This is a discussion on Selecting and Fitting a Dragon Tuning Box to a PD140 with DSG within the Technical Guides forums, part of the Skoda Model Discussion Area category; You won't recognise the user name but I am a long term Freedom member who wants his car to remain ...
| BANNED | Selecting and Fitting a Dragon Tuning Box to a PD140 with DSG You won't recognise the user name but I am a long term Freedom member who wants his car to remain untraceable during the warrantee period – possible paranoia creping in here Detailed here are my experiences of selecting, fitting and running a Dragon Digital Tuning Box on an Octavia PD140 with DSG box. There are a number of other suppliers offering similar digital tuning boxes for the PD140 and the following fitting process should be the same for all boxes that use the round harness connector mounted on the RH side of the engine. These are my personal experiences on how to upgrade your PD140 to effectively a PD170. All information is offered in good faith but I obviously can offer no warrantee that you will have the same results as me – use this guide with any information you can personally source to make your own decision. BACKGROUND - After reading all the posts here and following every Google I could find on the maximum torque a DSG box should/could handle and coming to the conclusion that while VAG state that 350nm is the max the DSG can handle, 360/5 is the max anyone is actually running with and then not for any length of time. The PD170 Passat is offered with the DSG and delivers a quoted 350nm. Most remaps appear to offer 370 to 390nm and all the suppliers say 'they have had no problems' but will not say how many DSGs they have actually remapped and how many miles they have covered without problems. Some remap companies appear to offer a drive train warrantee if their map causes problems but I would expect problems claiming £4,000 for a new box. Dragons claims of 168bhp and 360nm for a 'Power and Economy' map (though other figures are also quoted for different maps so check with Dragon if concerned) seemed like a good compromise to me – plus the unit is removable for Service and Warrantee and does not change any settings in the ECU which all remaps do. SO TO THE FITTING. The Unit comes with instructions but they are far from comprehensive. Following the instructions below should have the unit fitted in about 15 minutes but take your time for the first fitting.
IN USE – my experiences. At first I found that they while there was definitely more power available the motor was a little lumpy in traffic, steady 1500-2000 revs – there was also a slight increase in smoke. Before changing the internal settings in the Digibox – a jumper is adjustable in 7 positions to increase/decrease fuelling/power – I decided to fit a replacement panel filter even though the car has done less than 7000 miles. I chose a Pipercross filter from Awsome GTi – see site partners – a foam filter supplied dry with an oil spray if you choose to use it. I only used a tiny amount of spray as other posts warn that too much oil on a filter can cause problems with the sensors. The result was truly amazing, after fitting the filter the engine felt even stronger, the smoke virtually vanished and the engine runs perfectly smoothly under all conditions. It should also be noted that I run with the normal dilution of Millers Diesel Sport 4 in Tescos standard deisel, which may help get the best from these simple mods. Total cost, Box and Filter less than £230 inc postages – I consider this a bargain and a good trade against max power from a much more expensive Remap vs. limiting any potential damage to the DSG, plus removable when needed and has a decent resale value. |
| Briskodian | Re: Selecting and Fitting a Dragon Tuning Box to a PD140 with DSG Followed this guide and took a few pics which might help others: With Engine cover removed: IMG_1117 copy.jpg Identifying parts, note suggest uncliping of tube before moving filter cover: IMG_1118 copy.jpg Position of Engine Connector: IMG_1120 copy.jpg Dragon Box in place in front of battery box: IMG_1121 copy.jpg |
