This is a discussion on Tips: Felicia Tips within the Technical Guides forums, part of the Skoda Model Discussion Area category; Please post any little tips or tricks you have with your Felicia here please....
| Site owner Join Date: Oct 2002 Location: Hill & Mountains of North Wales
Members Car: Roomster Scout Images: 3 Thanks: 29
| Tips: Felicia Tips Please post any little tips or tricks you have with your Felicia here please.
__________________ ColinD 1.9 Scout Roomster - Standard ![]() www.BRISKODA.net :: Site Owner E-Mail : webmaster at briskoda dot net Got a comment to make about the site? Please feel free to use the feedback form here, we welcome your views. |
| Briskodian Join Date: Feb 2006 Location: suffolk
Members Car: 1998 Skoda Felicia 1.3gli estate MET - tuned Thanks: 0
| Re: Tips: Felicia Tips Being the owner of a '98 Felicia estate, I have a few tips for you all to ponder - mostly these are cosmetic, but all are cheap! Headrest covers, available from ebay, can help to cheer the interior up (unless you like grey...) I've changed the headlight bulbs, as the originals were puny. This is a definite improvement, as i now can see where I am going. I suggest xenon bulbs, along with getting the headlights adjusted. I also found the 1.3mpi engine was a touch weak, so I got rid of the airbox and fitted an induction filter. This helps to improve the acceleration slightly, and gives the engine a throaty roar - very nice! I hope these are some use to you all, and if anyone has any ideas on how to improve the handling of my estate cheaply, please let me know! |
| The Following User Says Thank You to minycooper For This Useful Post: | DAVE WESTON (09-06-2008) |
| New to Posting | Re: Tips: Felicia Tips I found the thermostat housing on the 1.6MPI engine a very poor design... Modified the housing to be assembled with 40mm M6 bolts and nuts in place of the weak self-tappers hanging on to the plastic helicoils!! Simply drill the plastic housing with a 6mm drill bit, then the 2 halves of the housing go together a lot more securely! |
| not a bird!!! Join Date: Sep 2006 Location: pixi said not to fill my box
Members Car: 1.6l felicia 1998 Thanks: 1
| Re: Tips: Felicia Tips get a 22mm anti roll bar off a vw caddy (97 on) stiffens it up no end. |
| The Following 2 Users Say Thank You to pinkskud For This Useful Post: | anewman (01-09-2008), DAVE WESTON (09-06-2008) |
| Briskodian Join Date: Jul 2007 Location: Sheffield
Members Car: Felicia Estate. 1.3mpi, 1998 Thanks: 0
| Re: Tips: Felicia Tips Hi, I have started using a Semi-synthetic engine oil, this along with an Induction kit seems to have released a few more horses! Kev. |
| Briskodian | Re: Tips: Felicia Tips If you have the grundig radio cassette the wiring to add an aux input is in the radio handbook. A few crimp tags and an old headphone cable and I had direct MP3 i/p. I dropped the cable down the back of the radio and the player sat in the centre console (remove the ashtray for extra access during fitting). You do need the radio removal tools and the handbook! I can post pictures from the manual if needed but I've just moved from the 99 Felicia to to a 52 Fabia so I can't look at how I did it. DaveF |
| Briskodian | Re: Tips: Felicia Tips About 70K miles I started getting the engine stalling when coming out of overrun (ie when declutching after engine braking). Easy to bump it back but loss of PAS and brake servo was nasty. Garage quoted 200/300+VAT for a new throttle body which they weren't sure would fix it. Got them to fix a scrap throttle body (a few bolts could have done it myself) and all as good as new! DaveF |
