39,449 Members 1,489,494 Posts
Skoda Option Codes Decoder
This is a discussion on Skoda Option Codes Decoder within the Technical Guides forums, part of the Skoda Model Discussion Area category; Ever wondered what all those codes printed in the front of the service book mean?. Follow the simple instructions and ...
Go Back   BRISKODA - The Skoda Forums > Skoda Model Discussion Area > Technical Guides
Old 04-07-2006, 18:24   #1
Ex-Moddy
Makefish's Avatar
Members Car: Golf PD105
Exclamation Skoda Option Codes Decoder
Ever wondered what all those codes printed in the front of the service book mean?. Follow the simple instructions and this clever piece of software decifers all these codes and tells you about your car.
Tip: Copy the example shown and edit accordingly, much quicker and easier
Superchips Bluefin only £390 @ JKM
http://www.jkm.org.uk/performance/bluefinxmas2008.htm
Makefish is offline
The Following 3 Users Say Thank You to Makefish For This Useful Post:
J555 JPG (13-08-2008), nlao (05-02-2008), pruddell (18-05-2008)
Old 04-07-2006, 20:44   #2
DGW
BRISKODA Staff
DGW's Avatar
Re: Skoda Option Codes De-coder
An excellent find and well worth bookmarking, although it doesn't give detailed decodes for some options for my 4X4. For example:
L50
Decoder = Suspension range 50
ETKA decode = front axle weight class - weight range G34: 686-735KG
1KE
Decoder = disk brakes, rear
ETKA decode = disk brakes 232X9MM rear
If you are friendly with your dealer, they might be willing to print out the Car Data for your vehicle which lists all the PR numbers, ie option codes. The Vehicle Data sticker for my car lists 44 PR numbers whereas the Car Data printout lists 173.
PS - I will be feeding all those options into the decoder to see what comes up.
Moderators note: Please use this thread to discuss options. This thread will be kept clean of questions.
Denis
DGW is offline
Old 04-07-2006, 21:34   #3
DGW
BRISKODA Staff
DGW's Avatar
Here is the complete decode for my 2002 UK spec RHD Octavia 1.8T 4X4 Estate. Where there are notable differences in the ETKA decodes, the latter are shown in italics.
A8D = luxury equipment
AZ0 = vehicle with standard production scope
B09 = type approval Great Britain and Northern Ireland
B0N = component parts set, complying with vehicle type for Great Britain, various parts
C00 = operating permit, initial registration
C6A = alloy wheels 6 1/2J x 16 SLX 4x4 version, offset 42
D2E = 4-cylinder gasoline engine 1.8 L/110 kW 20V turbo, base engine is T8C
E0A = no special edition
F0A = no special purpose vehicle, standard equipment
G0G = five-speed manual transmission for four-wheel drive vehicle
G34 = front shock absorption
..........heavy duty suspension - front - 4X4:KOMBI
H6U = tires 205/55 R 16 91W
J1L = battery 280 A (60 Ah)
K8D = Station Wagon Variant/Avant
L0R = right-hand drive vehicle
L50 = suspension range 50
..........front axle weight class>>>>>>>>>>>>weight range: G34:686-735KG
N2M = fabric seat covering
..........seat and backrest cover - cloth - ELEGANCE
Q4H = comfort sports seats, front
QA0 = without child seat
QG1 = service interval prolongation
..........extended service interval
QJ0 = without aluminum/chrome work package
QS0 = without electronic map cooling system
QV0 = without TV reception/digital radio reception
T8C = components for, base engine, unit 06A.C
..........4 cylinder petrol engine 1,8L/110KW 20V
U1B = instrument insert with mph speedometer, clock, tachometer and trip odometer
..........combi-instrument with revolution counter, clock and trip recorded (miles) - CAN BUS
V0A = tires without specification of tire brand
VC0 = without remote-controlled garage door opener
VK0 = air duct, standard
0A2 = four doors
0AR = front stabilizer
..........anti-roll bar - front - 19MM
0BL = rear stabilizer
0CH = vehicle class differentiation
0EJ = installation differentiation for transmission MQ 250 vehicle components
..........additional fitting parts for manual gearbox - DIESEL
