Posts
97 -
Joined
Last visited
Profile Information
Interests
motor sport, drones,fishing
Location
london
Car Info
Model
octavia vrs 502bhp
Year
2018
Recent Profile Visitors
mattft86's Achievements
I can't say for sure if it will work with the mib3 I can't see Why not? You would need to find out for sure before risking it
3
That's my car. This is for my partners car a 2013 octavia.
No the only connection to a phone is via Bluetooth no carplay or droid auto.
Hmmm thing cost over £500 aswell. What would be a good replacement with wireless carplay/android auto?
If you translate this page it says it can. https://www.kenwood.de/car/technologie/canbus/
It's not showing however the head unit is on kenwoods supported canbus list.
mattft86 started following Blower problem , radio change and can some body help with rear fogs lights and rain close
Hi all i brought this for my partners car https://connects2.com/Product/ProductItem/CTUSK02 and I plugged the adapter into the car and then connected it to my kenwood dmx8019dabs but it dose not display any car info or car settings like it claims. Has anyone else fitted one and got it to work?
Hi all can someone please help with the coding for my car I'm trying to enable the second rear fog light but I'm not having much luck and also the rain closing for the windows. I followed this post about the rear fogs but i can't get them to work https://www.briskoda.net/forums/topic/299462-enabling-both-rear-fog-lights-with-vcds-led-cluster/ Wednesday,07,February,2024,15:05:02:01631 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 23.11.0.0 (x64) HEX-V2 CB: 0.4643.4 Data version: 20231027 DS351.0 www.Ross-Tech.com VIN: TMBBE7NE9J0284947 License Plate: Mileage: 87515km-54379mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: NE-SK37 (3Q0) Scan: 01 03 08 09 10 15 16 17 19 42 44 4B 52 5F A5 A9 D6 D7 VIN: TMBBE7NE9J0284947 Mileage: 87515km-54379miles 01-Engine -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: Malfunction 0010 10-Park/Steer Assist -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 42-Door Elect, Driver -- Status: Malfunction 0010 44-Steering Assist -- Status: OK 0000 4B-Multifunc. Module -- Status: OK 0000 52-Door Elect, Pass. -- Status: Malfunction 0010 5F-Information Electr. -- Status: OK 0000 A5-Frt Sens. Drv. Assist -- Status: OK 0000 A9-Struct. Borne Sound -- Status: OK 0000 D6-Light Ctrl Left 2 -- Status: OK 0000 D7-Light Ctrl Right 2 -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-CHHA) Labels:. 06K-907-425-V1.clb Part No SW: 5G0 906 259 P HW: 06K 907 425 B Component: 2.0l R4 TFSI H13 0001 Revision: --H13--- CVN: FFE2AF15 Coding: 0C1900122424010B0000 Shop #: WSC 12345 123 61029 ASAM Dataset: EV_ECM20TFS0205G0906259P 001001 ROD: EV_ECM20TFS0205G0906259P.rod VCID: 3B233A5D43E5C5223A1-806E VINID: 91D49254779525A0022042441CD661CF04 No fault code found. Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels:* 5Q0-907-379-ESP-V1.clb Part No SW: 5Q0 614 517 CS HW: 5Q0 614 517 AF Component: ESC H62 0973 Revision: 00000000 Serial number: 60418000001167 Coding: 24079391542821704080060440CA2924C92A8402600294762043F070C007430B00000012121212B835351919323200 Shop #: WSC 12345 123 61029 ASAM Dataset: EV_Brake1UDSContiMK100ESP 037009 ROD: EV_Brake1UDSContiMK100ESP_037.rod VCID: 045181A17E9B7ADA0BB-8050 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels:| 5G0-907-044.clb Part No SW: 5E0 907 044 AP HW: 5E0 907 044 AP Component: Climatronic H04 2002 Revision: 00001K00 Coding: 0111000400011001100500460010102A Shop #: WSC 12345 123 61029 ASAM Dataset: EV_ACClimaBHBVW37X 006147 ROD: EV_ACClimaBHBVW37X_006_VW37.rod VCID: 73B3D27D2B354D62221-8026 Fresh air blower control module (front): A/C pressure/coolant temperature sensor: Air quality sensor: No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:. 