A valued partner and supporter of this community, please visit.
This is one of our valued partners, please consider supporting them.
System files corrupt
Discussing System files corrupt within the The Tech Shed forums, part of the Members Area category; I've spent all morning trying to get my laptop to boot up, problem is a couple of files in c:\windows\system32\config ...
Go Back   BRISKODA - The Skoda Forums > Members Area > The Tech Shed
Login
46,768 Members 23 Posts
Notices
Register to reduce ads, enable search and join our community.
Bookmark and Share LinkBack Thread Tools Display Modes
Old 16-08-2008, 15:47   #1
Oops! :(
apd007's Avatar
Location: The 2nd biggest city in the whole of England.
Members Car: Octy II vRS
Unhappy System files corrupt
I've spent all morning trying to get my laptop to boot up, problem is a couple of files in c:\windows\system32\config have got corrupt. I've followed the instructions from the MS website and got my laptop to boot so far, but then it turns around and says passwords are incorrect and reboots. Can't get in to safe mode for the same reason and can't boot the recovery CD as it now won't accept my admin password.Used Puppy to restore the original security files and now back to square one. Any ideas?
Support Briskoda join Freedom ======>
Was :- Skoda 120LSE Yellow 1.2 ~ 60 BHP?
Then :- Mk I Skoda Octavia Blueline 1.9 TDi 90 BHP.
Now :- Mk II Skoda Octavia vRS Black 2.0 TFSI. 200 BHP. + Skoda Felicia LXi Green 1.3 67 BHP
apd007 is offline
Old 16-08-2008, 16:22   #2
cjb
Re: System files corrupt
Try a google for ntpasswd, and see if that can change/blank the admin password for you. It's a boot floppy/CD.
-- Chris
The Devil may care, but I don't mind.
cjb is offline
The Following User Says Thank You to cjb For This Useful Post:
apd007 (17-08-2008)
Old 16-08-2008, 16:40   #3
BRISKODA Staff
mannyo's Avatar
Config is the hardware part of the registry, and usually if thats corrupt its a reinstall time. I asume you have already tried pressing F8 and then selecting the last good config option.
You can try and fix it by doing a repair install over the current one, no need for the admin password
You will need an XP home/pro CD, and also a valid CD key.
1) boot from XP cd (not vendor recovery disc as this WILL wipe everything).
2) press enter to install xp (not R)
3) on the next screen xp setup will find your existing setup and ask if you want to attempt a repair, press R now.
4) setup will continue to the end prompting for answers along the way.
Manny
2005(55) Octavia 2.0TDi Elegance combi, retrofitted maxidot, columbus, RS6 Syle wheels
my skoda website http://www.octaviars.co.uk
Join the briskoda.net folding team click Here for more info
mannyo is offline
The Following User Says Thank You to mannyo For This Useful Post:
apd007 (17-08-2008)
Old 17-08-2008, 10:59   #4
Oops! :(
apd007's Avatar
Thanks for the answers. CJB, looks like a useful application that, I'll certainly give it a try. With regards to a full rebuild, thinking about going with Linux on it instead as it will give me access to my stuff on the NTFS partition.
apd007 is offline
Old 19-08-2008, 20:51   #5
Oops! :(
apd007's Avatar
It WORKS!!!!
Taken a bit of work, following instructions from the MS web site but having to do all the fixes in DOS instead of safe mode was fun.
Just hope the BSOD doesn't come back, has been ok tonight so far though.
apd007 is offline
Old 19-08-2008, 21:50   #6
Mouse's Avatar
Members Car: Furby VRS
If BSOD comes back. Then may i sugest your hard drive is stuffed, get any data off of there before this happens. Glad to see you all sorted.
Black Magic Fabia v/RS
Skoda Fabia VRS ! Practical & Exciting !
Mouse is offline
Old 19-08-2008, 21:53   #7
Oops! :(
apd007's Avatar
Sadly, I suspect this is the root cause of all the issues I've been having over the last few days.
Still, suppose it's not bad, 4 years out of a laptop.
apd007 is offline
Old 20-08-2008, 21:20   #8
Vanishing Point
Wardy's Avatar
Location: Usually somewhere around Manchester or Cheshire...
Members Car: Octavia vRS 2.0TFSi
Images: 6
Could you post which MS links you used to fix please. I've got a couple of machines in that appear to have a very similar fault to what you describe.
The fact I have two here with very similar symptoms makes me think it could well be the result of a Windows update/patch/fix.
Cheers,
Steve
18s : Maxidot : Jumbo Pack : Cruise : PDC
"Racing is life. Anything before or after is just waiting." - Steve McQueen
"If in doubt, flat out." - Colin McRae
Wardy is offline
Old 20-08-2008, 21:31   #9
Oops! :(
apd007's Avatar
How to recover from a corrupted registry that prevents Windows XP from starting
That's the one I've been using. When you've done part one and you're on to part two you may find you still need to use DOS or a runtime version (e.g. Puppy) as it still might not boot. I've got my laptop now booting but it still keeps BSOD after a bit of time, leading me to suspect the HDD.
With regards to the possibility of an update causing the issue, I know when SP3 came out there were a number of reports of it causing BSOD, however, I waited a bit of time before installing it and have been using it for a couple of months now without trouble. Only updates I've done recently are AVG8 and also Firefox 3, don't know how this compares to your experiences.
apd007 is offline
The Following User Says Thank You to apd007 For This Useful Post:
Wardy (20-08-2008)
Old 20-08-2008, 21:34   #10
cjb
Either that or RAM. Give it a run of Memtest86+ - Advanced Memory Diagnostic Tool as well.
