A valued partner and supporter of this community, please visit.
This is one of our valued partners, please consider supporting them.
Unlock your BT Home Hub to use with another ISP
Discussing Unlock your BT Home Hub to use with another ISP within the The Tech Shed forums, part of the Members Area category; Thought this might be useful - Here are the instructions to upgrade your BT HomeHub to firmware 6.1.9.6. The effect ...
Go Back   BRISKODA - The Skoda Forums > Members Area > The Tech Shed
Login
46,768 Members 34 Posts
Notices
Register to reduce ads, enable search and join our community.
Bookmark and Share LinkBack Thread Tools Display Modes
Old 07-08-2007, 20:17   #1
Txt Spk Police
VRStu's Avatar
Members Car: Audi S3
Here are the instructions to upgrade your BT HomeHub to firmware 6.1.9.6. The effect of this is to make the router unlocked and able to be used on any ISP.
• Go to Start > Control Panel > Network Connections > Local Area Connection -(rightclick)- Properties
• Click on "Internet Protocol (TCP/IP)" to highlight it, then click on the "Properties" button.
• Click on the "Use the following IP address" option and enter the following in the boxes.
• Code:
• IP address: 192.168.1.1
• Subnet Mask: 255.255.255.0
• Default Gateway: 192.168.1.254
• Click "OK" then "OK".
• Connect the HH to your desktop PC with the yellow ended CAT5 cable.
• Plug in the power of the HH.
• Go to the folder you unzipped the Speedtouch Update Wizard to.
• Doubleclick on upgradeST.exe
• Click on "Next"
• Let the wizard detect your HH. When you click on "Next" you will be asked for the login of the router.
Login: admin
Pass: admin
• Click on the "Have Disk" button, and find the ZZMYAA6.196.bin file that you unzipped earlier.
• Click "Next".
• This is your final chance to chicken out before you start the update. If you're ready, click "Next" and let the update run.
• If all goes well, you will see the firmware being uploaded to the router and then being installed on the router.
• It will ask you for new login details just press CANCEL - Ignore the error message at the end because the wizard is lying to you.
• Close the wizard.
• Go to Start > Run ... and type telnet 192.168.1.254 then click "OK".
• Login using the same login details as before...
Login: Administrator
Pass:
• Look at the text, and if you see 'Speedtouch 7G' and 6.1.6.9 in the top right corner then you have SUCCESSFULLY updated the firmware of your HH and can now proudly call it a 7G.
• Type exit to leave telnet.
• Start > Control Panel > Network Connections > Local Area Connection -(rightclick)- Properties
• Click on the "Obtain an IP address automatically" option and then click "OK" and "OK" again.
• Plug in the phone line into the 'broadband' socket of the router.
• Open your browser and type in http://192.168.1.254
Pass:
• Click on Speedtouch on the blue menu on the left.
• Click on the "Set Up" link under 'Pick a task...'
• Click the "Next" button on the popup window
• Select Routed PPP then click "Next"
• Select 0.38 from the list for VPI/VCI
• Select PPP over ATM (PPPoA) for 'Connection Type'
NB. Only if you're on AOL, choose PPP over Ethernet (PPPoE).
• Enter the username and password for your ISP broadband login. Click "Next"
I think it is self-explanatory from that point on. That basically means that you've got Internet capability.
Have a look around the menus. You've got far more options available to you.
You can get the files here - Download bthub.rar, upload your files and earn money. but it may not be worksafe.
Stu
VRStu is offline
The Following User Says Thank You to VRStu For This Useful Post:
soviet (30-10-2008)
Old 07-08-2007, 21:57   #2
mattbeef's Avatar
Members Car: MK1 Red Octy vRS
Re: Unlock your BT Home Hub to use with another ISP
I thought that they were unlocked as it were anyway?