5Q0-937-08X-V2.clb Part No SW: 5Q0 937 084 CQ HW: 5Q0 937 084 CG Component: BCM MQBAB H H36 0253 Serial number: 01001803900033 Dataset Number: V03935276SP 0001 Coding: 000000000000000000000000000000000000000000000000000000000000 Shop #: WSC 12345 123 61029 ASAM Dataset: EV_BCMMQB 018001 ROD: EV_BCMBOSCH_018.rod VCID: 094F909559B927B278D-805C Wiper motor control module: Subsystem 1 - Part No SW: 5E2 955 119 A HW: 5E2 955 119 Labels: 5QX-955-119-V1.CLB Component: WWS371 180120 051 0915 Serial number: 887253F0401802000027 Coding: 164DDD Rain/Light Recognition Sensor: Subsystem 2 - Part No SW: 5Q0 955 547 B HW: 5Q0 955 547 B Labels: 5Q0-955-547.CLB Component: RLHS 047 0105 Serial number: TBY18M02D16H20M46S16 Coding: 00885D Anti-theft alarm system sensor: Subsystem 3 - Part No SW: 5Q0 951 171 HW: 5Q0 951 171 Component: Sensor, DWA 005 0316 Serial number: 000000000ZY173132X07 Alarm horn: Subsystem 4 - Part No SW: 5QD 951 605 HW: 5QD 951 605 Component: Sirene, DWA 005 0314 Serial number: 00002856223973542629 2 Faults Found: 0531 - Footwell Illumination B11FF 01 [00001001] - Electrical Failure Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 6 Fault Frequency: 1 Reset counter: 46 Mileage: 87046 km Date: 2024.01.20 Time: 17:30:14 Terminal 15 status: On Terminal 50 status: OFF CAN-Bus_aktiv: On Status Bremslichtschalter (HW): OFF Status Bremslichtschalter (CAN): OFF OFF: operated Position lamps: Not operated Automatic high beam assist: Not operated Low beam: Not operated Parking light left: Not operated Parking light right: Not operated last_wakeup: gültiges Funktelegramm Voltage: 12.1 V Outside temperature: 6.0 °C 919560 - Light Switch B126A 29 [00001000] - Signal Implausible Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 3 Fault Frequency: 1 Reset counter: 99 Mileage: 87341 km Date: 2024.01.31 Time: 19:05:43 Terminal 15 status: OFF Terminal 50 status: OFF CAN-Bus_aktiv: OFF Status Bremslichtschalter (HW): OFF Status Bremslichtschalter (CAN): OFF OFF: operated Position lamps: Not operated Automatic high beam assist: operated Low beam: Not operated Parking light left: Not operated Parking light right: Not operated last_wakeup: gültiges Funktelegramm Voltage: 12.1 V Outside temperature: 9.5 °C ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-283.clb Part No SW: 5QA 919 283 B HW: 5QA 919 283 Component: PDC 4 KanalH07 0044 Serial number: 000308419618039 Dataset Number: V03935256AE 0001 Coding: 0601050001 Shop #: WSC 12345 123 61029 ASAM Dataset: EV_EPHVA14AU3700000 009033 ROD: EV_EPHVA14AU3700000_009_SK37.rod VCID: 49CF5095193967B2B8D-801C No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb Part No SW: 3Q0 959 655 BH HW: 3Q0 959 655 BH Component: Airbag VW21 006 0703 Revision: -------- Serial number: 003W4P1DWN15 Dataset Number: V03935266KC 0001 Coding: 98CCC000000000005C5400CC008800000065 Shop #: WSC 73430 790 00000 ASAM Dataset: EV_AirbaVW21TS6VW48X 001014 ROD: EV_AirbaVW21TS6VW48X_VW37.rod VCID: 05579CA575A143D21C5-8050 Crash sensor for side airbag: driver side: Subsystem 1 - Part No SW: ----------- HW: 454 000 502 18 Component: SideSensor_Df 008 0887 Serial number: 3570000000080D84FB2X Coding: 2D2D2D Front Passenger's Side Airbag Crash Sensor: Subsystem 2 - Part No SW: ----------- HW: 454 000 402 18 Component: SideSensor_Pf 008 0887 Serial number: 358000000001BA186C2O Coding: 2D2D2D Rear Side Airbag Crash Sensor (on driver's side): Subsystem 3 - Part No SW: ----------- HW: 454 800 102 18 Component: SideSensor_Dr 301 0148 Serial number: 351009AEB5613000000P Coding: 2D2D2D Passenger side rear thorax airbag crash sensor: Subsystem 4 - Part No SW: ----------- HW: 454 803 101 18 Component: SideSensor_Pr 301 0148 Serial number: 