Felicia: one of the most common problems with the Felicia
This is a discussion on Felicia: one of the most common problems with the Felicia within the Technical Guides forums, part of the Skoda Model Discussion Area category; Originally by BigK One of the most common problems with the Felicia is the "my temp gauge doesn't go up ...
Go Back   BRISKODA - The Skoda Forums > Skoda Model Discussion Area > Technical Guides
Old 21-03-2006, 13:01   #1
Site owner
ColinD's Avatar
Default Felicia: one of the most common problems with the Felicia
Originally by BigK
One of the most common problems with the Felicia is the "my temp gauge doesn't go up whilst driving". Well this is the reason:
This is a pic of a new thermostat. Quite simple really. As the temp rises the spring retracts to allow that thermostat to open allowing hot coolant from engine into the radiator to be cooled. Pay attention to the lugs on circled with the green paint. Here we have a metal frame held in by a plastic surround and over time the plastic surround lugs break as shown in following pic.
As can be seen in this pic the lugs break causing the guts of the thermostat to break up allowing a constant flow of water to the radiator. Thus the coolant is permantly being cooled, causing not only the temp gauge to read low but the ECU into thinking engine is cold and injecting more fuel.
ColinD is offline
The Following User Says Thank You to ColinD For This Useful Post:
DAVE WESTON (09-06-2008)
Old 05-08-2006, 01:21   #2
Default Re: Felicia: one of the most common problems with the Felicia
sorry for bumping the thread up but do u have larger pictures than the thumbnails ?
lajonel is offline
Old 05-08-2006, 23:16   #3
playing dadsie
Quinten's Avatar
That's as big as I can get them I'm afraid.
Awooga!!!
Quinten is offline
Old 08-08-2006, 06:07   #4
is the problem the thermastat or the plastic houseing please
pmott60 is offline
Old 09-02-2007, 13:55   #5
bump!
The problem is with the housing.
I've just replaced mine on a 2001 Fabia
mgskoda is offline
Old 23-02-2007, 15:09   #6
old boiler
fab51's Avatar
hi colin -
know the fealing - one of my lugs came off inside the thermostat housing , apparantly it is a common fault with them - but , where there`s a will there`s a way - drilled a small hole in the cross bar with a pilot hole in the housing and put a little self taping screw in and its been as good as gold for 2yrs now - if it go`s on the other side i`ll buy a new one - i know , its cheating - cant let skoda win all the time -
hope it helps
fab51 is offline
Old 01-03-2007, 18:10   #7
sean moore's Avatar
help mines knackered too
just to rub salt in the wounds the bloody garage
sold me a stat for a diesel . anybody know how much the housing will cos for a 1999 felicia?
cheers
sean
sean moore is offline
Old 03-03-2007, 23:45   #8
daverapid's Avatar
cheers
sean
Roughly £50 inc VAT.
David McKinney
TREASURER OF SKODA OWNERS CLUB GREAT BRITAIN
www.skoda-owners-club.org.uk
daverapid is offline
Old 24-10-2007, 10:09   #9
Hi,
'New' Felicia is suffering from same problem.
Is it an easy enough DIY repair?
How long would it take?
Thanks
sem9999 is offline
Old 28-11-2007, 19:21   #10
hi would this broken thermostat cause the engine revs to surge ?
clairamay is offline