Mine lets me change the username and password
I few bits here and there but im happy to Performance Torque
Go on click me you know you want to
mattbeef is offline
The Following User Says Thank You to mattbeef For This Useful Post:
Stevete (18-06-2008)
Old 11-08-2007, 17:18   #3
DaveI's Avatar
Members Car: Seat Leon FR TDi
You can change the user and pass but as soon as it gets on line it changes them back to the default values, the BT business hub does this also.
88E Metro 1.3 Sport > 93K Ford Escort Excalibur 1.3 > 98S Vauxhall Corsa 1.2 16v SXi > 94L Vauxhall Cavalier 2.0 16v CDX > Vauxhall Astra 1.7 DTi Van! > 2004 Skoda Octavia 1.9 TDi Elegance Combi currently 2007 Seat Leon FR TDi 170
DaveI is offline
Old 18-06-2008, 22:04   #4
Members Car:
Hi, Just like to say thanks for the info, will post again when I have run the unlocking procedure.
Regards Stevete.
Stevete is offline
Old 18-06-2008, 22:21   #5
Dab of Oppo!
Neo_VR's Avatar
Members Car: A White Car
Lol, although quite why anyone would want to use a homehub....
ive just bought a sky broadband router off ebay for a tenner... can be flashed back to a proper netgear
ColGod the UberMod
Originally Posted by apinner
Hmm i am a real lover over a cumberland
,___,
[O.o]
/)__)
-"--"- ORLY??
Neo_VR is offline
Old 18-06-2008, 22:52   #6
Ex Moddy
Makefish's Avatar
Members Car: Saab 9-3 Aero TTiD
Originally Posted by Neo_VR View Post
......ive just bought a sky broadband router off ebay for a tenner... can be flashed back to a proper netgear
Care to tell me how it's done as I've tried to do it before but failed miserably and would like another bash at it?
Makefish is offline
Old 18-06-2008, 23:06   #7
Kaiserb_uk's Avatar
Members Car: Fabia vRS
I've got 2 identical netgear's - one provided by Sky (currently in box) and the one I've had for donkey's with custom firmware on it....flashing them is a doddle.
Offended? spEak You're bRanes
MCSA:M
CompTIA:Security+
Mods:Nearly enough
Kaiserb_uk is offline
Old 19-06-2008, 22:56   #8
Go Gadget Octy!
I thought BT etc these days always own the router and you simply rent it when you use their services.
You stop, it must go back. I know this is true for Orange, and thought it was the same for BT too.
gadgetman is offline
Old 21-06-2008, 10:32   #9
Dab of Oppo!
Neo_VR's Avatar
Just add to this, i got my "sky" router thismorning...
Have flashed it with dgteam custom firmware and its MUCH faster than the homehub... my ping is lower, downstream and upstream faster...
now i know this is because the homehub err's on the side of caution with SnR ratios, but im only a few hundred metres from the exchange and can sync at 7.5mb but never get anywhere near that... now i am
ColGod the UberMod
,___,
[O.o]
/)__)
-"--"- ORLY??
Neo_VR is offline
Old 21-06-2008, 10:35   #10
Briskodiodion
TeflonTom's Avatar
Members Car: Lupo TDi / Felicia
well they can have mine back it's in pieces after i got so annoyed with it and threw it out my bedroom window
DIY cruise control now up and running
TeflonTom is offline
Old 08-07-2008, 17:04   #11
Members Car:
What would be the benifits of doing this to my hub
jonc22 is offline
Old 08-07-2008, 17:28   #12
Txt Spk Police
VRStu's Avatar
The clue is in the thread title mate.
Stu
VRStu is offline
Old 08-07-2008, 18:04   #13
redbaron's Avatar
Members Car:
just swapped out my home hub for a dg834 after reading this... and internet is now 33% faster!
redbaron is offline
Old 24-08-2008, 23:17   #14
Dab of Oppo!
Neo_VR's Avatar
Just a quick bump.. i actually started fiddling about with the firmware on my DG384gt.. by changing the snr percentage i have managed to get an extra meg out of my line... now syncing at over 7mbits
ColGod the UberMod
,___,
[O.o]
/)__)
-"--"- ORLY??
