This is a discussion on TDi Fuel Cooler within the Technical Guides forums, part of the Skoda Model Discussion Area category; Im just about to do this to my furby, and found this thread, so thought id post it up... SEATCupra.net ...
| Briskodian Join Date: Dec 2007 Location: Chippenham
Members Car: 53 Fabia vRS Thanks: 24
| TDi Fuel Cooler Im just about to do this to my furby, and found this thread, so thought id post it up... SEATCupra.net - Your #1 source for SEAT information - The Diesel Fuel Cooler Guide If your doing this, the pic's showing you where to split the pipe is slightly wrong, you will need to place your cooler imbertween the top fuel line on your engine and the center take-off on the filter (round thing in the right of your engine bay). HTH some people who like power, and ill post up my pic's after im done. Dave
__________________ '53 Fabia vRS. Pro Race 2's, PD160 intake, Green Cotton Filter, Pikey Intercooler Mod x2, 312mm Brakes. Debaged Rear End. Fixed The Rear Door Leak! Ready to fit: 19Row Fuel Cooler, Braided Fuel Line. To Buy: FSD's, FMIC, LSD, Devils Own Water/Meth Injection, Clucth, SM Flywheel, Hybrid Turbo + Remap. ££££ |
| Re: TDi Fuel Cooler Also, where it says 'You are here....Home , Info Base , Fitting Guides , '. Click on the 'Fitting guide bit for more great links'. Dave
Members Car: Skoda Fabia Mongrel Images: 5 Thanks: 75
| Re: TDi Fuel Cooler I have the components in a box ready to be fitted this saturday all being well. ![]()
__________________ Jason - Only a Skoda. Custom Fabia Bonnet Lifter Kits - £45! Click Me. Cheesy bonnet lifter video to "raise me up" http://www.youtube.com/watch?v=hMnGECEi5Oc See the mongrel's 260bhp Dyno Video! |
| Briskodian Join Date: Jun 2007 Location: Brecon/ Cardiff
Members Car: 04 Fabia vRS (180/300) Thanks: 26
| Re: TDi Fuel Cooler what sort of power gains would you see?
__________________ '04 Fabia VRS - P-Torque STG1, 312mm Brakes, Whiteline RARB, SEAT Sport Strut Brace, Pipercross Panel Filter & PD160 Intake, Pioneer and Infinity ICE, Custom exhaust system w/ de-cat, CCV Bypass w/ Catch Can, Boost + Volt Gauge, Window Tints |
| Re: TDi Fuel Cooler marginal. But having cool fuel will always be good in the long run, and for "consistent" performance - Much in the same way an FMIC works I guess.
| Re: TDi Fuel Cooler what do they retail at?
| Re: TDi Fuel Cooler I got a 19 row cooler for £25 delivered, and a load of braded hose for next to nothing. i reckon about 1.5/2hp on a hot day, for around £45 (mine is going in the arch, where the intercooler is, but it will cool better with the FMIC fitted and SMIC out the way). HTH, Dave
| Re: TDi Fuel Cooler Mocal tends to be a bit more. I paid a shade under £70 for the mocal 10 row cooler, 2 fittings, and delivery.
| | #9 | |
| Briskodian Join Date: Oct 2006
Members Car: 02 Octavia 1.9 SDI Classic Thanks: 1
| Re: TDi Fuel Cooler Quote:
I have a 1.9TDi Pasat105 remapped to 145bhp (no other mods at all but would consider doing this mod at the right price for consistent summer performance) <edited for bad >
__________________ OctaviaBuzz - '02 Octavia 1.9SDi Current Status: 83k miles, currently averaging 51.5mpg | |
| | #10 |
| Briskodian Join Date: Mar 2005 Location: Peterborough
Members Car: Fabia vRS Thanks: 0
| Re: TDi Fuel Cooler There is already one fitted underneath the car, i assume this is in addition?