-- Chris
cjb is offline
Old 20-08-2008, 21:37   #11
Vanishing Point
Wardy's Avatar
Images: 6
Arrow Re: System files corrupt
Cheers for the info. These are all other people's machines, with leads me to suspect some outside force as they're all used differently, by different people and have different components etc - no common factor.
Cheers,
Steve
Wardy is offline
Old 21-08-2008, 01:13   #12
cheezemonkhai's Avatar
Members Car:
HDDs all fail eventually, 4 years is a pretty good life for a laptop drive if it's actually used on the move or just not on a desk all the time.
cheezemonkhai is offline
Old 21-08-2008, 09:26   #13
Aspman's Avatar
Members Car: Octavia VRS TFSI
Hard Drives - 2.5" Laptop IDE Drives - Ebuyer
Easy job and cheaper than a new laptop.
The TazZone Forums
Aspman is offline
Old 02-10-2008, 17:13   #14
Oops! :(
apd007's Avatar
I've just installed the drivers for my wireless laptop card after being ok for about a month and guess what has just started happening........
apd007 is offline
Old 02-10-2008, 17:51   #15
Vanishing Point
Wardy's Avatar
Images: 6
What card is it? And did you install with the latest driver download package (if available)?
Steve
Wardy is offline
Old 02-10-2008, 17:52   #16
Oops! :(
apd007's Avatar
Linksys WPC54G Version 1.2. Yeah, I'm using the latest drivers, downloaded them this afternoon.
BTW, how did you get on with the computers you were looking at?
apd007 is offline
Old 02-10-2008, 18:01   #17
Vanishing Point
Wardy's Avatar
Images: 6
Did you jump straight to XP SP3 when you re-installed? I did this on the ones I had problems with, and I've not had any phonecalls.... yet!
I'm convinced it was a buggy Windoze patch/update and my theory was that in jumping straight to the Service Pack, I might avoid anything again (one laptop, two desktops - nothing connecting/linking them etc, no patterns).
On the Linksys issue - might this help? Go straight to the horse's mouth, so to speak, by downloading drivers for the chipset that the card uses? WPC54G ver 1.2 Driver needed - LinksysInfo - Community Forums for Linksys Devices
Steve
Wardy is offline
The Following User Says Thank You to Wardy For This Useful Post:
apd007 (02-10-2008)
Old 02-10-2008, 18:11   #18
Oops! :(
apd007's Avatar
Yeah, went straight from XP XP1 to SP3, and everything has been fine. Installed the Linksys card = BSOD!.
Thanks for the link for the drivers btw , been looking for it as there used to be a definite driver for version 1.2 cards that has gone missing off the Linksys website.
To Be Continued.........
apd007 is offline
Old 02-10-2008, 18:23   #19
Vanishing Point
Wardy's Avatar
Images: 6
No worries, fingers crossed
From the tone of the posts on that link, it might be like you're not the only one to have issues with Linksys drivers
Steve
Wardy is offline
Old 02-10-2008, 18:35   #20
Oops! :(
apd007's Avatar
. It's gone into a BSOD loop and doesn't want to boot now!
apd007 is offline
Old 03-10-2008, 01:20   #21
Vanishing Point
Wardy's Avatar
Images: 6
Is rollback an option? Or boot in Last Known Configuration? Or go into Safe Mode with Networking and then remove/uninstall the device in Device Manager?
Steve
Wardy is offline
Old 03-10-2008, 11:49   #22
Oops! :(
apd007's Avatar
Steve
Sadly, no, no and no.
Ironically, it did BSOD on me as I was typing my original reply , however, I'm hoping that was just because I forgot to reboot after an update.
As it wouldn't boot even into safe mode properly I ended up reimaging the hard drive. Since installing the Broadcom drivers though I have managed to download wirelessly all the updates from XP SP1 to SP3 and install them.
apd007 is offline
Old 03-10-2008, 12:55   #23
Vanishing Point
Wardy's Avatar
Images: 6
Blimey, what a pain! Sincerely hope this is the end to your troubles now, and that the Broadcom version does the trick....
Steve
Wardy is offline
Bookmarks
Similar Threads
Corrupt a Wish! gillywibble Off Topic and Chit Chat 25 18-12-2007 11:51
How to deliberately corrupt hard disk? maffwilson The Tech Shed 12 12-09-2007 23:40
Transferring Files Conshine The Tech Shed 16 27-04-2007 12:15
X-Files Boxsets vRS19TD Off Topic and Chit Chat 7 15-03-2007 12:54
cue files & bin files??? scrutineer The Roadside Hotel 5 07-09-2004 01:45
Disclaimer: This is not an official SKODA site and is not affiliated to SKODA in any way. Visit the Official SKODA Website. Views and opinions are given by the poster and do not reflect the views of BRISKODA.net nor SKODA.
PLEASE NOTE - PERSONAL ABUSE, ABUSE AGAINST THIS OR ANY OTHER WEBSITE OR ANY COMPANY WILL NOT BE TOLERATED. OFFENDERS WILL BE MODERATED OR EVEN BANNED.
BRISKODA.net is operated by Summit 360 Ltd. Site Design and vBulletin Theme by Alex Pinner (apinner)
Problem viewing this site? Upgrade to the latest version of your web browser of choice:
Opera | Firefox | Safari | Internet Explorer
Website © 2002-2009 BRISKODA ltd & SUMMIT360 ltd E. & O.E.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106
