeo monkey Join Date: Jan 2005 Location: blah, blah, f*****g blah!
| Re: MS Active Directory Software deployment help... do you not just remove the policy which installed the old app from the computers (or the computers from the policy) and then add the policy which installs the new app? or is that something you're trying to avoid? shouldn't the MST for the new app (be able to)uninstall the old one, or is that what's not working?
__________________ Note: This statement was most likely made with a usual dry sense of humor. It was in no way made to offend anyone who may be easily offended. If you find yourself offended by such a statement, you needed more hugs as a child, or more beatings. Whichever you didn't get enough of, you need more of. Probably beatings. Quote:
| | #3 | |
| Briskodian Join Date: Jun 2003 Location: On the back of an AA truck with a failed turbo
| Re: MS Active Directory Software deployment help... Quote:
What you need to do is upgrade the one application with the other as it mentions here.... Upgrade an application: Group Policy Oh , and forgot to say - the old app needs to have been installed via the GPO and not put on there manually , even if it was from the same msi
__________________ Alex "I laugh in the face of danger, then I hide until it goes away" www.drzoidberg.co.uk | |
| The Following 2 Users Say Thank You to Dr Zoidberg For This Useful Post: | andypandypoos (08-09-2008), mannyo (09-09-2008) |
| Re: MS Active Directory Software deployment help... I think you are right Alex, looks like a manual uninstall/reinstall is on the cards. The original install image seems to have been done manually rather than through a GPO.
| Briskodian Join Date: Aug 2007 Location: Leicestershire
| Re: MS Active Directory Software deployment help... We had the same issue with removal of apps that weren't originally installed via a GPO, and it caused huge problems. Faced with trying to manually uninstall a particular app from 1500 desktops one of our guys wrote another app to strip as much of it as possible and that seemed to work.. ish. The problem cuts both ways too - if the app was a GPO install and is removed manually, there are a lot of keys left behind that wouldn't have otherwise been there. If you're using SMS (or rolling out SMS clients) then you'll find both these scenarios creatd a world of random and frustrating hurt.. |
| Frustrated Join Date: Oct 2002 Location: It's grim
| Re: MS Active Directory Software deployment help... logon script to do the uninstall?
__________________ My goal is to replace my soul with coffee and become immortal |
| | #7 | |
Could be worth trying on a test machine...
| Om nom nom nom Join Date: Feb 2003 Location: Manchester
| Re: MS Active Directory Software deployment help... MS office is a biyach to get rid of totally. we are having a similar dilemma, trying to downgrade from office pro to std.. even after removing pro and re-installin std, it still says its pro (and this is without using AD) |
| Upgrading Active Directory to 2k3 problem | Dr Zoidberg | The Tech Shed | 5 | 03-11-2006 18:17 |
| Active Directory tools.... | Neo_VR | The Tech Shed | 2 | 09-10-2006 11:57 |
| Copying Active directory.. | Neo_VR | The Tech Shed | 9 | 26-07-2005 14:32 |
| Active directory XP/2003 question | Neo_VR | The Tech Shed | 12 | 21-07-2005 14:43 |
| Airbag deployment intrigue... | maffwilson | General Car Chat | 17 | 18-03-2004 20:02 |
