This is a discussion on VAG-COM: Octavia Climatronic display within the Technical Guides forums, part of the Skoda Model Discussion Area category; Control codes are listed below for the Climatronic display in the Octavia. To access the Climatronic's maintenence mode, press the ...
| Site owner Join Date: Oct 2002 Location: Hill & Mountains of North Wales
Members Car: Roomster Scout Images: 3 Thanks: 29
| VAG-COM: Octavia Climatronic display Control codes are listed below for the Climatronic display in the Octavia. To access the Climatronic's maintenence mode, press the following 3 Climatronic pushbuttons at the same time: Cold (blue - reducing interior temperature), Blower slower (fan speed down), and ECON. Scroll through the settings shown on the Climatronic using the two temperature keys (Blue and Red) The best function is on channel 16, because the current speed is digitally indicated there! 00 = total placing value, 0=max. cool, 255 max. heat 01 = interior temperature sensors (at the operating sector of the Climatronic) 02 = average sun exposure index 03 = sun exposure index in mW/cm² 04 = outside temperature bumper (averaged) 05 = current value: Outside temperature bumper 06 = temperature fresh air suction port (?) 07 = temperature Fussaustroemer 08 = temperature, but no feeler attached 09 = blower regulation (one can with +/- blower engine regulate) 10 = blower strength 11 = temperature flap (0 = max. warmly, 255 = max. coldly), (+/) 12 = flap torso (+/) 13 = flap circulating air (+/) 14 = flap for windshield (+/) 15 = time since engine start in seconds of 16 = speed (Digitaltacho) (kmh = metric, mph = imperial) 17 =? 18 = mostly is 0. Sporadically I had there 65, 68 and 69 (wenn's very, very hot). No idea, which means it. 19 =? 20 =? 21 =? 22 =? 23 =? Temperature identification with #7?! 24 = act. Temperature heat flap od.: one over +/- adjustable temperature. I take to it am the maximally permitted temperature for NR. 23 and/or NR. 7, thereby the feet does not anbrennen 25 =? 26 = actual value of temperature flap 27 =? 28 =? 29 = actual value floor space? 30 =? 31 =? 32 = actual value of circulating air flap 33 =? 34 =? 35 = actual value of window nozzle (Defroster nozzle or as **** yourself calls) 36 =? 37 =? starting from 38 stand firm worth: 38 = 10 39 = 0 40 = -51°C 41 = 0 42 = 3 43 = 2 44 = 0 info provided by member jeanluc.
__________________ ColinD 1.9 Scout Roomster - Standard ![]() www.BRISKODA.net :: Site Owner E-Mail : webmaster at briskoda dot net Got a comment to make about the site? Please feel free to use the feedback form here, we welcome your views. |
| Briskodian Join Date: Feb 2006
Members Car: VW Golf 2.3 V5 2001 Reflex Silver Thanks: 0
| Re: VAG-COM: Octavia Climatronic display Hi Sorry if this sounds like a stupid question, but i'm presuming these modes are to change a certain part of the climatronic display, presumably the bit that would usually display the default reading ie the exterior temperature, to another option ie current speed? Or have I read this all wrong! Also, would you know if this is applicable to VW cars as the climatronic units are VW sourced? Cheers Baz
__________________ VW GOLF 2.3 V5 20V 170 2001. REFLEX SILVER ON SANTA MONICAS |
| Dinosaur Join Date: Oct 2002 Location: North of the Watford Gap
Members Car: Merc E class & SLK Thanks: 19
| Re: VAG-COM: Octavia Climatronic display Indeed they would, but some of the numbers / blocks are different. Think VW use 15 for speed rather than the Skoda 16. And to think, people buy this info on eBay ![]() It is all freely available on tinterwebnet ![]()
__________________ A jolly sensible Mercedes E class saloon in a rather fetching bluey grey colour. No it isn't fast, no it isn't modded, and yes, it will still eat your Fabia for breakfast. Official mobile chicane for Briskoda trackdays ![]() |
| Briskodian Join Date: Jan 2004 Location: Ireland
Members Car: Skoda Octavia vRS Thanks: 23
| Re: VAG-COM: Octavia Climatronic display AFIK these codes and their values are only displayed when the climatronic unit is left in diagnostic mode. I have messed around with mine and it goes back to the default display once you get out of diagnostic mode (you cant adjust the airflow or temp in diagnostic mode).
__________________ Dear Lord.. The gods have been good to me. For the first time in my life, everything is absolutely perfect just the way it is. So here's the deal: You freeze everything the way it is, and I won't ask for anything more. If that is OK, please give me absolutely no sign. OK, deal. |
| Re: VAG-COM: Octavia Climatronic display Cheers for the repsonse guys So how would one go about setting a permanent change of display? Can it be done manually or will I have to call on a mate and his VAG.COM??
Members Car: Octavia 1.8T 4X4 Estate & Fabia vRS Thanks: 51
| Re: VAG-COM: Octavia Climatronic display You can change the display to indicate degreees Celsius or degrees Fahrenheit. Instructions for doing that are on page 95 of the Octavia Owner's Manual. That's it for permanent changes.
| Re: VAG-COM: Octavia Climatronic display Hmm thats a bit boring!
