Octavia - Remote central locking guide with photos!
This is a discussion on Octavia - Remote central locking guide with photos! within the Technical Guides forums, part of the Skoda Model Discussion Area category; Well, I promised I'd do another guide after the Fabia one. Instead of describing it all in this post, I ...
Go Back   BRISKODA - The Skoda Forums > Skoda Model Discussion Area > Technical Guides
Old 12-09-2007, 23:34   #1
jonboyuk's Avatar
Default Octavia - Remote central locking guide with photos!
Well, I promised I'd do another guide after the Fabia one. Instead of describing it all in this post, I thought it more prudent to attach it as a PDF. I hope it's of some use to you guys.
Cheers
Jon
File Type: pdf RETROFIT GUIDE FOR KE60_OCTAVIA_RevA.pdf (540.7 KB, 706 views)
jonboyuk is offline
The Following User Says Thank You to jonboyuk For This Useful Post:
barbo (30-07-2008)
Old 03-10-2007, 11:19   #2
macocty's Avatar
Default Re: Octavia - Remote central locking guide with photos!
Do this make the power windows work too? Just got my kit in the post today. Thanks, Eamon
Problem!!! Can get it to lock but not unlock! help!!
macocty is offline
Old 09-10-2007, 14:22   #3
jonboyuk's Avatar
Erk! You need to check the connections that you crimpped to the earth (use a multimeter if necessary). Also I found that it doesn't work properly unless all the doors are shut? Are you sure you have a 2 wire system? What year is your Octy?
jonboyuk is offline
Old 24-11-2007, 13:35   #4
jonboyuk's Avatar
I have revised the guide with an updated wiring diagram.
jonboyuk is offline
Old 23-03-2008, 13:21   #5
I have same problem. 1999 Octavia. locks ok (pin 2) but won't unlock (pin 4). Unit/earthing is OK because if i put white/black wire from unit to pin 2(lock) it locks when i press the unlock button on my fob.
any ideas?
Warmkiwi99 is offline
Old 27-03-2008, 21:28   #6
jonboyuk's Avatar
Hmm...you need to try other wires in the loom in the ECU. Just push them in temporarily until you get a result.
jonboyuk is offline
Old 29-03-2008, 11:09   #7
OK. I think I tried that but with no joy. Will have another go when (if) the rain ever stops
Old 29-03-2008, 19:49   #8
I Had the same problem, but if you unlock on the fob and again within 2 secs it then unlocks all for doors as I found out on mt Octi by acciedent.
Hope it helps....
Tony Thatcher is offline
Old 12-05-2008, 11:13   #9
Question Re: Octavia - Remote central locking guide with photos!
I've got the same problem, also the lock pulse doesn't activate the alarm, this could be done with a red wire somewere?
Also the warning lights don't work when connected to unit, the colours are the same as in the manual (black/green and black/white).
I suppose the unit switches the lamps to ground or +12V, according to the 2 yellow wires' polarity.
I think my Octavia is a 1997 model with type 2 negative wiring.
André
speedyandre is offline
Old 30-07-2008, 19:14   #10
mello in yello
postmanpat's Avatar
Hiya Barbo think you meant to post this:
Hello.
Can you send me guide for Octavia how to install remote central locking to ****
Tnx
You posted this as a report post comment. Please don't include email address in open forum tho
Andrew
Originally Posted by Emily-Elizabeth
Sperm donership: It is not like giving blood, it is tossing away...............
Postmanpats car Fabia vRS Zennons, ESP, autochanger, 3rd headrest, heated seats, cruise control
SWMBO Octy Mk2 vS maxidot, duel zone wotsit, cruise, parking sensors, 18" alloys
postmanpat is offline
Old 04-09-2008, 20:05   #11
Hey,
Thank you for this excellent guide! I used it as I purchased a Octavia 2001 Classic. The car has a steering wheel on the left, so the underside of the dash is slightly different. However, I located the 23-pin connector and the required pins 2 and 4.
The pin 2 has a wire, but the pin 4 is empty. Is this ok? These pins are also referred in the Defa instructions; see below.
http://www.fvwa.sitefactory.fi/data/6408.jpg
Should I enable the pin 4 somehow? Should locking work with just pin 2? I mean, the pin 4 is used to unlock the car? Now the black box just makes a relay sound, but the doors do not lock/unlock.
The other difference is the hazard warning lights; I have just one wire to use to drive them, so taking a wire from the button won't work; that way I just get the other side working and by splitting the wire I'm afraid to affect normal turning signals.
As a temporary solution I took the wire to the fuse box and connected it to the parking lights. Now unlocking and locking flas the parking lights (and dash, and plate lights...) probably illeagal..
I'd really appreciate any help!
Thanks,
Ville
Kyytsö is offline