Neo_VR is offline
Old 12-10-2008, 14:32   #15
Members Car: none
hi, can anyone tell me if they have unlocked the new black bt router v2.0 yet. as i am trying to find a way how to do it. any info about it i would be very greatful
tonyandkathy is offline
Old 12-10-2008, 15:20   #16
DaveI's Avatar
I was wondering why this keeps getting dug up, this thread is third on Google when you type in unlock BT home hub
DaveI is offline
Old 12-10-2008, 15:37   #17
Members Car: none
i tried that but it doesnt say what router it is for apart from that it takes you to the top of this thread
Old 12-10-2008, 21:52   #18
Members Car:
best thing i have done is disconnect the bellwire from the mastersocket. cheaper than an iplate and its given me almost an extra 1mb in sync speed
"There's a time to live, there's a time to die
But isn't it strange that as soon as you're born you are dying?" IM
encephalopathy is offline
Old 14-10-2008, 14:52   #19
Members Car: MR2 Turbo
Sort of off topic......bear with me.
Is it true that if you use BT as your ISP you are forced to use their home hub?
If so, does anybody know how to use a third party router with a BT home broadband service?
Cheers
NumLock/*- is offline
Old 14-10-2008, 22:56   #20
Go Gadget Octy!
Cheers
Unless they give you login details, then the easy way to get them is hack into it (passwords etc will be on the net) then do a config dump to the computer. You'll find it in there.
Works for Sky, Post office and many other plug and play ISPs that provide the router and no other details.
Old 14-10-2008, 23:29   #21
Vanishing Point
Wardy's Avatar
Location: Usually somewhere around Manchester or Cheshire...
Members Car: Octavia vRS 2.0TFSi
Images: 6
Damn Colin and his efficient page ranking skills
18s : Maxidot : Jumbo Pack : Cruise : PDC
"Racing is life. Anything before or after is just waiting." - Steve McQueen
"If in doubt, flat out." - Colin McRae
Wardy is offline
Old 15-10-2008, 07:34   #22
500 Power
lfc958's Avatar
Members Car: Fiat 500
Cheers
Answer to your question is No you dont have to use BT supplied I have a linksys, and it works fine.
As long as it is configured to ISP, then it works fine.
Steve
Michael Schumacher drives a 500, Is it still a girlie car ?
lfc958 is offline
Old 15-10-2008, 11:14   #23
Fluffy Bunny's Avatar
I got instructions on how to use a different router when my black home hub arrived the other day.
Heather
Fluffy Bunny is offline
Old 15-10-2008, 22:30   #24
Go Gadget Octy!
Just remember, like many others, the conditions *might* say you merely rent it, and must hand back if you leave or pay a vastly inflated figure.
So many people who ebay'd their hubs and live boxes soon regret it when a bill for a few £100 lands on the mat. Orange demand £250 IIRC for a livebox.
Old 16-10-2008, 00:00   #25
Vanishing Point
Wardy's Avatar
Images: 6
£250! - it's worth precisely nothing and the biggest heap of junk excuse for a router I've ever seen. If you ever take the 'roof' and look at what's inside you'll see what I mean!
Steve
Wardy is offline
Bookmarks
Disclaimer: This is not an official SKODA site and is not affiliated to SKODA in any way. Visit the Official SKODA Website. Views and opinions are given by the poster and do not reflect the views of BRISKODA.net nor SKODA.
PLEASE NOTE - PERSONAL ABUSE, ABUSE AGAINST THIS OR ANY OTHER WEBSITE OR ANY COMPANY WILL NOT BE TOLERATED. OFFENDERS WILL BE MODERATED OR EVEN BANNED.
BRISKODA.net is operated by Summit 360 Ltd. Site Design and vBulletin Theme by Alex Pinner (apinner)
Problem viewing this site? Upgrade to the latest version of your web browser of choice:
Opera | Firefox | Safari | Internet Explorer
Website © 2002-2009 BRISKODA ltd & SUMMIT360 ltd E. & O.E.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106