0F2 = fuel system for carburetor gasoline engine
..........fuel system without fuel cooling - petrol
0FA = standard manufacturing sequence
0G4 = cable gearshift
0GE = emissions concept EU 3
0KA = without stickers and badges
0L2 = electric throttle actuation
0N5 = standard rear axle
..........rear axle mit track width>>>>>>wheel bearing: Standard
0NB = nameplate set in base trim
0RA = without ignition/starter switch locking system
0SS = labels/plates in English and French
0TA = without floor mats
0VF = information kit in English
0YZ = without determination of weight category for rear axle
1AT = electronic stabilization program (ESP)
..........anti-lock brake system - abs -, electronic differential lock - edl - and electronic stabilisation programme - esp -
1C1 = antifreeze up to -25 degree celsius tolerance up to -30 degree C
..........vehicle used in cold climates - -25C
1D0 = without towing attachment
1E1 = code not found :-(
..........activated charcoal filter canister for absorption of fuel vapour
1EX = special identification plate for EC
1G2 = steel spare wheel with original equipment tires
..........spare wheel with tyre instead of space-saving emergency spare wheel
1H0 = without proportioning valve
1JW = rear shock absorption, rough-road designfour wheel drive
..........spring and shock absorber for heavy duty suspension
1KE = disc brakes, rear
..........disc brakes 232X9MM rear
1LE = disc brakes, front
..........disc brakes 288X25MM front
1MP = steering wheel for airbag system
1N1 = power steering
1NL = covers for alloy wheels
1PC = wheel bolts with anti-theft protection (unlockable)
1Q0 = without mass damper for steering wheel
1SA = without additional engine guard
1T0 = without first aid kit and warning triangle
1X1 = four wheel drive
1Z2 = increase in initial standard fuel filling
2BS = code not found :-(
2C5 = axial and vertical adjustable steering column
2D0 = without cd enhancing underbody panel
2G9 = filler neck module 2 with insert
..........filler cap, lockable for fuel tank - BEZOVOLO
2LB = fuel tank with special material treatment (fluorination)
2UB = rough-road design
2V1 = dust and pollen filter
2W0 = fuel filler cap
3AV = outer right rear view mirror: non-spherical, powered, heated
3B0 = without additional child seat anchor
3BF = outer left rear view mirror: convex, powered, heated
3C7 = 3-point seat belt for center rear seat
3CA = without partition
3FE = electric slide/tilt sunroof with sun screen/sunblind
3GA = without cargo area
3H0 = without backrest release for front seats
3J7 = articulated and height-adjustable headrests for front seats
3L3 = manual height adjustment for front seats
3NC = rear seat bench/backrest, split folding
3Q6 = three rear headrests
3QT = 3-point seat belts with tensioner and height adjustment, front
3S2 = black roof rails
3U2 = sliding trunk cover
3V0 = without child bench seat
3X0 = without load-through provision
3ZG = 3-point seat belts, outer rear with height adjustment
4A0 = without seat heater
..........seat and backrest not heated
4B1 = protective side molding
4E0 = code not found :-(
4GC = windshield, tinted with sun band
4K3 = radio remote controlled central locking operated from inside and safe securing
4KC = side and rear windows tinted
4L0 = non-dipping breakaway inside rear view mirror
4LA = without controls
..........steering wheel without additional multi-function control elements
4M6 = cup holder
4N1 = padded dashboard
4P2 = rear floor panel module, type 3
4R4 = power windows with comfort operation and circuit breaker
4SC = left vanity mirror with cover
4TC = right vanity mirror with cover
4U1 = luggage nets/pockets on backrests
4UE = airbag for driver and front seat passenger
4W0 = without cassette and CD storage unit
4X1 = side airbag front
4Z3 = lockable glove compartment door, with light
5C0 = without special body measures
5D1 = carrier frequency 433.92 MHz
5K1 = paint preservative (wax)
5TC = without decorative inserts
6A0 = without fire extinguisher
6E3 = code not found :-(
