This is a discussion on Superb - Engine coolant temperature sensor within the Technical Guides forums, part of the Skoda Model Discussion Area category; This is how I changed the engine coolant temperature sensor with help from a mate. This job needs a second ...
| Briskodian Join Date: Mar 2008 Location: Surrey
Members Car: Superb TDI 130 comfort Thanks: 5
| Re: Engine coolant temperature sensor This is how I changed the engine coolant temperature sensor with help from a mate. This job needs a second pair of hands as you cant reach for the new sensor and the tools you need whilst removing the old sensor. If you choose to do this yourself you do so at your own risk. Make sure the engine is cold! The old sensor has part #078919501C, whilst the new sensor has part# 059919501A you are also best to get a new o ring and a new clip just in case. If your coolant is on minimum, you might want some more of that too. 1. Remove engine covers 2. Remove under tray - both parts 3. Unclip large hose to allow room to work 4. Remove electrical connector from sensor using flathead screwdriver best done from underneath 5. Remove sensor retaining clip - best done from underneath 6. Remove old sensor and quickly put your finger in the hole to stop coolant leaking best done from above 7. Remove the finger bringing with it the old o ring quickly place another finger in the hole to prevent further coolant leaking best done from above 8. Remove finger and quickly place new sensor (fitted with new o ring) into place you will lose a bit more coolant best done from above 9. Fit the new clip 10. Re fit the wiring to the new sensor 11. Refit large hose, engine covers and under tray job done Here is an image of the engine bay from the offside, the sensor is circled in red ![]() Here is a close up photo of the sensor ![]() The car now runs better, I am getting a higher mpg - maybe the engine was running rich with a dud sensor? Much thanks to my mate for all his help ![]() Any questions please ask away. |
| The Following User Says Thank You to porlkertus For This Useful Post: | irfant (17-05-2008) |
| Engine coolant temperature sensor | porlkertus | Superb | 10 | 17-05-2008 17:23 |
| engine coolant temperature sensor | kerr01uk | Diagnostics & VAG-COM | 4 | 29-06-2007 10:30 |
| How can you check that the Engine coolant temperature sensor is working? | fel123 | Favorit, Felicia, Fun and Forman | 15 | 21-05-2007 18:19 |
| Coolant Temperature Sensor | pittVRS | Maintenance & Performance | 7 | 26-01-2005 20:53 |