352005FC06513000000E Coding: 2D2D2D Crash sensor for front airbag: driver side: Subsystem 5 - Part No SW: ----------- HW: 454 802 101 18 Component: FrontSensor_D 304 0149 Serial number: 35500AF851C13000000P Coding: 2D2D2D No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels:| 5Q0-953-549.clb Part No SW: 5Q0 953 507 GD HW: 5Q0 953 549 F Component: Lenks. Modul 003 0140 Revision: -------- Serial number: 17021804400858 Coding: 1400 Shop #: WSC 73430 790 00000 ASAM Dataset: EV_SMLSKLOMQB 020002 ROD: EV_SMLSKLOMQB_020_VW37.rod VCID: 7EA5F3491077100A5DF-802A No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3 Part No SW: 5E0 920 956 E HW: 5E0 920 956 E Component: KOMBI 303 0310 Coding: 27AD010069848E00010A6B021001000000000000 Shop #: WSC 12345 123 61029 ASAM Dataset: EV_DashBoardVDDMQBAB 009060 ROD: EV_DashBoardVDDMQBAB_009_VW26.rod VCID: 2E0503098097208A8DF-807A No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels:| 3Q0-907-530-V1.clb Part No SW: 3Q0 907 530 L HW: 3Q0 907 530 C Component: GW MQB High 436 4326 Revision: -------- Serial number: 0007427193 Dataset Number: V03935276GC 0001 Coding: 030100047F085900FB00026B080F00010001070000000000000000000000 Shop #: WSC 12345 123 61029 GVL: 01563C1000000000408C00000000480000000000000200000000000000000000 ASAM Dataset: EV_GatewNF 013044 ROD: EV_GatewNF_VW37.rod VCID: 3829255172D3EE3AD73-806C Generator: Multifunction steering wheel control module: Subsystem 2 - Part No SW: 3V0 919 719 A HW: 3V0 919 719 A Component: E221__MFL-PR6 H02 0160 Serial number: 000000000A2892090218 Battery Monitoring Control Module: Subsystem 3 - Part No SW: 5Q0 915 181 J HW: 5Q0 915 181 J Component: J367-BDMConti H03 1050 Serial number: 758860000018021525FE No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb Part No SW: 5Q4 959 593 B HW: 5Q4 959 593 B Component: TSG FS 009 0014 Serial number: 0000113427163 Dataset Number: 5E0222t____ 0013 Coding: 00150020D001040000001100 Shop #: WSC 73430 790 00123 ASAM Dataset: EV_DCUDriveSideEWMAXCONT 006001 ROD: EV_DCUDriveSideEWMAXCONT.rod VCID: 44D141A13E1BBADA4BB-8010 Rear Driver Side Door Control Module: Subsystem 1 - Part No SW: 5Q0 959 812 E HW: 5Q0 959 812 E Component: FOND_FHSG_DRV 006 0007 Serial number: 00000000000019301939 Coding: 1D0200 1 Fault Found: 65604 - Door Warning Lamp B1326 01 [00001000] - Electrical Failure Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 3 Fault Frequency: 1 Reset counter: 99 Mileage: 87341 km Date: 2024.02.01 Time: 14:57:34 ------------------------------------------------------------------------------- Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb Part No SW: 3Q0 909 144 L HW: 3Q0 909 144 L Component: EPS_MQB_ZFLS 507 5081 Dataset Number: V03935278BB 0001 Coding: 91170000 Shop #: WSC 73430 790 00000 ASAM Dataset: EV_SteerAssisMQB 015157 ROD: EV_SteerAssisMQB_015.rod VCID: 3B233A5D43E5C5223A1-806E No fault code found. ------------------------------------------------------------------------------- Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V1.clb Part No SW: 3Q0 907 338 HW: 3Q0 907 338 Component: FCM MQB Low 002 0286 Serial number: 10021810802742 Dataset Number: V03935265KN 0001 Coding: 000000070100046E00003D01010000000000000000000000000000000000 Shop #: WSC 73430 790 00063 ASAM Dataset: EV_MultiModulContiVW48X 001010 ROD: EV_MultiModulContiVW48X_001.rod VCID: 72BDD779542F446A297-8026 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb Part No SW: 5Q4 959 592 B HW: 5Q4 959 592 B Component: TSG BFS 009 0014 Serial number: 0000112829126 Dataset Number: 5E0157t____ 0013 Coding: 00150020D001040000001100 Shop #: WSC 73430 790 00123 ASAM Dataset: EV_DCUPasseSideEWMAXCONT 006001 ROD: EV_DCUPasseSideEWMAXCONT.rod VCID: 43D342BD3B15BDE2721-8016 Rear Passenger Door Control Module: Subsystem 1 - Part No SW: 5Q0 959 811 E HW: 5Q0 959 811 E Component: FOND_FHSG_PSG 006 0007 Serial number: 00000000000019346783 Coding: 050200 1 Fault Found: 65604 - Door Warning Lamp B1326 01 [00001000] - Electrical Failure Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 3 Fault Frequency: 1 Reset counter: 91 Mileage: 87151 km Date: 2024.01.22 Time: 15:06:06 ------------------------------------------------------------------------------- Address 5F: Information Electr. (J794) Labels:| 3V0-035-MIB-STD2.clb Part No SW: 5Q0 035 874 C HW: 5Q0 035 874 C Component: MU-S-ND-ER H41 0480 Serial number: SKZAZ2U0432698 Dataset Number: V03935278EJ 0001 Coding: 03735101FF00000041111201008800002F0209D601200500CF Shop #: WSC 19460 666 12345 ASAM Dataset: EV_MUStd4CTSAT 001022 ROD: EV_MUStd4CTSAT_VW37.rod VCID: 343111616EBB0A5AFBB-8060 Display and control head 1 for information electronics: Subsystem 1 - Part No SW: 5E0 919 605 M HW: 5E0 919 605 M Component: ABT_Std-2_Nav H50 8130 Serial number: SKZ6ZHV0482961 Data carrier: Subsystem 2 - Part No SW: V03 959 820 F HW: ----------- Component: ECE1 2023 --- 1910 Serial number: -------------------- No fault code found. ------------------------------------------------------------------------------- Address A5: Frt Sens. Drv. Assist (R242) Labels:| 3Q0-980-65X-A5.clb Part No SW: 3QD 980 654 HW: 3Q0 980 654 A Component: MQB_B_MFK H07 1272 Serial number: 09011841K11269 Dataset Number: V03935268CW 0001 Coding: 0203070100000401000213408150A80094000E200020 Shop #: WSC 12345 123 61029 ASAM Dataset: EV_MFKBoschMQBB 001001 ROD: EV_MFKBoschMQBB_001_VW36.rod VCID: 0849959142B35EBA673-805C No fault code found. ------------------------------------------------------------------------------- Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb Part No SW: 5E0 907 159 HW: 4H0 907 159 A Component: SAS-GEN 2 H06 0001 Serial number: 180120204166 ASAM Dataset: EV_SoundActuaGen2AU64X 003010 ROD: EV_SoundActuaGen2AU64X.rod VCID: 698FB01579F987B298D-803C No fault code found. ------------------------------------------------------------------------------- Address D6: Light Ctrl Left 2 (A31) Labels: 7P5-941-591.clb Part No SW: 7P5 941 591 AD HW: 7P5 941 591 A Component: LED1L H06 0005 ASAM Dataset: EV_LED_PLUS_L_KEBODAVW416 001003 ROD: EV_LED_PLUS_L_KEBODAVW416.rod VCID: 7EA5F3491077100A5DF-802A 1 Fault Found: 0800 - Bulb for Low-Beam Headlamp C1198 F6 [00101000] - Over-Temp Protection Active Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 2 Fault Frequency: 1 Reset counter: 0 Mileage: 87413 km Date: 2024.02.03 Time: 23:48:08 ------------------------------------------------------------------------------- Address D7: Light Ctrl Right 2 (A27) Labels: 7P5-941-591.clb Part No SW: 7P5 941 591 AD HW: 7P5 941 591 A Component: LED1R H06 0005 ASAM Dataset: EV_LED_PLUS_R_KEBODAVW416 001003 ROD: EV_LED_PLUS_L_KEBODAVW416.rod VCID: 7EA5F3491077100A5DF-802A 1 Fault Found: 0800 - Bulb for Low-Beam Headlamp C1198 F6 [00101000] - Over-Temp Protection Active Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 2 Fault Frequency: 1 Reset counter: 0 Mileage: 87413 km Date: 2024.02.03 Time: 23:46:47 End----(Elapsed Time: 01:28, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
Retrofitting cruise control
mattft86 replied to mattft86's topic in Skoda Octavia Mk III (2013 - 2020)
If i need the run a wire dose anyone have a guide on how to do it? -
It's never done that in her car nor mine and mines a 2018 vrs.
We don't use auto and in auto all the lights go out unless you code it on.
That's what i thought but if i turn the temp down they all work even when everything is cold.
Hi all bit of a strange one my partners 2013 Skoda Octavia’s lights seem faulty I’ve checked it with vcds no codes IMG_8329.mov