__________________ Fabia vRS - Black Magic, Lowered 25mm, Aero Wipers, Removed side strips, Retrofit 3rd Rear Headrest, Few VAGCOM tweaks, Audi TT 17" Wheels arriving soon! Previous Cars: Mini Cooper S, SEAT Ibiza Cupra TDI, Mazda RX8, Ford Cougar V6, Mk2 Golf GTI 16V |
| | #11 |
| Re: TDi Fuel Cooler There is one under the car yes, but it's not that efficient. Mine is now fitted, bolted to the underside of the slam panel and well vented via the grille. Also gives me some more "engine bay bling" ![]() It was quite good as when leak testing you could feel it warming up a lot, even just on tickover. Hopefully it will do a good job for the future. ![]() No pics yet. First people to see will be at TRAX tomorrow. ![]()
| | #12 |
| Re: TDi Fuel Cooler You may ask... eBay Seller: trashspeedcameras: Cars, Parts Vehicles items on eBay.co.uk The link above is the seller (on ebay), but he hasnt got any at the mo. Just look on ebay tho. My 19 row one is about 150mm x 250mm. so quite big. HTH. Dave
| | #13 |
| Briskodian | Re: TDi Fuel Cooler Make up a how to guide when you do as i'll likely do this
__________________ Star Remap, BMC, Helix, 312's, Magnex, Vibratechniks mount, Allard Power Pipe, VMaxx Coilies, CCV mod, Pikey Short Shifter, Stainless Boost pipes, Pikey arch mod, HID's, 17's, Heated Seats, Cruise + many more ![]() |
| | #14 |
| Re: TDi Fuel Cooler My only thought (which will probably get answered in a mo) is, does the fuel system need priming/bleeding. I dont think it does as the tank pump will prime the system... right? Dave
| | #15 |
| Re: TDi Fuel Cooler O, and i forgot to say. Im using braided hose to A) Keep heat out, and B) so it doesnt rub through on anything. Will be replacing all fuel lines in the engine bay probably.
| | #16 |
| Briskodian | Re: TDi Fuel Cooler |
| | #18 |
| | #19 | |
| Briskodian Join Date: Sep 2007 Location: Walderslade, Maidstone
Members Car: Fabia vrs Special Edition. Thanks: 9
the one under the car is quite a side and would have thought if possible to be moved to vertically mounted it would be a large item for cooling...
__________________ Neil, Fabia VRS SE, PD160, Green cotton filter, Jabba Rear ARB, Front strut Brace, wheelarch mod, generic re-map for quick upgrade installed (proper remap once all parts on car required) 145BHPish at present... ![]() (Allard EGR, 312mm Occy Brakes, Eibach springs, full blueflame exhaust system inc sports cat downpipe & samco intercooler hose kit, all still awaiting fitment ) off for a full re-map once all done one day... | |
| | #20 | |
| Briskodian | Re: TDi Fuel Cooler Quote:
This keeps the temperatures down and is partly requires as the car has a plastic fuel tank. Add to that you don't really want roasting hot fuel in the tank. I'd say don't bother myself as nearly all the time during the year you're not going to benefit from it on a derv. If you want to throw some money away I'd get the EGR, intercooler and associated pipework all cleaned out, a clean air filter and an oil change. This will probably have more of an effect than a fuel cooler.
__________________ Cars make CO2 and trees absorb CO2. By driving your car you're feeding a tree and helping the environment. | |
| | #21 |
| Re: TDi Fuel Cooler I probably should put up pics of my install of the seatcupra.net fuel cooler mod. ![]() This is it fitted to the underside of the slam panel area. It sits nicely in there, at least when you have no aircon.... ![]() ![]() This is the "bigger picture" taken on a dyno day shortly after. You can see it in there sneaking out. ![]()
| | #22 |
| Briskodian | Re: TDi Fuel Cooler Thought the idea of a fuel cooler was like cheezemonkhai said. cools the fuel returning to the tank so you dont get warm fuel in your tank causing condensation.? Maybee wrong. |
| | #23 |
| Re: TDi Fuel Cooler might have that side effect, but primarily cool fuel = more power. (a bit)
| Diesel fuel cooler | sainz | Fabia I | 6 | 14-05-2008 10:48 |
| Fuel cooler + mount idea? | Basil | Maintenance & Performance | 14 | 12-05-2008 14:45 |
| MOCAL Fuel Cooler | SILVERSAUSAGE | Fabia I | 18 | 24-12-2007 12:16 |
| Fabia TDI fuel | Kev Brown | Maintenance & Performance | 4 | 03-12-2006 21:42 |