6FB = body-colored outer rear view mirror housings
6KA = radiator grille
6M2 = load safety net
6N1 = mud flaps rear
6P1 = license plate bracket rear (ECE)
6PA = plastic hand brake lever handle
6Q1 = plastic gearshift ****/handle
6R1 = leatherette gearshift boot
6SC = tufted trunk floor covering
6W0 = without license plate bracket front
6XD = outer rear view mirrors: powered, heated
6Y0 = without cruise control warning system
7A2 = CD changer
7AA = electronic vehicle immobilization device
7E0 = code not found :-(
7N0 = without tray on roof liner
7P4 = manually adjustable lumbar support in front seats
7PB = platform group class 2
7Q0 = without navigation device
7QA = without CD ROM
7X0 = without park distance control
8BQ = halogen headlight for right-hand drive
8CC = speedometer sensor without seal (electronic speedometer sensor)
8F2 = side turn signal lights
8GD = alternator 90A
8K0 = without special low beam mode
..........without day driving lights
8L3 = roof antenna
8M1 = rear window wiper and washer system with intermittent control
8N4 = windshield wiper intermittent control with potentiometer (four speeds)
8NA = without parking light warning light
8Q1 = headlight-range adjustment
8QK = key for locking system
8R1 = center high-mounted stop light
8RM = eight loudspeakers (passive)
8S4 = two reading lights front, two rear
8SA = taillight assemblies, standard design
8T0 = without cruise control system (CCS)
8TD = rear fog light for driving on the left
8W1 = washer fluid level indicator
8WD = integrated front fog light
8X1 = headlight washer system
8Y1 = two-tone horn
8YD = radio for middle-class vehicle
..........stereo radio with cassette with cd changer control and telephone connection, control via multi-function steering wheel - SYMPHONIE
8Z5 = engine cooling system, type 1
9A0 = without taxi alarm system
9AK = Climatronic with impact pressure control free of cfc
9BC = display and warning tone for opened doors
9D0 = without preparation for two-way radio installation
9J0 = without supertone system and tone sequence control
9M0 = without auxiliary/parking heater
9P1 = seat belt warning light, electric contact in buckle
9Q1 = multi-function indicator/trip computer
9T0 = without heated washer nozzles
9TB = additional warning lights (door area)
9U1 = brake pad wear indicator
9W0 = without car phone preparation/installation
9X0 = without heated door lock cylinder
Denis
DGW is offline
Old 05-07-2006, 16:17   #4
Ex-Moddy
Makefish's Avatar
This is off my OctyII vRS just for reference. Would be interested to see a few more posted up.
5SJ = outer left rear view mirror: convex
5RV = outer right rear view mirror: non-spherical
1KP = disc brakes, rear
6FB = body-coloured outer rear view mirror housings
3FA = without roof insert (standard roof)
1N3 = speed-related variable steering assist (Servotronic)
H7D = tires 225/40 R 18 92Y xl
4UF = drivers and front passenger airbag with front passenger airbag deactivation
3NW = rear seat bench/backrest, split folding with centre armrest
8L3 = roof antenna
7AH = electronic vehicle immobilization device with alarm system, passenger compartment control and backup horn
8GU = alternator 140A
8YL = radio with CD player
8QL = key for locking system with remote control
8X0 = without headlight washer system
G07 = front shock absorption
QN1 = drawer under left front seat
8WR = front fog lights
7A2 = CD changer
0GG = emissions concept EU 4
L55 = suspension range 55
3S4 = preparation for roof load rack
2UC = sports version
Makefish is offline
Old 05-07-2006, 18:02   #5
huddo's Avatar
Members Car:
Here's my Furby vRS equipment list
1AP = anti-spin regulation (ASR) with electronic differential lock (EDL), lightweight design
1N2 = power steering electro-hydraulic
H2J = tires 205/45 R 16 83W
4R2 = power windows front, mechanical window regulators rear
4X0 = without side airbag
8L3 = roof antenna
J0L = battery 340 A (70 Ah)
7AH = electronic vehicle immobilization devicewith alarm system, passenger compartmentcontrol and backup horn
