Eibach Springs - how to improve the ride
This is a discussion on Eibach Springs - how to improve the ride within the Technical Guides forums, part of the Skoda Model Discussion Area category; OK, here's a tip for anyone thinking of fitting Eibach springs. But first a bit of background... I've had Eibachs ...
Go Back   BRISKODA - The Skoda Forums > Skoda Model Discussion Area > Technical Guides
Old 22-07-2005, 08:47   #1
rsbspt's Avatar
Default Eibach Springs - how to improve the ride
I've had Eibachs on my Furby vRS for over a year, initially with standard dampers and later with Koni adjustables. From day one I was delighted with the improvement to the pitch, dive and roll, but less than impressed with the effect on ride which, at high speed on poorly surfaced M/ways I would best describe as 'jarring'.
When others who'd fitted Eibachs reported on Briskoda that they found the ride as good, if not better than standard, I began to wonder if my springs were faulty. So I made arrangements to take them to Eibach UK to be compression tested. They were found to be within spec. Eibach's design and test engineer agreed to road test the car over a public road test route he uses for setting up the suspension on cars as varied as Prodrive WRC Subarus and Tony Blair's 3.5 tonne armour-plated Jaguar! He concluded the poor ride was either due to a damping problem or the need for more progressive bump stops.
His mention of bump stops got me thinking about the effect of lowering springs on the standard bump stops. He said that some cars are designed to have the bump stops in constant contact between dampers and body mounts (Rover 75 and Golf Mk5 for example). But when I examined the Furby, it was clear the stops are only there to act as a buffer when the springs are in maximum compression.
Fitting Eibachs lowers the ride height by 25mm and this reduces the amount of free movement in the suspension before hitting the bump stops to about 0.5" at the rear and virtually nil at the front. In other words, the suspension is constantly bumping against the stops. Could this be the cause of the jarring ride?
I decided to shorten the bump stops to restore the amount of free suspension travel to standard. The rear stops are quite long (110mm) so I shortened these by 30mm. The front stops are rather shorter (55mm) so these were reduced by 20mm. To allow the re-fitting of the damper dust covers at the rear, I decided not to chop all the length off one end but to take a section out of the middle of the stop, re-joining the two ends together with Araldite Rapid.
And the result? Eureka! Problem solved. OK, the ride is still firm - Eibachs are 25% stiffer than standard after all. But the ride is so much more compliant (smoother) and the jarring at high speed has completely gone.
So my advice if you're fitting Eibachs is:
1) Well beforehand, order a new set of bump stops - part Nos:
Front 6Q0412301A - £4.95 each + VAT
Rear 6Q0512131B - £7.24 each + VAT
2) Cut and, in the case of the rears, re-join as suggested above.
3) When the suspension is dismantled to fit your Eibachs, fit the new bump stops at the same time.
4) Enjoy!
Hope this is useful.
Phil Thomas
Then: Red Fabia vRS: Not quite standard.
Now: White Octavia vRS: Eibachs/FSDs - Milotec B pillars - Neuspeed shifter (thanx Stu!).
rsbspt is offline
Old 22-07-2005, 09:09   #2
eatsoot04's Avatar
Default
Thats brilliant thankyou very much.
Could someone please explain "bump Stops" though or post a piccy of where i should look?
Alex
Alex
Revo
Chilly Alpine ICE
Cupra Intake
Green Cotton Filter
RS6 wheels
184 BHP
eatsoot04 is offline
Old 22-07-2005, 09:14   #3
rsbspt's Avatar
Default
Alex
There's a pic of a rear bump stop in this thread:
http://www.briskoda.net/forums/showt...ghlight=Eibach
see the section on Rear Springs and Dampers Step 1.
Phil Thomas
rsbspt is offline
Old 22-07-2005, 10:30   #4
Goodas's Avatar
Default
Thanks for posting that, very useful information
I am having my springs fitted tommorow by JBS, i just checked with them and they are shortening the bump stops.
Corrida Red Fabia Vrs...now sold...new car...Blue Fiesta ST150
Goodas is offline
Old 22-07-2005, 11:19   #5
faboka vrs's Avatar
Default
Hmm sounds interesting.
for the research.
John
Take away the poor damping, inadequate bushes, heavy diesel lump and spongy brakes its not a bad warm hatch
faboka vrs is offline
Old 22-07-2005, 11:31   #6
HellFire's Avatar
Default
Mine is fine but a good tip for anyone who is having the above problem.
Metro Blue '06' 5 Door Astra 1.8 SRi
HellFire is offline
Old 22-07-2005, 11:38   #7
Goodas's Avatar
Default
Didnt you get yours fitted at JBS?
