Brakes: Brake Fade Causes And Cures
This is a discussion on Brakes: Brake Fade Causes And Cures within the Technical Guides forums, part of the Skoda Model Discussion Area category; The following guide looks at common causes and cures of brake fade. Pad Fade Pad fade occurs for several reasons. ...
Go Back   BRISKODA - The Skoda Forums > Skoda Model Discussion Area > Technical Guides
Old 21-03-2006, 12:58   #1
Site owner
ColinD's Avatar
Default Brakes: Brake Fade Causes And Cures
Pad Fade
Pad fade occurs for several reasons. All friction material (brake pad stuff) has a coefficient of friction curve over temperature. Friction materials have an optimal working temperature where the coefficient of friction is the highest. Sometimes you can use the brakes so hard that you get the temperature over the point of maximum friction to where the coefficient of friction curve starts to decline.
The mechanics of this decline in the coefficient of friction are varied. At a certain temperature, certain elements of the pad can melt or smear causing a lubrication effect, this is the classic glazed pad. Usually the organic binder resin starts to go first, then even the metallic elements of the friction material can start to melt. At really high temperatures the friction material starts to vaporize and the pad can sort of hydroplane on a boundary layer of vaporized metal and friction material which acts like a lubricant. Pad fade is felt as a car that still has a decent, non mushy feeling brake pedal that won’t stop even if you are pushing as hard as you can. Usually it builds somewhat slowly giving you time to compensate for it ,but some friction materials have a sudden drop off of friction when the heat is put on them resulting in sudden dangerous fade.
[b]
ColinD - 97/100 Limited Edition Octavia vRS < For Sale
www.BRISKODA.net :: Site Owner.
E-Mail : webmaster at briskoda dot net
Got a comment to make about the site? Please feel free to use the feedback form here, we welcome your views.
ColinD is offline
Old 21-03-2006, 13:26   #2
Dinosaur
TaviaRS's Avatar
Default Re: Brakes: Brake Fade Causes And Cures
http://www.briskoda.net/forums/showthread.php?t=2210
Put thgis in Col and then delete this post
Jon
A jolly sensible Mercedes E class saloon in a rather fetching bluey grey colour. No it isn't fast, no it isn't modded, and yes, it will still eat your Fabia for breakfast.
Official mobile chicane for Briskoda trackdays
TaviaRS is offline