9AP = semi-automatic air conditioning
8UE = radio with CD drive
B09 = type approval Great Britain and NorthernIreland
G04 = front shock absorption
3L2 = manual height adjustment for right front seat
9P0 = without seat belt warning light
7A0 = without CD changer/CD player
QG0 = without service interval prolongation
0GZ = emissions concept EU 3
L35 = suspension range 35
7P0 = without lumbar support in front and rear seats
huddo is offline
Old 06-07-2006, 11:33   #6
roo
Ding, dong
roo's Avatar
Images: 4
Octavia II Elegance
1KF = disc brakes, rear
H6L = tires 225/45 R 17 91with Y tire width restricted to 219mm
4RA = without seat belts second row of seats
3NW = rear seat bench/backrest, split folding with center armrest
8L3 = roof antenna
J0N = battery 330 A (61 Ah)
9VJ = sound package
8YM = radio with CD player (high-end)
7X1 = ultrasonic park distance control
8WB = front fog lights
L58 = suspension range 58
Jeff: Ambitious, but rubbish
Originally Posted by topgear.com
The police use the Octavia Vrs because they don’t look fast enough to catch a cold. That’s cheating
roo is offline
Old 07-07-2006, 15:43   #7
2006 May Octy II Ambiente :
1AC = anti-lock brake system (ABS)
H6T = tires 205/60 R 15 V
4R4 = power windows with comfort operation andcircuit breaker
8L3 = roof antenna
8GG = alternator 110A
8WA = without front fog light
7A2 = CD changer
L02 = suspension range 02
2UA = standard design
mercian is offline
Old 10-07-2006, 12:07   #8
2006 Octavia 2.0 TDI PD Elegance estate
HH7 = tires 205/55 R 16 91V
8L3 = roof antenna
8YH = radio, version 1
0P1 = rear side exhaust tailpipe
BWB = code not found :-(
7A2 = CD changer
3GN = variable cargo area concept
L13 = suspension range 13
Paul
pbutterworth is offline
Old 14-07-2006, 18:36   #9
skodayouth's Avatar
2004 Skoda Octavia II Classic 1.6MPI
6FA = components without special surface appearance
1ND = full wheel covers
H7F = tires 195/65 R 15 91H
4R5 = power windows with comfort operation andcircuit breaker, mechanical window regulators rear
3NB = rear seat bench/backrest, completely folding
8L3 = roof antenna
J1P = battery 220 A (44 Ah)
9AA = manually controlled heating system
8RE = four loudspeakers (passive)
8QA = key without LED
4F1 = central locking system
G02 = front shock absorption, standard 2
QN0 = without drawers under front seats
L29 = suspension range 29
Skoda Octava II Estate 1.9DSG Elegance
Anthracite Grey
Skoda Fabia 3 1.6 Tiptronic
Storm Blue
skodayouth is offline
Old 14-07-2006, 20:53   #10
Taztastic's Avatar
Week 22 MY2007 Octavia Elegance
8L3 = roof antenna
8GV = alternator 180A
7Q7 = navigation system with color screen
8AY = radio/navigation system
9WQ = code not found :-(
7A2 = CD changer
L59 = suspension range 59
I'll stop wearing black when the invent a darker colour
Taztastic is offline
Old 16-07-2006, 09:03   #11
Members Car:
Smile Re: Skoda Option Codes De-coder
Here's mine: Octavia tour 2006, 1.6, North Africa specs:
3BS = outer left rear view mirror: non-spherical, powered, heated
3AF = outer right rear view mirror: convex, powered, heated
1K0 = without clutch actuation
1N6 = power steering
1NH = full wheel covers
H3E = tires 195/65 R 15 V (black)
4UC = airbag for driver
8L3 = roof antenna
8QD = key for locking system
9AB = manually controlled air conditioning
8YP = radio "MID"
B54 = special requirements North Africa Egypt, Algeria, Libya, Morocco, Tunisia
Q07 = suspension range 307
3L1 = manual height adjustment for left front seat
Q1A = standard front seats
3QA = without front restraint system
0GF = emissions concept D3 (EU 3D)
L16 = suspension range 16
Shades
shades is offline
Old 17-07-2006, 03:07   #12
PEMBO's Avatar
Location: Middlesbrough, home of legends :P (not the worst place in the UK at all...honest guv)
Members Car: 1.4 16V Fabia Comfort
Skoda Fabia 1.4 16v 2001 Comfort:
Note, Remote central locking and fitted mats were thrown in after a s/h deal - using official skoda parts and they fitted the parts too.
