Resetting one touch windows
This is a discussion on Resetting one touch windows within the Technical Guides forums, part of the Skoda Model Discussion Area category; Should your vehicle lose its one touch setting follow these simple steps, same applies for each window. Step 1. With ...
Go Back   BRISKODA - The Skoda Forums > Skoda Model Discussion Area > Technical Guides
Old 11-09-2006, 20:27   #1
Hairy Yeti
Lummox's Avatar
Default Resetting one touch windows
Step 1. With the window in the fully up position pull and hold the window switch into the up position again, you should hear a small click from the motor.
One touch is now set for that window.
Have a nice day
R
Unit 18 now open Servicing, repairs, modifications you name it we do it. Cupra console bushes at special price, PM for a very competitive quote.
Lummox is offline
The Following 4 Users Say Thank You to Lummox For This Useful Post:
BoilingPoint (07-08-2007), ColinD (25-07-2008), Fabia_TDI (13-08-2007), Shifty (04-08-2008)
Old 17-05-2007, 20:09   #2
Default Re: Resetting one touch windows
thanks
zugor is offline
Old 20-05-2007, 06:53   #3
GPW
Dieselslave
GPW's Avatar
great thanks lummox. worked on the wifes Audi and saved me a trip to the dealers
Mods: Rubber floor mats front and rear, Rubber boot liner
Rear centre headrest....Sexy
GPW is offline
Old 05-06-2007, 17:54   #4
lock car and immoboliser with remote control but leave front windows open
Shut the windows by inserting key in driving door lock turn cllockwise to close windows
One touch is now reset.
laurie is offline
Old 21-08-2007, 21:59   #5
neither have worked for me?
any further ideas?
Kablam is offline
Old 22-08-2007, 18:40   #6
Jon TDI's Avatar
From the manual:-
"Turn the key in the lock of the drivers door into the closing position & hold it there until all of the windows are closed.
Release the key.
Insert the key again & turn it to the closing position for about 3 seconds."
Black Magic SEAT Leon 2.0 TDI Sport - Green panel thingy, Upsolute jiggery pokery, Koni FSD/Eibach Pro Kit bouncy stuff, 18" Audi A8 Parabol rims, '08 Cupra black/honeycombe grille.
Also driving around in a Mini ONE that thinks it's a Cooper!
Jon TDI is offline
The Following User Says Thank You to Jon TDI For This Useful Post:
ColinD (25-07-2008)
Old 24-08-2007, 12:22   #7
I dunno if i'm doing somthing wrong, or perhaps its just busted.
Kablam is offline
Old 27-09-2007, 12:08   #8
Gizmo68's Avatar
I had a similar problem, the drivers window would open all the way with one touch, but not close (even after doing both of the suggested 'resets') it now does work sometimes, if you pull the switch up very hard, possibly a worn switch?
Gizmo68 is offline
Old 01-02-2008, 15:40   #9
are you talking about one touch from the inside controls or one touch from the remote?
I tried what I've read here, didn't work, the remote still has to be pressed all the way in order for the windows to go up completely
GunX is offline
Old 01-02-2008, 16:22   #10
You only get one touch windows from the key with an optional alarm, etc.
Everything here is about the inside door switches, namely resetting the recorded "fully up/down" position they use.
sebulbus is offline
Old 18-05-2008, 11:27   #11
thank you
magdy zaky is offline
Old 07-06-2008, 14:24   #12
Thumbs up Re: Resetting one touch windows
Thanks a lot .
happynow is offline
Old 25-07-2008, 10:43   #13
I have a fabia ll purchased nov 2007 and my windows just started playing up.
I just have front electric windows. Faults as follows:-
Passenger side one touch not working.
passenger switch on drivers side not working at all but very occasional start to work and stop again.
Driver side one touch not working 90% of time.
Have tried all the reset techniques which seem to start driver one touch working but then stops again very quickly.
Have rung dealer and as I live a distance away am going to try and call in when in the area so they can put it on diagnostic machine.
Any ideas?
sebdan is offline
Old 20-08-2008, 09:00   #14
Railroad's Avatar
My front passenger window will work one-touch up and down, but the drivers window will only work one-touch down, not up. I've tried the above reset procedure but without success. I'm not over concerned with it, but if anyone knows what the problem is I'd be grateful......
Railroad is online now
Old 21-08-2008, 09:46   #15
Need more power
martziniuk's Avatar
Mine sometimes work one touch and sometimes dont. Strange.
Regards Martin
Turbo back blueflame exhaust ,Forge FMDV006 Dump valve, Autobahn88 TIP, CAI ,Remapped, FMIC soon.....
SCN rolling road day 216.8bhp 264ft/lb (Dyno Dynamics)
martziniuk is offline