I think they would have shortened your bump stops for you then
Goodas is offline
Old 22-07-2005, 11:42   #8
HellFire's Avatar
Default
Yes I did . If they have done that already that's brilliant, didn't know they knew about this issue already
HellFire is offline
Old 22-07-2005, 11:50   #9
eatsoot04's Avatar
Default
So the bump stop is inside the damper?
Alex
Revo
Chilly Alpine ICE
Cupra Intake
Green Cotton Filter
RS6 wheels
184 BHP
Old 22-07-2005, 11:55   #10
rsbspt's Avatar
Default
No. It sits between the top of the damper body and the mounting point for the damper (or strut) on the car.
Phil Thomas
rsbspt is offline
Old 22-07-2005, 12:01   #11
UberMod™
Neo_VR's Avatar
Default
Would this affect all suspension setups.. ie would coilovers have the same problem?
ColGod the UberMod
VXR, Gti, ST, Type-R, vRS, Cupra, Shifty... An MPS fears not these things...
Neo_VR is offline
Old 22-07-2005, 12:27   #12
ScoobyChris's Avatar
Default
Wonder if the Elegance Fabia is different then as the ride quality on mine hardly changed at all when I had my Eibachs fitted. My mate did them and I'm pretty sure he didn't monkey about with the bumpstops!
Chris
ScoobyChris is offline
Old 22-07-2005, 12:32   #13
Briskoda Staff
VRStu's Avatar
Default
Some good advice there mate. In my days of messing with the Saxo etc it wasn't uncommon to shorten the Bump Stops for exactly that reason.
With lowering shocks you normally have a shorter shaft and therefore less travel so proportionately the Bump Stop should be shorter.
Powerflex do some nice Polyurethane Bump stops
Stu - Freedom Pimp
Stu's Car - Hmm, Have a guess......
VRStu is offline
Old 22-07-2005, 14:00   #14
faboka vrs's Avatar
Default
I would have thought you'd get new bump stops with coilovers. Could be wrong.
John
Old 22-07-2005, 17:10   #15
UberMod™
Neo_VR's Avatar
Default
Im just thinking to myself.. if i was going to do this.. and taking the suspension off, i might as well put coilovers back on.. oh and poly bushes
Neo_VR - victim of "the slippery slope"
ColGod the UberMod
Neo_VR is offline
Old 22-07-2005, 17:58   #16
Briskoda Staff
VRStu's Avatar
Default
Powerflex
http://www.powerflex.co.uk/bumpstop.asp
Stu - Freedom Pimp
VRStu is offline
Old 24-07-2005, 12:13   #17
faboka vrs's Avatar
Default
could know someone who'll take your springs off your hand
John
Old 24-07-2005, 15:43   #18
VT5
Default
I decided to shorten the bump stops to restore the amount of free suspension travel to standard. The rear stops are quite long (550mm) so I shortened these by 30mm. The front stops are rather shorter (110mm) so these were reduced by 20mm. To allow the re-fitting of the damper dust covers at the rear, I decided not to chop all the length off one end but to take a section out of the middle of the stop, re-joining the two ends together with Araldite Rapid.
4) Enjoy!
I did exactly this on my last fabia (fitted with Koni adjustables and Eibach springs)
Was a pain before on faster roads and motorways with dips - car much better after trimming them.
It does improve the ride quality, although it is still firmer than standard.
I trimmed the rears and the fronts. It makes an improvement and reduces the bounciness and allows the springs to work without the bumpstops interfering..
You can actually do this mod without removing the dampers, if you are really determined...
Was: 2003 Allard Tuned Fabia vRS VT5 Turbo Conversion
Now: 2008 Audi A3 Sportback TDI
FabiaTDi is offline
Old 25-07-2005, 00:31   #19
Mike Austin's Avatar
Default
Was this the 2.0 Elegance? I would like to drop mine a bit (while retaining the ride quality) so the spring rate you chose would suit me if the engine block is the same weight. What was the part number of the Eibachs, and how far did the suspension drop? Did you change the dampers as well?
Mike Austin is offline
Old 25-07-2005, 06:24   #20
Mil
Mil's Avatar
Default
Dude, you will not be able to retain the same ride quality with lower springs. Bumps will be harsher, you'll have moved out of the comfort zone.
I don't know what coilovers would do for you, but I do know they help since they have adjustable dampers, so you can set it so that maximum shock absorption happens at the right time...
Milton Kyvernitis
Private Government
Mil is offline