1KK = disc brakes, rear
1AJ = anti-spin regulation (ABS/ASR/EDL) with electronic differential lock (EDL)
H0G = tires 185/60 R 14 H
8L3 = roof antenna
8YJ = radio, version 2
1GA = front shock absorption, basic design 1
J03 = suspension range 03
PEMBO is offline
Old 18-07-2006, 11:20   #13
Irf
Irf's Avatar
Members Car: Furby vRS
Dec 05 Furby VRS:
4A3 = seat heater for front seats separately controlled
8L3 = roof antenna
QN2 = drawer under right front seat
7A2 = CD changer
FURBY VRS: cruise, xenons, ESP, heated seats, Revo, Eibachs, Koni FSDs, PD160 pipe, Jabba rear arb, Allard EGR pipe, EGR totally removed, Powertec induction kit, Milltek full system, Garrett GT17, Forge FMIC, 17" Octy wheels, debadged, side strips removed, Seat Cupra splitter, 312mm brakes...
ICE: Alpine 9835, Alpine changer, Alpine X-Type sub, Alpine MRDM1000 & MRFV340 amps, Alpine Remote Amp Controller, Boston Acoustics Pro60....
NEXT: re-remap & clutch
Irf is offline
Old 27-07-2006, 20:35   #14
Tapsa's Avatar
Members Car:
Re: Skoda Option Codes Decoder
-01 Octavia 1.9 TDI Ambiente HB
1KG = drum brakes, rear
H6S = tires 195/65 R 15 V
8L3 = roof antenna
J0R = battery 380 A (80 Ah)
8GL = alternator 120A
8AA = without radio
8QC = key with light
B05 = type approval Finland
G14 = front shock absorption
Tapsa is offline
Old 03-09-2006, 08:43   #15
BRISKODA Staff
mannyo's Avatar
Sept 05 Octavia Elegance 2.0 PD TDi Combi (Estate)
8L3 = roof antenna
Manny
2005 Octavia 2.0TDi Elegance combi
my skoda website http://www.octaviars.co.uk
Join the briskoda.net folding team click Here for more info
mannyo is offline
Old 13-09-2006, 15:14   #16
andy2407's Avatar
Members Car: Yellow Fabia vRS
October 04 Octavia 2.0 TDi Elegance Hatchback
3NU = rear seat bench unsplit, backrest split folding with center armrest
8L3 = roof antenna
J1D = battery 380 A (72 Ah)
7A2 = CD changer
The future's bright
The future's mellow
Now with a little zest of Washbrook added
andy2407 is offline
Old 05-01-2007, 01:22   #17
Briskoda Staff
auroan's Avatar
My 03 Octy vRS Estate
Mine were
2ED = disc brakes, rear
8L3 = roof antenna
9VE = digital sound package
8YP = radio "MID"
G35 = front shock absorption
7A2 = CD changer
L23 = suspension range 23
'05 Audi A4 2.0 Tdi SE - no mods until the warrenty expires ... yeah right... interior light pack, 3 spoke mfsw.
'00 Audi A4 2.8 Quattro - Gone.... (bleeding money pit )
Audi A4 2.6 Avant (Breaking - Check out http://shop.ebay.co.uk/merchant/auroan)
auroan is offline
Old 05-01-2007, 01:56   #18
stuart_hatch's Avatar
Members Car: Fabia
Fabia SDI comfort:
1KM = drum brakes, rear
1AN = lightweight anti-lock brake system (ABS)
H2Z = tires 185/60 R 14 T
8L3 = roof antenna
8UK = radio 2007 "Sound2"
8QE = key for locking system with remote control
L06 = suspension range 06
stuart_hatch is offline
Old 07-01-2007, 12:37   #19
SimonJ's Avatar
December 01 Octavia 4x4 estate
