This is a discussion on DashBoard Creak (Fabia) within the Technical Guides forums, part of the Skoda Model Discussion Area category; Its been annoying me for weeks, and I decided that while Im off college with man flu, Ill fix the ...
| | #1 | ||
| Briskodian Join Date: Jun 2006 Location: Middlesbrough, home of legends :P (not the worst place in the UK at all...honest guv)
| Its been annoying me for weeks, and I decided that while Im off college with man flu, Ill fix the creak. Armed with 6 plastic cards, I managed to get the vents out and (hopefully) fix the problem. Heres a guide avec pictures... To stop anything that may snap (god forbid) falling into an abyss, put the heaters onto the feet position. Heres the hard bit. Use the cards to release the retaining clips which are circled (there are another 4 under these too in the same positions). ![]() If its too tight a fit with 3 cards under and 3 cards above just use 3 under, and gently prize the top part away (this is abit more risky as you need a fair bit more force and the clips could snap). The top should protrude about 3-5mm, then you can "wiggle" the bottom out fully. ![]() Heres some close up pics of the clips: ![]() ![]() Dont pull the vents fully out, as you need to unclip the hazzard light switch from the vents first! ![]() Once you have the vents out its plain sailing. Now you need to choose your method of taking up the gap. Quote:
![]() Oh, and I thought it would be ideal if I sorted out my head unit at the same time and heres the result :![]() Hope this helps everyone who is turning deaf because they had to turn the radio so loud in order to drown out the mouse under the dash! Mike Pembo | ||
| The Following 4 Users Say Thank You to PEMBO For This Useful Post: |
| Briskodian Join Date: Sep 2006 Location: Liverpool
| Thanks alot i thought it was just my VRS that made this noise lol will av a go at sorting it at the weekend |
| | #3 | |
| Quote:
| Briskodian Join Date: Aug 2006
| My set up seems to be different to this, when I start to remove the fascia part of the vent it seems to leave behind the louvre and adjustment dials. I have not looked further into it as I didn't have much time, so I put it back. |
| | #5 | |
| Quote:
These are the locations of the clips that are coming undone I presume on yours: It may be easier to remove the radio and put your hand up behind the vents and push it out that way Give it a try ![]() | |
| Briskodian Join Date: Jul 2006 Location: Hampshire
| Not quite clear where to put the half cork. I have put mine 6" in front of the greyish plastic vertical support strut. It's inside the top hat and underneath 2 diagonal plastic struts that slope down from above. Photo (double click on it) taken from left vent shows the top hat to right of cork and one of these sloping plastic struts above it. Is this the right place? When pulling out the vents 4 of the spring clips detached from the vent and one fell inside. Maybe I had got the credit cards below the top clips rather than above them. Took me 3 hours of dismantling the central fascia to find it. Not helped by Halfords selling me the wrong radio removal tool. Last edited by echase; 03-06-2007 at 23:25. Reason: Add Photo |
| The Following User Says Thank You to echase For This Useful Post: | reflex88 (07-10-2007)
| | #7 | |
| Briskodian Join Date: Dec 2006
| Quote:
anyways.. just wanted to confirm the location as correct and your description as perfect!.. two plastic supports come down from the dash at an angle.. the aim is to stuff something under these and in the top hat metal bracket to push UP on the plastic supports! and stop the flexing.. wherever it actually is! | |
| Briskodian Join Date: Aug 2008
| Thanks everyone for this info about the source of the squeak! I followed the directions and stuffed some packaging material underneath the two plastic struts and it seems to have pretty much cured the noise for now. The method I used was to cut a long (about 1.5 metre) strip of thin packaging foam, about 5cm wide, and then push it into the gap using a cutlery knife, starting from one end of the strip and feeding it in gradually. This has the advantage that you can't drop it inside the dash by accident as you have hold of one end! |
| Briskodian Join Date: Apr 2003
| Is this to cure a "mouse-like" creak or a loud "plastic on plastic" rattle? I've got really bad rattling coming from this area (and now from in front of the dash pod) and am wondering if it's the same thing (I'm beginning to fear it's the dash support / cross-brace)... BTW I've been using bits of pipe insulation to cure the other creaks and rattles with pretty good success so far...
__________________ . |
